Examples of volume exchange coefficient computation for SYRTHES coupling (cs_user_syrthes_coupling_volume_h)
The Examples function is required to compute a volume exchange coefficient for SYRTHES coupling.
Examples
The following code blocks show two examples of computation of a volume exchange coefficient.
Example 1
The first example corresponds to a constant volume exchange coefficient:
cs_real_t hvol_cst = 1.0e6;
for (cs_lnum_t i = 0; i < n_elts; i++) {
h_vol[i] = hvol_cst;
Definition: cs_defs.h:332
Definition: cs_defs.h:325
Example 2
The second example corresponds to a variable volume exchange coefficient defined as follows :
\[ h_{vol} = h_{surf} S \]
with S is the surface area where exchanges take place by unit of volume and
\[ h_{surf} = \frac{Nu \lambda}{L} \]
First, the values of the different fields that will be needed for the computation of the volume exchange coefficient are retrieved.
const cs_real_3_t *cvar_vel = (const cs_real_3_t *)CS_F_(vel)->val;
const cs_real_t *cpro_rom = (const cs_real_t *)CS_F_(rho)->val;
const cs_real_t *cpro_mu = (const cs_real_t *)CS_F_(mu)->val;
cs_real_t visls_0 = -1;
const cs_real_t *cpro_cp = nullptr, *cpro_viscls = nullptr;
cs_lnum_t cp_step = 0, viscls_step = 0;
if (CS_F_(cp) != nullptr) {
cpro_cp = (const cs_real_t *)CS_F_(cp)->val;
cp_step = 1;
else {
cpro_cp = &cp0;
/* Get thermal field and associated diffusivity
(temperature only handled here) */
const int viscl_id = fth->get_key_int("diffusivity_id");
if (viscl_id > -1) {
cpro_viscls = (const cs_real_t *)cs_field(viscl_id)->val;
viscls_step = 1;
else {
visls_0 = fth->get_key_double("diffusivity_ref");
cpro_viscls = &visls_0;
const int is_temperature = fth->get_key_int("is_temperature");
Definition: cs_field.h:275
int get_key_int(int key_id) const
Definition: cs_field.cpp:4507
double get_key_double(int key_id) const
Return a floating point value for a given key associated with a field.
Definition: cs_field.cpp:4745
cs_real_t * val
Definition: cs_field.h:298
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
@ mu
Definition: cs_field_pointer.h:102
@ vel
Definition: cs_field_pointer.h:66
@ cp
Definition: cs_field_pointer.h:99
@ rho
Definition: cs_field_pointer.h:96
#define CS_F_(e)
Definition: cs_field_pointer.h:47
Definition: cs_physical_constants.cpp:462
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:180
real(c_double), pointer, save cp0
reference specific heat.
Definition: cstphy.f90:81
double cp0
Definition: cs_physical_constants.h:85
Then the coefficient can be computed and assigned to all cells.
cs_real_t sexcvo = 36.18; /* Surface area where exchanges take
place by unit of volume */
cs_real_t l0 = 0.03; /* Characteristic length */
cs_lnum_t c_id = elt_ids[i];
cs_real_t rho = cpro_rom[c_id];
cs_real_t mu = cpro_mu[c_id];
cs_real_t cp = cpro_cp[c_id*cp_step];
cs_real_t lambda, lambda_over_cp;
if (is_temperature) {
lambda = cpro_viscls[c_id*viscls_step];
lambda_over_cp = lambda / cp;
else {
lambda_over_cp = cpro_viscls[c_id*viscls_step];
lambda = lambda_over_cp * cp;
/* Compute a local molecular Prandtl **(1/3) */
cs_real_t pr = mu / lambda_over_cp;
/* Compute a local Reynolds number */
cs_real_t uloc = cs_math_3_norm(cvar_vel[c_id]);
cs_real_t re = fmax(uloc*rho*l0/mu, 1.); /* To avoid division by zero */
/* Compute Nusselt number using Colburn correlation */
cs_real_t nu = 0.023 * pow(re, 0.8) * cbrt(pr);
cs_real_t h_corr = nu * lambda / l0;
/* Compute hvol */
h_vol[i] = h_corr * sexcvo;
@ lambda
Definition: cs_field_pointer.h:105
CS_F_HOST_DEVICE T cs_math_3_norm(const T v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:240
Not that in this example, no test is done on the coupling id or Syrthes instance name. The corresponding arguments can be used to apply specific computations in cas of multiple couplings.
Also, although a test is done to check if the scalar behaves as a temperature regarding multiplication by Cp for more generality, the Syrthes volume coupling currently only handles the temperature variable.
