cs_lagr_attribute_map_t Struct Reference
#include <cs_lagr_particle.h>
+ Collaboration diagram for cs_lagr_attribute_map_t:
Public Member Functions
CS_F_HOST_DEVICE cs_lagr_attribute_map_t ()
 Default constructor. More...
CS_F_HOST cs_lagr_attribute_map_t (cs_lnum_t attr_keys[CS_LAGR_N_ATTRIBUTES][3])
 Constructor based on a list of attribute keys. More...
CS_F_HOST_DEVICE cs_lagr_attribute_map_t (const cs_lagr_attribute_map_t &other)
 Copy constructor using a shallow copy (no allocation) More...
CS_F_HOST_DEVICE cs_lagr_attribute_map_t (cs_lagr_attribute_map_t &&other)
 Move constructor. More...
CS_F_HOST_DEVICE ~cs_lagr_attribute_map_t ()
 Default destructor. More...
CS_F_HOST_DEVICE cs_lagr_attribute_map_t & operator= (cs_lagr_attribute_map_t other)
 Assignment operator. More...
Public Attributes
size_t extents
size_t lb
int n_time_vals
size_t size [CS_LAGR_N_ATTRIBUTES]
cs_datatype_t datatype [CS_LAGR_N_ATTRIBUTES]
int(* count )[CS_LAGR_N_ATTRIBUTES]
ptrdiff_t(* displ )[CS_LAGR_N_ATTRIBUTES]
ptrdiff_t * source_term_displ
Friends
struct cs_lagr_particle_set_t
Particle attribute structure mapping
Constructor & Destructor Documentation
◆ cs_lagr_attribute_map_t() [1/4]
◆ cs_lagr_attribute_map_t() [2/4]
CS_F_HOST cs_lagr_attribute_map_t ( cs_lnum_t  attr_keys[CS_LAGR_N_ATTRIBUTES][3])
[in]attr_keyskeys to sort attributes
◆ cs_lagr_attribute_map_t() [3/4]
◆ cs_lagr_attribute_map_t() [4/4]
Move constructor.
[in]otherOriginal reference to move
◆ ~cs_lagr_attribute_map_t()
Default destructor.
Member Function Documentation
◆ operator=()
Friends And Related Function Documentation
◆ cs_lagr_particle_set_t
friend struct cs_lagr_particle_set_t
friend
Member Data Documentation
◆ count
int(* count)[CS_LAGR_N_ATTRIBUTES]
◆ datatype
◆ displ
ptrdiff_t(* displ)[CS_LAGR_N_ATTRIBUTES]
◆ extents
size_t extents
◆ lb
size_t lb
◆ n_time_vals
int n_time_vals
◆ size
size_t size[CS_LAGR_N_ATTRIBUTES]
◆ source_term_displ
ptrdiff_t* source_term_displ
