Gas 3 PTCHEM example
The following sections illustrate subsets of a same example, combining high-level definitions (which are preferred), and lower-level setings where necessary.
This is assumed to be combined with the GUI or settings not specific to gas combustion, so wall and symmetry conditions are not shown here.
Definitions for the setup stage
Using a fixed mass-flow rate, the main inlet conditions can be defined in cs_user_boundary_conditions_setup, as follows for a zone named "inlet":
const cs_zone_t *z = cs_boundary_zone_by_name("inlet");
cs_real_t q_inlet = q_burner / 360.; /* W */
cs_real_t m_inlet = q_inlet / cs_glob_combustion_gas_model->pcigas; /* kg/s */
cs_real_t r_inlet = 0.15; /* m */
void cs_boundary_conditions_open_set_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant mass flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.cpp:3048
void cs_boundary_conditions_inlet_set_turbulence_hyd_diam(const cs_zone_t *zone, cs_real_t hd)
Base the inlet turbulence values on a a circular duct with smooth wall (see ref cs_turbulence_bc_ke_h...
Definition: cs_boundary_conditions.cpp:3355
Definition: cs_boundary_zone.cpp:708
cs_combustion_gas_model_t * cs_glob_combustion_gas_model
Definition: cs_combustion_gas.cpp:169
Definition: cs_defs.h:332
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.cpp:408
double pcigas
Definition: cs_combustion_gas.h:197
Definition: cs_zone.h:51
Note that we have used a notebook variable here, allowing parametrization of the computation, but the mass flow should be fixed. For a variable mass flow rate, use cs_boundary_conditions_open_set_mass_flow_rate_by_func instead.
Definitions for the compute stage
Not all definitions can yet be handled at the setup stage, so additional settings are needed in cs_user_boundary_conditions.
Local variables to be added
The following aliases (for conciseness of the downstream code) and initializations are used here:
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
const int kbmasf = cs_field_key_id("boundary_mass_flux_id");
const int iflmab = CS_F_(vel)->get_key_int(kbmasf);
const auto bmasfl = cs_field(iflmab)->get_val_s();
/* Oxydant temperature needed by the combustion model
when there is no oxydant inlet */
for (int icg = 0; icg < CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES; icg++)
coefg[icg] = 0;
coefg[1] = 1;
cm->tinoxy = fp->t0;
cm->hinoxy = cs_combustion_t_to_h(coefg, cm->tinoxy);
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
#define CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES
Definition: cs_combustion_gas.h:51
cs_real_t cs_combustion_t_to_h(const cs_real_t x_sp[], cs_real_t t)
Convert a temperature to enthalpy value for gas combustion.
Definition: cs_combustion_ht_convert.cpp:161
Definition: cs_defs.h:325
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
Definition: cs_field.cpp:2728
@ vel
Definition: cs_field_pointer.h:66
#define CS_F_(e)
Definition: cs_field_pointer.h:47
Definition: cs_physical_constants.cpp:462
Definition: cs_combustion_gas.h:181
double hinoxy
Definition: cs_combustion_gas.h:242
double tinoxy
Definition: cs_combustion_gas.h:241
Fluid properties descriptor.
double t0
Definition: cs_physical_constants.h:84
Inlet definitions
Based on the inlet defined at the setup stage, the following additional settings can be used. Note that the inlet temperature is global to the module, but matches an inlet, so we choose to (re)set it here. These settings will be handled in the setup stage in a future version.
/* Fuel flow inlet type */
ci->ientfu = 1;
/* Inlet Temperature in K */
cm->tinfue = fp->t0;
cs_combustion_bc_inlet_t * cs_combustion_boundary_conditions_get_inlet(const cs_zone_t *zone)
Return pointer to coal boundary conditions inlet structure.
Definition: cs_combustion_boundary_conditions.cpp:140
Inlet definition for gas combustion.
Definition: cs_combustion_boundary_conditions.h:54
int ientfu
Definition: cs_combustion_boundary_conditions.h:59
double tinfue
Definition: cs_combustion_gas.h:240
Open boundary definition
Since it is not yet possible to handle open boundary conditions with backflow conditions with the high level API (i.e. at the setup stage), the following example illustrates have this can be managed, on an example zone named "open":
const auto cvar_vel = CS_F_(vel)->get_val_v();
auto brom = CS_F_(rho_b)->get_val_s();
int *p_icodcl = CS_F_(p)->bc_coeffs->icodcl;
cs_real_t *p_rcodcl1 = CS_F_(p)->bc_coeffs->rcodcl1;
cs_real_t *fm_rcodcl1 = CS_F_(fm)->bc_coeffs->rcodcl1;
cs_real_t *fp2m_rcodcl1 = CS_F_(fp2m)->bc_coeffs->rcodcl1;
cs_real_t *h_rcodcl1 = nullptr;
h_rcodcl1 = CS_F_(h)->bc_coeffs->rcodcl1;
const cs_real_t xdh = 3.0; /* acos(-1.d0) * 1 ( domain circumference) */
const cs_real_t xitur = 0.02; /* turbulence intensity */
/* Loop on zone faces */
const cs_zone_t *z = cs_boundary_zone_by_name("open");
for (cs_lnum_t idx = 0; idx < z->n_elts; idx++) {
const cs_lnum_t face_id = z->elt_ids[idx];
bc_type[face_id] = CS_FREE_INLET;
/* Imposed pressure
* Note: it is expressed directly in term of solved pressure, that is
* p - rho0 g (z-z0).
* That is why it is "-" CS_BC_DIRICHLET
const cs_real_t pimp = 0.;
p_icodcl[face_id] = - CS_BC_DIRICHLET;
p_rcodcl1[face_id] = pimp;
/* Outlet: Neumann conditions by defauls */
if (bmasfl[face_id] > 0)
continue;
/* Inlet (backflow): Dirichlet conditions */
const cs_lnum_t c_id = b_face_cells[face_id];
cs_real_t uref2 = cs_math_3_square_norm(cvar_vel.sub_array(c_id));
uref2 = cs::max(uref2, cs_math_epzero);
cs_turbulence_bc_inlet_turb_intensity(face_id, uref2, xitur, xdh);
/* Mixture fraction */
fm_rcodcl1[face_id] = 0;
/* Variance */
fp2m_rcodcl1[face_id] = 0;
/* Enthalpy */
if (h_rcodcl1 != nullptr)
h_rcodcl1[face_id] = cm->hinoxy;
/* Soot */
if (cm->isoot == 1) {
CS_F_(fsm)->bc_coeffs->rcodcl1[face_id] = 0;
CS_F_(npm)->bc_coeffs->rcodcl1[face_id] = 0;
/* Density */
brom[face_id] = fp->p0/( cs_physical_constants_r
* cm->tinoxy/cm->wmolg[1]);
@ npm
Definition: cs_field_pointer.h:130
@ p
Definition: cs_field_pointer.h:63
@ fp2m
Definition: cs_field_pointer.h:127
@ h
Definition: cs_field_pointer.h:90
@ fsm
Definition: cs_field_pointer.h:129
@ rho_b
@ fm
Definition: cs_field_pointer.h:126
static constexpr cs_real_t cs_math_epzero
Definition: cs_math.h:102
CS_F_HOST_DEVICE T cs_math_3_square_norm(const T v[3])
Compute the square norm of a vector of 3 real values.
Definition: cs_math.h:337
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:506
@ CS_FREE_INLET
Definition: cs_parameters.h:100
const double cs_physical_constants_r
Definition: cs_physical_constants.cpp:438
int cs_glob_physical_model_flag[CS_N_PHYSICAL_MODEL_TYPES]
Definition: cs_physical_model.cpp:104
@ CS_COMBUSTION_3PT
Definition: cs_physical_model.h:54
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Set inlet boundary condition values for turbulence variables based on a diameter ,...
Definition: cs_turbulence_bc.cpp:773
CS_F_HOST_DEVICE T max(const T a, const T b)
Definition: cs_defs.h:735
double wmolg[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
Definition: cs_combustion_gas.h:253
int isoot
Definition: cs_combustion_gas.h:235
double p0
Definition: cs_physical_constants.h:78
const cs_lnum_t * elt_ids
Definition: cs_zone.h:61
cs_lnum_t n_elts
Definition: cs_zone.h:60
