cs_sles_cudss.cpp File Reference
handling of cuDSS-based linear solvers More...
#include <stdarg.h>
#include <mpi.h>
#include <cudss.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_dispatch.h"
#include "base/cs_log.h"
#include "base/cs_fp_exception.h"
#include "base/cs_halo.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_default.h"
#include "base/cs_timer.h"
#include "alge/cs_sles.h"
#include "alge/cs_sles_cudss.h"
+ Include dependency graph for cs_sles_cudss.cpp:
cs_sles_cudss_t * cs_sles_cudss_define (int f_id, const char *name)
 Define and associate an cuDSS linear system solver for a given field or equation name. More...
cs_sles_cudss_t * cs_sles_cudss_create (void)
 Create cuDSS linear system solver info and context. More...
void * cs_sles_cudss_copy (const void *context)
 Create cuDSS linear system solver info and context based on existing info and context. More...
void cs_sles_cudss_destroy (void **context)
 Destroy cuDSS linear system solver info and context. More...
void cs_sles_cudss_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup cuDSS linear equation solver. More...
cs_sles_convergence_state_t cs_sles_cudss_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call cuDSS linear equation solver. More...
void cs_sles_cudss_free (void *context)
 Free cuDSS linear equation solver setup context. More...
void cs_sles_cudss_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
void cs_sles_cudss_library_info (cs_log_t log_type)
 Print information on cuDSS library. More...
void cs_sles_cudss_set_mpi_comm (cs_sles_cudss_t *context, MPI_Comm comm)
 Set MPI communicator for cuDSS solver. More...
◆ cs_sles_cudss_copy()
void * cs_sles_cudss_copy ( const void *  context)
Most configuration parameters will be copied from the existing context, though not all, since cuDSS does not provide a comprehensive way to do this.
[in]contextpointer to reference info and context (actual type: cs_sles_cudss_t *)
pointer to newly created solver info object. (actual type: cs_sles_cudss_t *)
◆ cs_sles_cudss_create()
cs_sles_cudss_t * cs_sles_cudss_create ( void  )
pointer to associated linear system object.
◆ cs_sles_cudss_define()
cs_sles_cudss_t * cs_sles_cudss_define ( int  f_id,
const char *  name
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_cudss_create.
[in]nameassociated name if f_id < 0, or nullptr
pointer to newly created cuDSS solver info object.
◆ cs_sles_cudss_destroy()
void cs_sles_cudss_destroy ( void **  context)
[in,out]contextpointer to cuDSS solver info and context (actual type: cs_sles_cudss_t **)
◆ cs_sles_cudss_free()
void cs_sles_cudss_free ( void *  context)
[in,out]contextpointer to cuDSS solver info and context (actual type: cs_sles_cudss_t *)
◆ cs_sles_cudss_library_info()
void cs_sles_cudss_library_info ( cs_log_t  log_type)
[in]log_typelog type
◆ cs_sles_cudss_log()
void cs_sles_cudss_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to cuDSS solver info and context (actual type: cs_sles_cudss_t *)
◆ cs_sles_cudss_set_mpi_comm()
void cs_sles_cudss_set_mpi_comm ( cs_sles_cudss_t *  context,
MPI_Comm  comm
The system is solved only on ranks with a non-null communicator or if the associated communicator has less than 2 ranks.
[in,out]contextpointer to solver info and context
[in]commMPI communicator for solving
◆ cs_sles_cudss_setup()
void cs_sles_cudss_setup ( void *  context,
const char *  name,
const cs_matrix_t *  a,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_cudss_solve()
cs_sles_convergence_state_t cs_sles_cudss_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
const cs_real_t *  rhs,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
Warning
The precision, r_norm, and n_iter parameters are ignored here. the matching configuration options should be set earlier, using the cs_sles_cudss_set_config function
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]rhsright hand side
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
