Compute a time dependent parameter value from a time table defined by the user.
To access a time table defined variable when defining boundary conditions, a callback function of the type of type cs_dof_func_t can be defined, such as the following (for a time table named "inlet_temperature"):
static void
bool dense_output,
[[maybe_unused]] void *input,
time,
1,
false);
const cs_lnum_t face_id = (elt_ids ==
nullptr) ? i : elt_ids[i];
const cs_lnum_t j = dense_output ? i : face_id;
retval[j] = inlet_temp;
double t_cur
Definition: cs_time_step.h:78
Definition: cs_defs.h:332
Definition: cs_defs.h:325
cs_real_t cs_time_table_compute_time_value(const char *name, cs_real_t t, const int col, bool overwrite_prev)
Compute value using a given abscissa and a specific column.
Definition: cs_time_table.cpp:665
Note that accessing the time table value in the function above is done through the call to cs_time_table_compute_time_value.
The callback function can then be assigned to the zone named "inlet" for variable "scalar1" in the usual way (in cs_user_boundary_conditions_setup):
"inlet",
_time_table_t_inlet,
nullptr);
cs_equation_param_t * cs_equation_param_by_name(const char *eqname)
Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equatio...
Definition: cs_equation.cpp:592
cs_xdef_t * cs_equation_add_bc_by_dof_func(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Define and initialize a new structure to set a boundary condition related to the given cs_equation_pa...
Definition: cs_equation_param.cpp:2847
const cs_flag_t cs_flag_boundary_face
Definition: cs_flag.cpp:78
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:506
