This page provides an example that may be used or adapted to perform extra or advanced extra-operations within the Lagrangian module.
cs_real_t zz[4] = {0.1e0, 0.15e0, 0.20e0, 0.25e0};
for (
cs_lnum_t iplan = 0; iplan < 4; iplan++)
_m_flow[iplan] = 0.0;
for (
cs_lnum_t iplan = 0; iplan < 4; iplan++) {
if ( part_coords[0] > zz[iplan]
&& prev_part_coords[0] <= zz[iplan])
for (int iplan = 0; iplan < 4; iplan++)
bft_printf(
" Particle mass flow at Z(%d): %e14.5)",
iplan,
_m_flow[iplan]/stat_age);
Definition: bft_printf.cpp:134
int nt_cur
Definition: cs_time_step.h:72
Definition: cs_defs.h:332
Definition: cs_defs.h:325
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
@ CS_LAGR_MASS
Definition: cs_lagr_particle.h:89
@ CS_LAGR_STAT_WEIGHT
Definition: cs_lagr_particle.h:87
@ CS_LAGR_COORDS
Definition: cs_lagr_particle.h:92
cs_real_t cs_lagr_stat_get_age(void)
Return global volume statistics age.
Definition: cs_lagr_stat.cpp:5957
cs_lagr_stat_options_t * cs_glob_lagr_stat_options
auto attr_real_const_ptr(Args &&... args) -> decltype(attr_get_const_ptr< cs_real_t >(std::forward< Args >(args)...))
Definition: cs_lagr_particle.h:835
auto attr_real(Args &&... args) -> decltype(attr< cs_real_t >(std::forward< Args >(args)...))
Definition: cs_lagr_particle.h:763
cs_lnum_t n_particles
Definition: cs_lagr_particle.h:326
auto attr_n_real_const_ptr(Args &&... args) -> decltype(attr_n_get_const_ptr< cs_real_t >(std::forward< Args >(args)...))
Definition: cs_lagr_particle.h:883
int nstist
Definition: cs_lagr_stat.h:211
int isttio
Definition: cs_lagr.h:210
