cs_lagr_stat_options_t Struct Reference
#include <cs_lagr_stat.h>
+ Collaboration diagram for cs_lagr_stat_options_t:
Public Attributes
int isuist
int idstnt
int nstist
cs_real_t threshold
Structure defining Lagrangian statistics options
Member Data Documentation
◆ idstnt
int idstnt
absolute time step number (including the restarts) after which the calculation of the volume statistics is activated.
◆ isuist
int isuist
during a Lagrangian calculation restart, indicates whether the particle statistics (volume and boundary) and two-way coupling terms are to be read from a restart file (=1) or reinitialized (=0). Useful if isuila = 1
◆ nstist
int nstist
absolute time step number (includings the restarts) after which the volume statistics are cumulated over time (they are then said to be steady). if the absolute time step number is lower than nstist, or if the flow is unsteady (isttio=0), the statistics are reset to zero at every time step (the volume statistics are then said to be non-steady). Useful if isttio = 1
◆ threshold
cs_real_t threshold
threshold for statistical meaning when used by other model features (such as the Poisson correction)
