cs_probe.h File Reference
#include "fvm/fvm_nodal.h"
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_probe.h:
Typedefs
typedef struct _cs_probe_set_t cs_probe_set_t
typedef void() cs_probe_set_define_local_t(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s)
 Function pointer to definition of probes based on rank-local points. More...
Enumerations
enum  cs_probe_snap_t { CS_PROBE_SNAP_NONE , CS_PROBE_SNAP_ELT_CENTER , CS_PROBE_SNAP_VERTEX }
void cs_probe_finalize (void)
 Free all structures related to a set of probes. More...
void cs_probe_set_transfer_associated_field_info (cs_probe_set_t *pset, int *n_fields, int **field_info)
 Transfer info on associated fields to the caller. More...
int cs_probe_get_n_sets (void)
 Retrieve the number of probe sets defined. More...
cs_probe_set_t * cs_probe_set_get (const char *name)
 Retrieve a cs_probe_set_t structure. More...
cs_probe_set_t * cs_probe_set_get_by_id (int pset_id)
 Retrieve a cs_probe_set_t structure from its id. More...
const char * cs_probe_set_get_name (const cs_probe_set_t *pset)
 Retrieve the name related to a cs_probe_set_t structure. More...
void cs_probe_set_get_post_info (const cs_probe_set_t *pset, bool *time_varying, bool *on_boundary, bool *on_curve, bool *auto_variables, bool *auto_curve_coo, bool *auto_cart_coo, int *n_writers, int *writer_ids[])
 Retrieve information useful for the postprocessing step. More...
const char * cs_probe_set_get_location_criteria (cs_probe_set_t *pset)
 Return the location filter selection criteria string for a given probe set. More...
int cs_probe_set_get_interpolation (cs_probe_set_t *pset)
 Return the interpolation option for a given probe set. More...
cs_probe_set_t * cs_probe_set_create (const char *name)
 Create a new set of probes. More...
void cs_probe_set_add_probe (cs_probe_set_t *pset, cs_real_t x, cs_real_t y, cs_real_t z, const char *label)
 Add a new probe to an existing set of probes. More...
cs_probe_set_t * cs_probe_set_create_from_array (const char *name, int n_probes, const cs_real_3_t *coords, const char **labels)
 Define a new set of probes from an array of coordinates. More...
cs_probe_set_t * cs_probe_set_create_from_segment (const char *name, int n_probes, const cs_real_t start_coords[3], const cs_real_t end_coords[3])
 Define a new set of probes from the segment spanned by two points. More...
cs_probe_set_t * cs_probe_set_create_from_local (const char *name, cs_probe_set_define_local_t *p_define_func, void *p_define_input)
 Define a new set of probes from rank-local definition function. More...
void cs_probe_set_allow_overwrite (const char *name)
 allow overwriting the definition of a given probe set. More...
void cs_probe_set_assign_curvilinear_abscissa (cs_probe_set_t *pset, const cs_real_t *s)
 Assign curvilinear abscissa for the given probe set. More...
void cs_probe_set_associate_writers (cs_probe_set_t *pset, int n_writers, const int *writer_ids)
 Associate a list of writers to a probe set. More...
void cs_probe_set_associate_field (cs_probe_set_t *pset, int writer_id, int field_id, int comp_id)
 Associate a field to a probe set. More...
void cs_probe_set_auto_var (cs_probe_set_t *pset, bool mode)
 Set automatic output of variables behavior. More...
void cs_probe_set_auto_curvilinear_coords (cs_probe_set_t *pset, bool mode)
 Set automatic output of curvilinear coordinates. More...
void cs_probe_set_auto_cartesian_coords (cs_probe_set_t *pset, bool mode)
 Set automatic output of cartesian coordinates. More...
void cs_probe_set_snap_mode (cs_probe_set_t *pset, cs_probe_snap_t snap_mode)
 Set snap mode related to the management of a set of probes. More...
void cs_probe_set_option (cs_probe_set_t *pset, const char *keyname, const char *keyval)
 Set optional parameters related to the management of a set of probes. More...
void cs_probe_set_locate (cs_probe_set_t *pset, const fvm_nodal_t *location_mesh)
 Try to locate each probe and define the coordinate really used for the postprocessing step. More...
fvm_nodal_t * cs_probe_set_export_mesh (cs_probe_set_t *pset, const char *mesh_name)
 Define a fvm_nodal_t structure from the set of probes. More...
fvm_nodal_t * cs_probe_set_unlocated_export_mesh (cs_probe_set_t *pset, const char *mesh_name)
 Define a fvm_nodal_t structure from the set of unlocated probes. More...
void cs_probe_set_dump (const cs_probe_set_t *pset)
 Dump a cs_probe_set_t structure. More...
void cs_probe_set_get_members (const cs_probe_set_t *pset, cs_probe_snap_t *snap_mode, int *n_probes, cs_real_3_t *coords[])
 Retrieve the main members of a cs_probe_set_t structure. More...
int cs_probe_set_get_n_local (const cs_probe_set_t *pset)
 Return the number probes in the local domain. More...
const cs_real_t * cs_probe_set_get_curvilinear_abscissa (const cs_probe_set_t *pset)
 Return the list of curvilinear abscissa for the given probe set. More...
cs_real_t * cs_probe_set_get_loc_curvilinear_abscissa (const cs_probe_set_t *pset)
 Return the list of curvilinear abscissa of probes located on the local ranks for the given probe set. More...
const cs_lnum_t * cs_probe_set_get_elt_ids (const cs_probe_set_t *pset, int mesh_location_id)
 Return the ids of a probe set's local matching elements, relative to a given mesh location. More...
Typedef Documentation
◆ cs_probe_set_define_local_t
If non-empty and not containing all elements, a list of coordinates as well as a list of curvilinear coordinates should be allocated (using CS_MALLOC) and defined by this function when called. Those list's lifecycle is then managed automatically by the probe set object.
Note: if the input pointer is non-null, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
[in,out]inputpointer to optional (untyped) value or structure
[out]n_eltsnumber of selected coordinates
[out]coordscoordinates of selected elements.
[out]scurvilinear coordinates of selected elements
◆ cs_probe_set_t
◆ cs_probe_snap_t
Enumerator
CS_PROBE_SNAP_NONE
No position change
snap to nearest cell or face center
‍snap to nearest vertex
◆ cs_probe_finalize()
void cs_probe_finalize ( void  )
◆ cs_probe_get_n_sets()
int cs_probe_get_n_sets ( void  )
◆ cs_probe_set_add_probe()
void cs_probe_set_add_probe ( cs_probe_set_t *  pset,
cs_real_t  x,
cs_real_t  y,
cs_real_t  z,
const char *  label
[in,out]psetset of probes
[in]xx coordinate of the point to add
[in]yy coordinate of the point to add
[in]zz coordinate of the point to add
[in]labelnull or the name of the point (optional)
◆ cs_probe_set_allow_overwrite()
void cs_probe_set_allow_overwrite ( const char *  name)
If no a probe set of the given name exists, the operation is ignored.
[in]namename of the probe set
◆ cs_probe_set_assign_curvilinear_abscissa()
void cs_probe_set_assign_curvilinear_abscissa ( cs_probe_set_t *  pset,
const cs_real_t *  s
This is effective only when using probe sets to which curvilinear coordinates have not already been assigned.
So this may be used following cs_probe_set_create (and probe additions) or cs_probe_set_create_from_array, but will be ignored for probe sets defined using cs_probe_set_create_from_segment and cs_probe_set_create_from_local.
If provided, the array of curvilinear absicssa must match the size of the probe set. If set to null, it is assumed a uniform spacing is provided between points.
[in]psetpointer to a cs_probe_set_t structure
[in]sarray of curvilinear abscissa, or null
If provided, the array of curvilinear absicssa must match the size of the probe set. If set to nullptr, it is assumed a uniform spacing is provided between points.
[in]sarray of curvilinear abscissa, or nullptr
◆ cs_probe_set_associate_field()
void cs_probe_set_associate_field ( cs_probe_set_t *  pset,
int  writer_id,
int  field_id,
int  comp_id
This function must be called during the postprocessing output definition stage, before any output actually occurs.
If the field should already be output automatically based on the mesh category and field output keywords, it will be filtered at a later stage.
[in]writer_idid of specified associated writer, or 0 (CS_POST_WRITER_ALL_ASSOCIATED) for all
[in]field_idid of field to attach
[in]comp_idid of field component (-1 for all)
◆ cs_probe_set_associate_writers()
void cs_probe_set_associate_writers ( cs_probe_set_t *  pset,
int  n_writers,
const int *  writer_ids
[in,out]psetpointer to a cs_probe_set_t structure to set
[in]n_writersnumber of writers assocuated to this probe set
[in]writer_idslist of writer ids
◆ cs_probe_set_auto_cartesian_coords()
void cs_probe_set_auto_cartesian_coords ( cs_probe_set_t *  pset,
bool  mode
[in]modetrue or false
◆ cs_probe_set_auto_curvilinear_coords()
void cs_probe_set_auto_curvilinear_coords ( cs_probe_set_t *  pset,
bool  mode
◆ cs_probe_set_auto_var()
void cs_probe_set_auto_var ( cs_probe_set_t *  pset,
bool  mode
◆ cs_probe_set_create()
cs_probe_set_t * cs_probe_set_create ( const char *  name)
[in]namename of the set of probes
a pointer to a new allocated cs_probe_set_t structure
◆ cs_probe_set_create_from_array()
cs_probe_set_t * cs_probe_set_create_from_array ( const char *  name,
int  n_probes,
const cs_real_3_t *  coords,
const char **  labels
[in]n_probesnumber of probes in coords and labels
[in]coordslist of coordinates related to each probe
[in]labelslist of label related to each probe (optional)
◆ cs_probe_set_create_from_local()
cs_probe_set_t * cs_probe_set_create_from_local ( const char *  name,
cs_probe_set_define_local_t *  p_define_func,
void *  p_define_input
The local definition function given by the p_define_func pointer is called just before locating probes on the parent mesh, so this allows building probe sets based on subsets of the computational mesh.
Note: if the p_define_input pointer is non-null, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
[in]p_define_funcfunction used for local definition
[in]p_define_inputoptional input for local definition function
◆ cs_probe_set_create_from_segment()
cs_probe_set_t * cs_probe_set_create_from_segment ( const char *  name,
int  n_probes,
If n_probes > 0, the given number of probes will be used for sampling, and will be evenly distributed along the segment.
If n_probes <= 0, one probe will be defined for each cell intersected by the line segment, and its position based on the projection of those cell centers on the given segment.
In both cases, using cs_probe_set_snap_mode can further modify this behavior.
[in]start_coordscoordinates of the starting point
[in]end_coordscoordinates of the ending point
[in]n_probesnumber of probes, or <= 0 for mesh intersection
◆ cs_probe_set_dump()
void cs_probe_set_dump ( const cs_probe_set_t *  pset)
◆ cs_probe_set_export_mesh()
fvm_nodal_t * cs_probe_set_export_mesh ( cs_probe_set_t *  pset,
const char *  mesh_name
[in]mesh_namename of the mesh to export
a pointer to a fvm_nodal_t structure
◆ cs_probe_set_get()
cs_probe_set_t * cs_probe_set_get ( const char *  name)
[in]namename of the set of probes to find
a pointer to a cs_probes_t structure or null if not found
◆ cs_probe_set_get_by_id()
cs_probe_set_t * cs_probe_set_get_by_id ( int  pset_id)
[in]pset_idid related to the set of probes to find
◆ cs_probe_set_get_curvilinear_abscissa()
const cs_real_t * cs_probe_set_get_curvilinear_abscissa ( const cs_probe_set_t *  pset)
null or the pointer to the array of abscissa
◆ cs_probe_set_get_elt_ids()
const cs_lnum_t * cs_probe_set_get_elt_ids ( const cs_probe_set_t *  pset,
The mesh_location id must match one of CS_MESH_LOCATION_CELLS, CS_MESH_LOCATION_BOUNDARY_FACES, or CS_MESH_LOCATION_VERTICES.
[in]mesh_location_idid of parent mesh location
◆ cs_probe_set_get_interpolation()
int cs_probe_set_get_interpolation ( cs_probe_set_t *  pset)
Interpolation will be applied only where possible.
interpolation option value
◆ cs_probe_set_get_loc_curvilinear_abscissa()
cs_real_t * cs_probe_set_get_loc_curvilinear_abscissa ( const cs_probe_set_t *  pset)
The caller is responsible for freeing the returned array.
◆ cs_probe_set_get_location_criteria()
const char * cs_probe_set_get_location_criteria ( cs_probe_set_t *  pset)
selection criteria string, or null if no filter defined
◆ cs_probe_set_get_members()
void cs_probe_set_get_members ( const cs_probe_set_t *  pset,
cs_probe_snap_t *  snap_mode,
int *  n_probes,
cs_real_3_t *  coords[]
[in,out]snap_modemode of location
[in,out]n_probesnumber of probes
[in,out]coordsprobe coordinates
◆ cs_probe_set_get_n_local()
int cs_probe_set_get_n_local ( const cs_probe_set_t *  pset)
number of probes in local domain
◆ cs_probe_set_get_name()
const char * cs_probe_set_get_name ( const cs_probe_set_t *  pset)
the name of the cs_probes_t structure or null if not found
◆ cs_probe_set_get_post_info()
void cs_probe_set_get_post_info ( const cs_probe_set_t *  pset,
bool *  time_varying,
bool *  on_boundary,
bool *  on_curve,
bool *  auto_variables,
bool *  auto_curve_coo,
bool *  auto_cart_coo,
int *  n_writers,
int *  writer_ids[]
Output arguments may be set to null if we do not need to query them.
[out]time_varyingtrue if probe locations may change with time
[out]on_boundarytrue if probes are located on boundary
[out]on_curvetrue if the probe set has cuvilinear coordinates
[out]auto_variablestrue if set of variables to output is predefined
[out]auto_curve_cootrue if curvilinear coordinates should be output
[out]auto_cart_cootrue if cartesian coordinates should be output
[out]n_writersnumber of associated user-defined writers, or -1 if default unchanged
[out]writer_idspointer to a list of writer ids
◆ cs_probe_set_locate()
void cs_probe_set_locate ( cs_probe_set_t *  pset,
const fvm_nodal_t *  location_mesh
For better performance when using multiple probe sets, a pointer to an existing location mesh may be passed to this function. The caller is responsible for ensuring this mesh matches selection criteria for the probe set.
[in]location_meshoptional pointer to mesh relative to which probe set should be located, or null
[in]location_meshoptional pointer to mesh relative to which probe set should be located, or nullptr
◆ cs_probe_set_option()
void cs_probe_set_option ( cs_probe_set_t *  pset,
const char *  keyname,
const char *  keyval
Available option key names accepting true or false:
  • transient_location if true, relocate probes relative to deforming or moving mesh (default: false)
  • boundary if \ c true, locate on boundary mesh; if false, locate on volume mesh (default)
Other options:
  • selection_criteria where keyval is selection criteria string
  • tolerance where keyval is for instance "0.05" (default "0.10")
  • interpolation if \ c 0, P0 interpolation (default); if 1, simple gradient-based interpolation for volume probes (ignored for boundaries). Other interpolation options might be added in the future.
[in]keynamename of the keyword related to the parameter to set
[in]keyvalvalue of the keyword to set
◆ cs_probe_set_snap_mode()
void cs_probe_set_snap_mode ( cs_probe_set_t *  pset,
[in]snap_modesnap mode to set
◆ cs_probe_set_transfer_associated_field_info()
void cs_probe_set_transfer_associated_field_info ( cs_probe_set_t *  pset,
int *  n_fields,
int **  field_info
This function transfers the property of the associated arrays to the caller and removes it from the probe set info.
[out]n_fieldsnumber of associated fields
[out]field_infoassociated field info (array of tuples with writer id, field id, component id)
◆ cs_probe_set_unlocated_export_mesh()
fvm_nodal_t * cs_probe_set_unlocated_export_mesh ( cs_probe_set_t *  pset,
