Module for physical constants
double precision tkelvi
 Temperature in Kelvin correponding to 0 degrees Celsius (= +273,15) More...
double precision stephn
 Stephan constant for the radiative module $\sigma$ in $W.m^{-2}.K^{-4}$. More...
real(c_double), pointer, save gy
 Gravity. More...
real(c_double), pointer, save gz
real(c_double), pointer, save rair
 Perfect gas constant for air (mixture) More...
real(c_double), pointer, save rvsra
 ratio gas constant h2o/ dry air More...
real(c_double), pointer, save p0
 reference pressure for the total pressure.
More...
real(c_double), pointer, save t0
 reference temperature. More...
real(c_double), pointer, save cp0
 reference specific heat. More...
◆ cp0
Useful with a thermal model. Unless the user specifies the specific heat in the user function cs_user_physical_properties with the compressible module or coal combustion, cp0 is also needed even when there is no user scalar.
Note
None of the scalars from the specific physics is a temperature.
When using the Graphical Interface, cp0 is also used to calculate the diffusivity of the thermal scalars, based on their conductivity; it is therefore needed, unless the diffusivity is also specified in cs_user_physical_properties.
◆ gy
Gravity.
◆ gz
◆ p0
◆ rair
◆ rvsra
◆ stephn
◆ t0
Useful for the specific physics gas or coal combustion (initialization of the density), for the electricity modules to initialize the domain temperature and for the compressible module (initializations). It must be given in Kelvin.
◆ tkelvi
