cs_param_amg_inhouse_t Struct Reference
Set of the main parameters used to setup the algebraic multigrid available natively in code_saturne (in-house implementations). These parameters are the most impacting ones. For a more advanced usage, this is still possible to consider the function cs_user_linear_solvers. More...
#include <cs_param_amg.h>
+ Collaboration diagram for cs_param_amg_inhouse_t:
Public Attributes
int max_levels
cs_gnum_t min_n_g_rows
double p0p1_relax
int aggreg_limit
cs_param_amg_inhouse_coarsen_t coarsen_algo
int n_down_iter
cs_param_amg_inhouse_solver_t down_smoother
int down_poly_degree
int n_up_iter
cs_param_amg_inhouse_solver_t up_smoother
int up_poly_degree
double coarse_rtol_mult
int coarse_max_iter
cs_param_amg_inhouse_solver_t coarse_solver
int coarse_poly_degree
Member Data Documentation
◆ aggreg_limit
int aggreg_limit
◆ coarse_max_iter
int coarse_max_iter
◆ coarse_poly_degree
◆ coarse_rtol_mult
◆ coarse_solver
◆ coarsen_algo
◆ down_poly_degree
◆ down_smoother
◆ max_levels
int max_levels
◆ min_n_g_rows
◆ n_down_iter
int n_down_iter
◆ n_up_iter
int n_up_iter
◆ p0p1_relax
double p0p1_relax
◆ up_poly_degree
int up_poly_degree
◆ up_smoother
