Electric arcs Joule examples
Local variables to be added
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
const cs_real_t *b_face_surf = domain->mesh_quantities->b_face_surf;
const cs_nreal_3_t *b_face_u_normal = domain->mesh_quantities->b_face_u_normal;
Definition: cs_defs.h:332
cs_nreal_t cs_nreal_3_t[3]
Definition: cs_defs.h:375
Definition: cs_defs.h:325
int nbelec = cs_glob_transformer->nbelec;
int nbtrf = cs_glob_transformer->nbtrf;
char name[8];
cs_array<cs_real_t> sir(nbelec);
cs_array<cs_real_t> sii(nbelec);
cs_array<cs_real_t> sirt(nbtrf);
cs_array<cs_real_t> siit(nbtrf);
cs_array_2d<cs_real_t> siib(nbtrf, 6);
cs_array_2d<cs_real_t> sirb(nbtrf, 6);
cs_array_2d<cs_real_t> ui(nbtrf, 6);
cs_array_2d<cs_real_t> ur(nbtrf, 6);
cs_array<int> nborne(nbtrf);
Define a templated array class (owner of data)
Definition: cs_array.h:1118
cs_data_joule_effect_t * cs_get_glob_transformer(void)
Definition: cs_elec_model.cpp:653
const cs_data_joule_effect_t * cs_glob_transformer
Structure to read transformer parameters in dp_ELE.
Definition: cs_elec_model.h:71
int nbtrf
Definition: cs_elec_model.h:77
int nbelec
Definition: cs_elec_model.h:73
Computation of intensity (A/m2) for each electrode
Pre initialization
for (int i = 0; i < nbelec; i++) {
sir[i] = 0.;
sii[i] = 0.;
for (int i = 0; i < nbtrf; i++) {
sirt[i] = 0.;
siit[i] = 0.;
nborne[i] = 0;
transfo->uroff[i] = 0.;
transfo->uioff[i] = 0.;
int nt_prev
Definition: cs_time_step.h:70
int nt_cur
Definition: cs_time_step.h:72
cs_real_t * uioff
Definition: cs_elec_model.h:86
cs_real_t * uroff
Definition: cs_elec_model.h:85
sprintf(name, "%07d", transfo->ielecc[i]);
cs_span_2d<cs_real_t> cpro_curre = CS_F_(curre)->get_val_v();
if (ieljou == 4)
cpro_curim = CS_F_(curim)->get_val_v();
for (cs_lnum_t ilelt = 0; ilelt < z->n_elts; ilelt++) {
cs_lnum_t face_id = z->elt_ids[ilelt];
cs_lnum_t cell_id = b_face_cells[face_id];
for (cs_lnum_t id = 0; id < 3; id++) {
sir[i] += cpro_curre(cell_id, id)
* b_face_u_normal[face_id][id] * b_face_surf[face_id];
if (ieljou == 4) {
sii[i] += cpro_curim(cell_id, id)
Define a templated mdspan class (non owner of data)
Definition: cs_mdspan.h:68
Definition: cs_boundary_zone.cpp:708
@ curre
Definition: cs_field_pointer.h:140
@ curim
Definition: cs_field_pointer.h:141
#define CS_F_(e)
Definition: cs_field_pointer.h:47
int cs_glob_physical_model_flag[CS_N_PHYSICAL_MODEL_TYPES]
Definition: cs_physical_model.cpp:104
@ CS_JOULE_EFFECT
Definition: cs_physical_model.h:59
int * ielecc
Definition: cs_elec_model.h:74
Definition: cs_zone.h:51
const cs_lnum_t * elt_ids
Definition: cs_zone.h:61
cs_lnum_t n_elts
Definition: cs_zone.h:60
Definition of Voltage on each termin of transformers
Computation of Intensity on each termin of transformers:
sirb(transfo->ielect[i], transfo->ielecb[i]) = 0.;
if (ieljou == 4)
siib(transfo->ielect[i], transfo->ielecb[i]) = 0.;
if (transfo->ielect[i] != 0) {
sirb(transfo->ielect[i], transfo->ielecb[i]) += sir[i];
if (ieljou == 4)
siib(transfo->ielect[i], transfo->ielecb[i]) += sii[i];
int * ielect
Definition: cs_elec_model.h:75
int * ielecb
Definition: cs_elec_model.h:76
RVoltage on each termin:
for (int ntf = 0; ntf < nbtrf; ntf++) {
/* Primary and Secondary in Triangle */
if (transfo->ibrpr[ntf] == 0 &&
transfo->ibrsec[ntf] == 0) {
nborne[ntf] = 3;
cs_real_t rnbs2 = 3. * transfo->rnbs[ntf]
* transfo->rnbs[ntf];
ur(ntf, 0) = 1.154675 * transfo->tenspr[ntf]
/ transfo->rnbs[ntf]
+ (transfo->zr[ntf] * sirb(ntf, 0)
- transfo->zi[ntf] * siib(ntf, 0)) / rnbs2;
ur(ntf, 1) = -0.5773 * transfo->tenspr[ntf]
+ (transfo->zr[ntf] * sirb(ntf, 1)
- transfo->zi[ntf] * siib(ntf, 1)) / rnbs2;
ur(ntf, 2) =-0.5773 * transfo->tenspr[ntf]
+ (transfo->zr[ntf] * sirb(ntf, 2)
- transfo->zi[ntf] * siib(ntf, 2)) / rnbs2;
ui(ntf, 0) = (transfo->zi[ntf] * sirb(ntf, 0)
- transfo->zr[ntf] * siib(ntf, 0)) / rnbs2;
ui(ntf, 1) = (transfo->zi[ntf] * sirb(ntf, 1)
- transfo->zr[ntf] * siib(ntf, 1)) / rnbs2;
ui(ntf, 2) = (transfo->zi[ntf] * sirb(ntf, 2)
- transfo->zr[ntf] * siib(ntf, 2)) / rnbs2;
else
bft_error(__FILE__, __LINE__, 0,
_("electric module : \n"
"transformer matrix not defined\n"));
Definition: bft_error.cpp:187
#define _(String)
Definition: cs_defs.h:61
cs_real_t * zi
Definition: cs_elec_model.h:84
cs_real_t * rnbs
Definition: cs_elec_model.h:82
int * ibrpr
Definition: cs_elec_model.h:79
cs_real_t * tenspr
Definition: cs_elec_model.h:81
cs_real_t * zr
Definition: cs_elec_model.h:83
int * ibrsec
Definition: cs_elec_model.h:80
Total intensity for a transformer (zero valued WHEN Offset established):
sirt[ntf] = 0.;
if (ieljou == 4)
siit[ntf] = 0.;
sirt[i] += sir[i];
if (ieljou == 4)
siit[i] += sii[i];
Take in account of Offset:
cs_real_t capaeq = 3.;
transfo->uroff[ntf] += sirt[ntf] / capaeq;
if (ieljou == 4)
transfo->uioff[ntf] += siit[ntf] / capaeq;
/* A reference transformer is assumed to have an Offset zero valued */
if (transfo->ntfref > 0) {
transfo->uroff[transfo->ntfref] = 0.;
transfo->uioff[transfo->ntfref] = 0.;
for (int nb = 0; nb < nborne[ntf]; nb++) {
ur(ntf, nb) += transfo->uroff[ntf];
if (ieljou == 4)
ui(ntf, nb) += transfo->uioff[ntf];
/* Print of UROFF (real part of offset potential) */
bft_printf(" ** INFORMATION ON TRANSFORMERS\n"
" ---------------------------------------\n"
"\n"
" ---------------------------------\n"
" Number of Transformers UROFF\n"
" ---------------------------------\n");
bft_printf(" %6i %12.5E\n", ntf, transfo->uroff[ntf]);
bft_printf(" ---------------------------------------\n");
Definition: bft_printf.cpp:134
int ntfref
Definition: cs_elec_model.h:78
Take in account of Boundary Conditions
int *potr_icodcl = CS_F_(potr)->bc_coeffs->icodcl;
cs_real_t *potr_rcodcl1 = CS_F_(potr)->bc_coeffs->rcodcl1;
cs_real_t *potr_rcodcl3 = CS_F_(potr)->bc_coeffs->rcodcl3;
int *poti_icodcl = nullptr;
cs_real_t *poti_rcodcl1 = nullptr;
cs_real_t *poti_rcodcl3 = nullptr;
if (ieljou == 4) {
poti_icodcl = CS_F_(potr)->bc_coeffs->icodcl;
poti_rcodcl1 = CS_F_(potr)->bc_coeffs->rcodcl1;
poti_rcodcl3 = CS_F_(potr)->bc_coeffs->rcodcl3;
bc_type[face_id] = CS_SMOOTHWALL;
potr_icodcl[face_id] = CS_BC_DIRICHLET;
potr_rcodcl1[face_id] = ur(transfo->ielect[i], transfo->ielecb[i]);
if (ieljou == 4) {
poti_icodcl[face_id] = CS_BC_DIRICHLET;
poti_rcodcl1[face_id] = ur(transfo->ielect[i], transfo->ielecb[i]);
else {
potr_icodcl[face_id] = CS_BC_NEUMANN;
potr_rcodcl3[face_id] = 0.;
if (ieljou == 4) {
poti_icodcl[face_id] = CS_BC_NEUMANN;
poti_rcodcl3[face_id] = 0.;
/* Test, if not any reference transformer
* a piece of wall may be at ground. */
if (transfo->ntfref == 0) {
int found = 0;
for (cs_lnum_t face_id = 0; face_id < n_b_faces; face_id++) {
if (bc_type[face_id] == CS_SMOOTHWALL) {
if (potr_icodcl[face_id] == CS_BC_DIRICHLET) {
if (ieljou == 3) {
if (fabs(potr_rcodcl1[face_id]) < 1.e-20)
found = 1;
else if (ieljou == 4) {
cs_real_t val = fabs(potr_rcodcl1[face_id]);
if (fabs(poti_rcodcl1[face_id]) < 1.e-20 && val < 1.e-20)
found = 1;
if (!found)
_("ERROR in JOULE : \n"
"Lack of reference: choose a transformer for which\n"
"offset is assumed zero or a face at ground on the\n"
"boundary."));
#define CS_INT_TYPE
Definition: cs_defs.h:465
@ potr
Definition: cs_field_pointer.h:133
static void cs_parall_max(int n, cs_datatype_t datatype, void *val)
Maximum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:171
@ CS_BC_NEUMANN
Definition: cs_param_types.h:511
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:506
@ CS_SMOOTHWALL
Definition: cs_parameters.h:87
