cs_lagr_particle.h File Reference
#include "assert.h"
#include "string.h"
+ Include dependency graph for cs_lagr_particle.h:
Classes
struct  cs_lagr_attribute_map_t
struct  cs_lagr_particle_set_t
Macros
#define CS_LAGR_PART_TO_DELETE   (1 << 0)
#define CS_LAGR_PART_FIXED   (1 << 1)
#define CS_LAGR_PART_DEPOSITED   (1 << 2)
#define CS_LAGR_PART_ROLLING   (1 << 3)
#define CS_LAGR_PART_IMPOSED_MOTION   (1 << 4)
#define CS_LAGR_PART_DEPOSITION_FLAGS
Enumerations
enum  cs_lagr_attribute_t {
  CS_LAGR_P_FLAG , CS_LAGR_CELL_ID , CS_LAGR_RANK_ID , CS_LAGR_REBOUND_ID ,
  CS_LAGR_RANDOM_VALUE , CS_LAGR_STAT_WEIGHT , CS_LAGR_RESIDENCE_TIME , CS_LAGR_MASS ,
  CS_LAGR_DIAMETER , CS_LAGR_TAUP_AUX , CS_LAGR_COORDS , CS_LAGR_VELOCITY ,
  CS_LAGR_VELOCITY_SEEN , CS_LAGR_VELOCITY_SEEN_VELOCITY_COV , CS_LAGR_TR_TRUNCATE , CS_LAGR_TR_REPOSITION ,
  CS_LAGR_TURB_STATE_1 , CS_LAGR_BROWN_STATE_1 , CS_LAGR_PRED_VELOCITY , CS_LAGR_PRED_VELOCITY_SEEN ,
  CS_LAGR_V_GAUSS , CS_LAGR_BR_GAUSS , CS_LAGR_SHAPE , CS_LAGR_ORIENTATION ,
  CS_LAGR_QUATERNION , CS_LAGR_RADII , CS_LAGR_ANGULAR_VEL , CS_LAGR_EULER ,
  CS_LAGR_SHAPE_PARAM , CS_LAGR_YPLUS , CS_LAGR_INTERF , CS_LAGR_NEIGHBOR_FACE_ID ,
  CS_LAGR_MARKO_VALUE , CS_LAGR_FOULING_INDEX , CS_LAGR_N_LARGE_ASPERITIES , CS_LAGR_N_SMALL_ASPERITIES ,
  CS_LAGR_ADHESION_FORCE , CS_LAGR_ADHESION_TORQUE , CS_LAGR_DISPLACEMENT_NORM , CS_LAGR_HEIGHT ,
  CS_LAGR_CLUSTER_NB_PART , CS_LAGR_DEPO_TIME , CS_LAGR_CONSOL_HEIGHT , CS_LAGR_TEMPERATURE ,
  CS_LAGR_TEMPERATURE_SEEN , CS_LAGR_CP , CS_LAGR_WATER_MASS , CS_LAGR_COAL_MASS ,
  CS_LAGR_COKE_MASS , CS_LAGR_SHRINKING_DIAMETER , CS_LAGR_INITIAL_DIAMETER , CS_LAGR_COAL_ID ,
  CS_LAGR_COAL_DENSITY , CS_LAGR_EMISSIVITY , CS_LAGR_STAT_CLASS , CS_LAGR_AGGLO_CLASS_ID ,
  CS_LAGR_AGGLO_FRACTAL_DIM , CS_LAGR_REMAINING_INTEG_TIME , CS_LAGR_USER , CS_LAGR_N_ATTRIBUTES
void cs_lagr_particle_attr_initialize (void)
 Define particle map based on defined options. More...
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map (void)
 Return const pointer to the main particle attribute map structure. More...
void cs_lagr_particle_set_create (void)
void cs_lagr_particle_finalize (void)
 Destroy main particle set and map if they exist. More...
void cs_lagr_part_copy (cs_lnum_t dest, cs_lnum_t src)
 Copy attributes from one particle to another. More...
void cs_lagr_get_attr_info (const cs_lagr_particle_set_t *particles, int time_id, cs_lagr_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
 Get data extents for a given particle attribute. More...
int cs_lagr_check_attr_query (const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id)
 Check that query for a given particle attribute is valid. More...
void cs_lagr_particle_attr_in_range (int attr)
 Check if a particle attribute is in a valid range. More...
cs_lagr_particle_set_t * cs_lagr_get_particle_set (void)
 Return pointer to the main cs_lagr_particle_set_t structure. More...
cs_lagr_particle_set_t & cs_lagr_get_particle_set_ref (void)
static void * cs_lagr_particles_attr (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Get pointer to a current attribute of a given particle in a set. More...
static const void * cs_lagr_particles_attr_const (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Get const pointer to current attribute data of a given particle in a set. More...
static void * cs_lagr_particles_attr_n (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Get pointer to attribute data of a given particle in a set at a given time. More...
static const void * cs_lagr_particles_attr_n_const (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Get const pointer to attribute data of a given particle in a set at a given time. More...
static int cs_lagr_particles_get_flag (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
 Get flag value with a selected mask for a given particle in a set. More...
static void cs_lagr_particles_set_flag (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
 Set flag value with a selected mask for a given particle in a set. More...
static void cs_lagr_particles_unset_flag (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
 Unset flag value with a selected mask for a given particle in a set. More...
static cs_lnum_t cs_lagr_particles_get_lnum (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_lnum_t of a given particle in a set. More...
static cs_lnum_t cs_lagr_particles_get_lnum_n (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_lnum_t of a given particle in a set at a given time. More...
static void cs_lagr_particles_set_lnum (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_lnum_t value)
 Set attribute value of type cs_lnum_t of a given particle in a set. More...
static void cs_lagr_particles_set_lnum_n (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
 Set attribute value of type cs_lnum_t of a given particle in a set at a given time. More...
static cs_gnum_t cs_lagr_particles_get_gnum (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_gnum_t of a given particle in a set. More...
static cs_gnum_t cs_lagr_particles_get_gnum_n (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_gnum_t of a given particle in a set at a given time. More...
static void cs_lagr_particles_set_gnum (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_gnum_t value)
 Set attribute value of type cs_gnum_t of a given particle in a set. More...
static void cs_lagr_particles_set_gnum_n (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
 Set attribute value of type cs_gnum_t of a given particle in a set at a given time. More...
static cs_real_t cs_lagr_particles_get_real (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_real_t of a given particle in a set. More...
static cs_real_t cs_lagr_particles_get_real_n (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Get attribute value of type cs_real_t of a given particle in a set at a given time. More...
static void cs_lagr_particles_set_real (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_real_t value)
 Set attribute value of type cs_real_t of a given particle in a set. More...
static void cs_lagr_particles_set_real_n (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
 Set attribute value of type cs_real_t of a given particle in a set at a given time. More...
static void cs_lagr_particles_attributes_fill_zero (cs_lagr_particle_set_t *p_set, cs_lnum_t p_id)
void cs_lagr_set_reallocation_factor (double f)
 Set reallocation factor for particle sets. More...
unsigned long long cs_lagr_get_n_g_particles_max (void)
 Get global maximum number of particles. More...
void cs_lagr_set_n_g_particles_max (unsigned long long n_g_particles_max)
 Set global maximum number of particles. More...
void cs_lagr_particles_current_to_previous (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id)
 Copy current attributes to previous attributes. More...
void cs_lagr_particle_set_dump (const cs_lagr_particle_set_t *p_set)
 Dump a cs_lagr_particle_set_t structure. More...
void cs_lagr_set_n_user_variables (int n_user_variables)
 Set number of user particle variables. More...
template<typename T >
T * cs_lagr_particles_attr_get_ptr (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
const T * cs_lagr_particles_attr_get_const_ptr (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
T * cs_lagr_particles_attr_n_get_ptr (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
const T * cs_lagr_particles_attr_n_get_const_ptr (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
T cs_lagr_particles_attr_get_val (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
void cs_lagr_particles_attr_set_val (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, T value)
T cs_lagr_particles_attr_n_get_val (const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
void cs_lagr_particles_attr_n_set_val (cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, T value)
const char * cs_lagr_attribute_name []
cs_lagr_particle_set_t * cs_glob_lagr_particle_set
◆ CS_LAGR_PART_DEPOSITED
particle is deposited
◆ CS_LAGR_PART_DEPOSITION_FLAGS
Value:
Definition: cs_lagr_particle.h:51
Definition: cs_lagr_particle.h:48
Definition: cs_lagr_particle.h:60
Definition: cs_lagr_particle.h:54
Definition: cs_lagr_particle.h:57
Flag sets (useful for cancelling nay flag of a set)
particle is in flow
◆ CS_LAGR_PART_FIXED
particle is fixed, no resuspension possible
◆ CS_LAGR_PART_IMPOSED_MOTION
particle motion is prescribed
◆ CS_LAGR_PART_ROLLING
particle is rolling
◆ CS_LAGR_PART_TO_DELETE
Flags specifying general event attributes
particle will be deleted
◆ cs_lagr_attribute_t
Prefedined particle attributes
Enumerator
CS_LAGR_P_FLAG
local metadata flag
CS_LAGR_CELL_ID
local cell id (0 to n-1)
CS_LAGR_RANK_ID
local parallel rank id
CS_LAGR_REBOUND_ID
number of time steps since rebound, or -1
associated random value (for sampling)
CS_LAGR_STAT_WEIGHT
statistical weight
time since particle injection
CS_LAGR_MASS
CS_LAGR_DIAMETER
CS_LAGR_TAUP_AUX
CS_LAGR_COORDS
CS_LAGR_VELOCITY
tensor array with the covariance usk_i up_j
CS_LAGR_TR_TRUNCATE
portion of trajectory truncated
number of times the particle is repositioned at the cell center, or -1 when lost (to be discarded at the next displacement step)
CS_LAGR_V_GAUSS
CS_LAGR_BR_GAUSS
CS_LAGR_SHAPE
Shape of spheroids
CS_LAGR_ORIENTATION
Orientation of spheroids
CS_LAGR_QUATERNION
Quaternion for spheroids
CS_LAGR_RADII
Radii a, b, c for ellispoids
CS_LAGR_ANGULAR_VEL
Angular velocity
CS_LAGR_EULER
Euler four parameters
CS_LAGR_SHAPE_PARAM
Shape parameters computed from a b c
CS_LAGR_YPLUS
CS_LAGR_INTERF
CS_LAGR_MARKO_VALUE
CS_LAGR_HEIGHT
CS_LAGR_DEPO_TIME
CS_LAGR_TEMPERATURE
CS_LAGR_CP
CS_LAGR_WATER_MASS
CS_LAGR_COAL_MASS
CS_LAGR_COKE_MASS
CS_LAGR_COAL_ID
CS_LAGR_EMISSIVITY
CS_LAGR_STAT_CLASS
CS_LAGR_USER
◆ cs_lagr_check_attr_query()
int cs_lagr_check_attr_query ( const cs_lagr_particle_set_t *  p_set,
int  stride,
int  component_id
[in]particlesassociated particle set
[in]attrattribute whose values are required
[in]datatypeassociated value type
[in]stridenumber of values per particle
[in]component_idif -1 : extract the whole attribute if >0 : id of the component to extract
0 in case of success, 1 in case of error
[in]p_setassociated particle set
◆ cs_lagr_get_attr_info()
void cs_lagr_get_attr_info ( const cs_lagr_particle_set_t *  p_set,
int  time_id,
size_t *  extents,
size_t *  size,
ptrdiff_t *  displ,
cs_datatype_t *  datatype,
int *  count
For attributes not currently present, the displacement and data size should be -1 and 0 respectively.
[in]time_idassociated time id (0: current, 1: previous)
[in]attrparticle attribute
[out]extentssize (in bytes) of particle structure, or NULL
[out]sizesize (in bytes) of attribute in particle structure, or NULL
[out]displdisplacement (in bytes) in particle structure, or NULL
[out]datatypedatatype of associated attribute, or NULL
[out]countnumber of type values associated with attribute, or NULL
[in]p_setpointer to particle set
[out]extentssize (in bytes) of particle structure, or nullptr
[out]sizesize (in bytes) of attribute in particle structure, or nullptr
[out]displdisplacement (in bytes) in particle structure, or nullptr
[out]datatypedatatype of associated attribute, or nullptr
[out]countnumber of type values associated with attribute, or nullptr
◆ cs_lagr_get_n_g_particles_max()
unsigned long long cs_lagr_get_n_g_particles_max ( void  )
By default, the number is limited only by local cs_lnum_t and global cs_gnum_t data representation limits.
◆ cs_lagr_get_particle_set()
cs_lagr_particle_set_t * cs_lagr_get_particle_set ( void  )
pointer to current particle set, or nullptr
◆ cs_lagr_get_particle_set_ref()
cs_lagr_particle_set_t & cs_lagr_get_particle_set_ref ( void  )
◆ cs_lagr_part_copy()
void cs_lagr_part_copy ( cs_lnum_t  dest,
cs_lnum_t  src
The random value associated with the particle is modified.
destid (0-based) of destination particle
srcid (0-based) of source particle
◆ cs_lagr_particle_attr_in_range()
void cs_lagr_particle_attr_in_range ( int  attr)
If this is not the case, a fatal error is provoked.
◆ cs_lagr_particle_attr_initialize()
void cs_lagr_particle_attr_initialize ( void  )
◆ cs_lagr_particle_finalize()
void cs_lagr_particle_finalize ( void  )
◆ cs_lagr_particle_get_attr_map()
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map ( void  )
pointer to current particle attribute map, or NULL
pointer to current particle attribute map, or nullptr
◆ cs_lagr_particle_set_create()
void cs_lagr_particle_set_create ( void  )
Allocate main cs_lagr_particle_set_t structure.
◆ cs_lagr_particle_set_dump()
void cs_lagr_particle_set_dump ( const cs_lagr_particle_set_t *  p_set)
[in]p_setcs_lagr_particle_t structure to dump
◆ cs_lagr_particles_attr()
static void * cs_lagr_particles_attr ( cs_lagr_particle_set_t *  particle_set,
inlinestatic
[in]particle_setpointer to particle set
[in]particle_idparticle id
[in]attrrequested attribute id
◆ cs_lagr_particles_attr_const()
static const void * cs_lagr_particles_attr_const ( const cs_lagr_particle_set_t *  particle_set,
inlinestatic
◆ cs_lagr_particles_attr_get_const_ptr()
const T * cs_lagr_particles_attr_get_const_ptr ( const cs_lagr_particle_set_t *  particle_set,
◆ cs_lagr_particles_attr_get_ptr()
T * cs_lagr_particles_attr_get_ptr ( cs_lagr_particle_set_t *  particle_set,
◆ cs_lagr_particles_attr_get_val()
T cs_lagr_particles_attr_get_val ( const cs_lagr_particle_set_t *  particle_set,
◆ cs_lagr_particles_attr_n()
static void * cs_lagr_particles_attr_n ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
inlinestatic
[in]time_id0 for current, 1 for previous
pointer to attribute data at given time
◆ cs_lagr_particles_attr_n_const()
static const void * cs_lagr_particles_attr_n_const ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
inlinestatic
◆ cs_lagr_particles_attr_n_get_const_ptr()
const T * cs_lagr_particles_attr_n_get_const_ptr ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
◆ cs_lagr_particles_attr_n_get_ptr()
T * cs_lagr_particles_attr_n_get_ptr ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
◆ cs_lagr_particles_attr_n_get_val()
T cs_lagr_particles_attr_n_get_val ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
◆ cs_lagr_particles_attr_n_set_val()
void cs_lagr_particles_attr_n_set_val ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
T  value
◆ cs_lagr_particles_attr_set_val()
void cs_lagr_particles_attr_set_val ( cs_lagr_particle_set_t *  particle_set,
T  value
◆ cs_lagr_particles_attributes_fill_zero()
static void cs_lagr_particles_attributes_fill_zero ( cs_lagr_particle_set_t *  p_set,
cs_lnum_t  p_id
inlinestatic
[in,out]p_setpointer to particle set
[in]valuevalue to assign
◆ cs_lagr_particles_current_to_previous()
void cs_lagr_particles_current_to_previous ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id
[in,out]p_setassociated particle set
[in]p_idid of particle
[in,out]p_setreference to particle set
◆ cs_lagr_particles_get_flag()
static int cs_lagr_particles_get_flag ( const cs_lagr_particle_set_t *  particle_set,
int  mask
inlinestatic
[in]maskrequested attribute flag value
attribute value
◆ cs_lagr_particles_get_gnum()
static cs_gnum_t cs_lagr_particles_get_gnum ( const cs_lagr_particle_set_t *  particle_set,
inlinestatic
attribute value
◆ cs_lagr_particles_get_gnum_n()
static cs_gnum_t cs_lagr_particles_get_gnum_n ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
inlinestatic
attribute value
◆ cs_lagr_particles_get_lnum()
static cs_lnum_t cs_lagr_particles_get_lnum ( const cs_lagr_particle_set_t *  particle_set,
inlinestatic
attribute value
◆ cs_lagr_particles_get_lnum_n()
static cs_lnum_t cs_lagr_particles_get_lnum_n ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
inlinestatic
attribute value
◆ cs_lagr_particles_get_real()
static cs_real_t cs_lagr_particles_get_real ( const cs_lagr_particle_set_t *  particle_set,
inlinestatic
attribute value
◆ cs_lagr_particles_get_real_n()
static cs_real_t cs_lagr_particles_get_real_n ( const cs_lagr_particle_set_t *  particle_set,
int  time_id,
inlinestatic
attribute value
◆ cs_lagr_particles_set_flag()
static void cs_lagr_particles_set_flag ( const cs_lagr_particle_set_t *  particle_set,
int  mask
inlinestatic
[in]maskattribute flag value to set
◆ cs_lagr_particles_set_gnum()
static void cs_lagr_particles_set_gnum ( cs_lagr_particle_set_t *  particle_set,
cs_gnum_t  value
inlinestatic
[in,out]particle_setpointer to particle set
◆ cs_lagr_particles_set_gnum_n()
static void cs_lagr_particles_set_gnum_n ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
cs_gnum_t  value
inlinestatic
◆ cs_lagr_particles_set_lnum()
static void cs_lagr_particles_set_lnum ( cs_lagr_particle_set_t *  particle_set,
cs_lnum_t  value
inlinestatic
◆ cs_lagr_particles_set_lnum_n()
static void cs_lagr_particles_set_lnum_n ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
cs_lnum_t  value
inlinestatic
◆ cs_lagr_particles_set_real()
static void cs_lagr_particles_set_real ( cs_lagr_particle_set_t *  particle_set,
cs_real_t  value
inlinestatic
◆ cs_lagr_particles_set_real_n()
static void cs_lagr_particles_set_real_n ( cs_lagr_particle_set_t *  particle_set,
int  time_id,
cs_real_t  value
inlinestatic
◆ cs_lagr_particles_unset_flag()
static void cs_lagr_particles_unset_flag ( const cs_lagr_particle_set_t *  particle_set,
int  mask
inlinestatic
◆ cs_lagr_set_n_g_particles_max()
void cs_lagr_set_n_g_particles_max ( unsigned long long  n_g_particles_max)
[in]n_g_particles_maxglobal maximum number of particles
◆ cs_lagr_set_n_user_variables()
void cs_lagr_set_n_user_variables ( int  n_user_variables)
[in]n_user_variablesnumber of user variables
◆ cs_lagr_set_reallocation_factor()
void cs_lagr_set_reallocation_factor ( double  f)
This factor determines the multiplier used for reallocations when the particle set's buffers are too small to handle the new number of particles.
[in]freallocation size multiplier
◆ cs_glob_lagr_particle_set
cs_lagr_particle_set_t* cs_glob_lagr_particle_set
extern
Pointer to the main particle set
◆ cs_lagr_attribute_name
const char* cs_lagr_attribute_name[]
extern
Names of particle attributes
