cs_preprocessor_data.h File Reference
#include "fvm/fvm_io_num.h"
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_preprocessor_data.h:
Enumerations
enum  cs_preprocessor_data_restart_mode_t { CS_PREPROCESSOR_DATA_RESTART_NONE , CS_PREPROCESSOR_DATA_RESTART_AND_MODIFY , CS_PREPROCESSOR_DATA_RESTART_ONLY }
void cs_preprocessor_data_add_file (const char *file_name, size_t n_group_renames, const char **group_rename, const double transf_matrix[3][4])
int cs_preprocessor_check_perio (void)
cs_preprocessor_data_restart_mode_t cs_preprocessor_data_get_restart_mode (void)
 Return restart behavior for preprocessing. More...
void cs_preprocessor_data_set_restart_mode (cs_preprocessor_data_restart_mode_t mode)
 Define restart behavior in case of restart. More...
void cs_preprocessor_data_read_headers (cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder, bool ignore_cartesian)
void cs_preprocessor_data_read_mesh (cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder, bool ignore_cartesian)
◆ cs_preprocessor_data_restart_mode_t
Mesh preprocessing operations in case of restart.
Enumerator
do not use restart mesh for computation, or restart mesh not present
read restart mesh and enable further preprocessing
use restart mesh as-is, with no additional preprocessing (default if restart is present)
◆ cs_preprocessor_check_perio()
int cs_preprocessor_check_perio ( void  )
◆ cs_preprocessor_data_add_file()
void cs_preprocessor_data_add_file ( const char *  file_name,
const char **  group_rename,
◆ cs_preprocessor_data_get_restart_mode()
cs_preprocessor_data_restart_mode_t cs_preprocessor_data_get_restart_mode ( void  )
preprocessing mode in case of restart.
◆ cs_preprocessor_data_read_headers()
void cs_preprocessor_data_read_headers ( cs_mesh_t *  mesh,
cs_mesh_builder_t *  mesh_builder,
◆ cs_preprocessor_data_read_mesh()
void cs_preprocessor_data_read_mesh ( cs_mesh_t *  mesh,
◆ cs_preprocessor_data_set_restart_mode()
void cs_preprocessor_data_set_restart_mode ( cs_preprocessor_data_restart_mode_t  mode)
If no restart/mesh_input.csm (or restart/mesh_input) file is found, CS_PREPROCESSOR_DATA_RESTART_NONE will be used.
[in]modechosen preprocessing mode on restart
