Data setting for drift scalars
Introduction
This page provides an example of code blocks that may be used to perform a calculation with drift scalars.
Physical properties
Local variables to be added
The following local variables and associated initializations need to be defined for the examples in this section:
auto cpro_viscl = CS_F_(mu)->get_val_s();
/* Key id for drift scalar */
const int keydri = cs_field_key_id("drift_scalar_model");
/* Key id for diffusivity id */
const int kivisl = cs_field_key_id("diffusivity_id");
/* Number of fields */
const int nfld = cs_field_n_fields();
Definition: cs_defs.h:325
int cs_field_n_fields(void)
Definition: cs_field.cpp:1505
Definition: cs_field.cpp:2728
@ mu
Definition: cs_field_pointer.h:102
#define CS_F_(e)
Definition: cs_field_pointer.h:47
Body
This example sets the scalar laminar dynamic diffusivity (for Brownian motion) to take thermophoresis into account.
/* Loop over fields which are scalar with a drift */
for (int iflid = 0; iflid < nfld; iflid++) {
cs_field_t *f = cs_field(iflid);
if (! (f->type & CS_FIELD_VARIABLE))
continue;
int drift_flag = f->get_key_int(keydri);
if (drift_flag & CS_DRIFT_SCALAR_ADD_DRIFT_FLUX) {
/* Position of variables, coefficients
cs_span<cs_real_t> cpro_taup;
cs_span<cs_real_t> cpro_taufpt;
cs_span<cs_real_t> cpro_viscls;
/* Scalar's diffusivity (Brownian motion) */
int ifcvsl = f->get_key_int(kivisl);
if (ifcvsl > -1)
cpro_viscls = cs_field(ifcvsl)->get_val_s();
/* Coefficients of drift scalar CHOSEN BY THE USER
Values given here are fictitious */
const cs_real_t diamp = 1.e-4; /* particle diameter */
const cs_real_t cuning = 1.; /* Cuningham correction factor */
const cs_real_t rhop = 1.e4; /* particle density */
/* Get corresponding relaxation time (cpro_taup) */
cpro_taup = cs_field_by_composite_name(f->name, "drift_tau")->get_val_s();
/* Corresponding interaction time particle--eddies */
if (drift_flag & CS_DRIFT_SCALAR_TURBOPHORESIS) {
cpro_taufpt = cs_field_by_composite_name(f->name, "drift_turb_tau")->get_val_s();
/* Computation of the relaxation time of the particles
const cs_real_t diamp2 = cs_math_pow2(diamp);
if (diamp <= 1.e-6) {
/* Cuningham's correction for submicronic particles */
for (cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
cpro_taup[c_id] = cuning*diamp2*rhop / (18.*cpro_viscl[c_id]);
else {
cpro_taup[c_id] = diamp2*rhop / (18.*cpro_viscl[c_id]);
/* Compute the interaction time particle--eddies (tau_fpt)
const int ksigmas = cs_field_key_id("turbulent_schmidt");
/* k-epsilon or v2-f models */
if (t_mdl->itytur == 2 || t_mdl->itytur == 5) {
const auto cvar_k = CS_F_(k)->get_val_s();
const auto cvar_eps = CS_F_(eps)->get_val_s();
const cs_real_t turb_schmidt = f->get_key_double(ksigmas);
cs_real_t xk = cvar_k[c_id];
cs_real_t xeps = cvar_eps[c_id];
cpro_taufpt[c_id] = (3./2.)*(cs_turb_cmu/turb_schmidt)*xk/xeps;
/* Rij-epsilon models */
else if (t_mdl->itytur == 3) {
const auto cvar_rij = CS_F_(rij)->get_val_t();
cs_real_t beta1 = 0.5 + 3.0/(4.*cs_turb_xkappa);
cs_real_t xk = 0.5 * ( cvar_rij(c_id, 0)
+ cvar_rij(c_id, 1)
+ cvar_rij(c_id, 2));
cpro_taufpt[c_id] = xk/xeps/beta1;
/* k-omega models */
if (t_mdl->itytur == 6) {
const auto cvar_omg = CS_F_(omg)->get_val_s();
cs_real_t xomg = cvar_omg[c_id];
cpro_taufpt[c_id] = (3./2.)*(1./turb_schmidt)/xomg;
/* Brownian diffusion at cell centers
/* Stop if the diffusivity is not variable */
if (ifcvsl < 0)
bft_error(__FILE__, __LINE__, 0,
"The diffusivity is uniform while a variable diffusivity\n"
"is computed.");
/* Temperature and density */
if (CS_F_(t) == nullptr)
"The temperature field on which physical properties depend\n"
"does not seem to be present.");
const auto cvar_t = CS_F_(t)->get_val_s();
const auto cpro_rom = CS_F_(rho)->get_val_s();
/* Homogeneous to a dynamic viscosity */
cs_real_t xvart = cvar_t[c_id];
cs_real_t rho = cpro_rom[c_id];
cs_real_t viscl = cpro_viscl[c_id];
cpro_viscls[c_id] = rho*cs_physical_constants_kb*xvart
* cuning/(3.*cs_math_pi*diamp*viscl);
} /* End of test on drift */
} /* End of loop on fields */
Definition: bft_error.cpp:187
Define a templated mdspan class (non owner of data)
Definition: cs_mdspan.h:68
Definition: cs_field.h:275
int get_key_int(int key_id) const
Definition: cs_field.cpp:4507
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
int type
Definition: cs_field.h:282
double get_key_double(int key_id) const
Return a floating point value for a given key associated with a field.
Definition: cs_field.cpp:4745
const char * name
Definition: cs_field.h:279
Definition: cs_defs.h:332
cs_field_t * cs_field_by_composite_name(const char *name_prefix, const char *name_suffix)
Return a pointer to a field based on a composite name.
Definition: cs_field.cpp:2486
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
@ t
Definition: cs_field_pointer.h:91
@ k
@ eps
Definition: cs_field_pointer.h:69
@ omg
Definition: cs_field_pointer.h:78
@ rho
Definition: cs_field_pointer.h:96
@ rij
Definition: cs_field_pointer.h:71
CS_F_HOST_DEVICE cs_real_t cs_math_pow2(cs_real_t x)
Definition: cs_math.h:902
static constexpr cs_real_t cs_math_pi
Definition: cs_math.h:111
@ CS_DRIFT_SCALAR_ADD_DRIFT_FLUX
Definition: cs_parameters.h:118
@ CS_DRIFT_SCALAR_TURBOPHORESIS
Definition: cs_parameters.h:120
const double cs_physical_constants_kb
Definition: cs_physical_constants.cpp:442
double cs_turb_cmu
Definition: cs_turbulence_model.cpp:484
double cs_turb_xkappa
Definition: cs_turbulence_model.cpp:422
const cs_turb_model_t * cs_glob_turb_model
#define CS_FIELD_VARIABLE
Definition: cs_field.h:66
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:126
int itytur
Definition: cs_turbulence_model.h:169
