cs::parall Namespace Reference
template<typename T , typename... Vals, typename std::enable_if<!std::is_array< T >::value, int >::type = 0>
static void sum (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Sum values of a given datatype over a given communicator. More...
static void sum (T &first, Vals &...values)
 Sum values of a given datatype on all default communicator processes. More...
template<int Stride, typename T , typename... Vals>
static void sum (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
 Sum strided-values of a given datatype over a communicator. More...
static void sum (T first[], Vals &&... values)
 Sum strided-values of a given datatype on all default communicator processes. More...
template<typename T , int N, typename... Vals>
static void sum (T(&first)[N], Vals &&...values)
 Sum values of a fixed-size C array over the default communicator. More...
static void sum (const cs_mpi_wrapper &mpi_w, T(&first)[N], Vals &&... values)
template<typename T , typename... Vals>
static void max (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Maximum values of a given datatype on a given communicator processes. More...
static void max (T &first, Vals &... values)
 Maximum values of a given datatype on all default communicator processes. More...
static void max (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void max (T first[], Vals &&... values)
static void min (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Minimum values of a given datatype on a given communicator processes. More...
static void min (T &first, Vals &... values)
 Minimum values of a given datatype on all default communicator processes. More...
static void min (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void min (T first[], Vals &&... values)
◆ max() [1/4]
static void max ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
[in]mpi_wParallel execution context
[in,out]firstFirst scalar to update
[in,out]valuesAdditional scalars to update
◆ max() [2/4]
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
stride: stride/dimension of values
◆ max() [3/4]
static void max ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ max() [4/4]
static void max ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ min() [1/4]
static void min ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ min() [2/4]
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
[in,out]firstFirst value to update
[in,out]valuesAdditional values to update
◆ min() [3/4]
static void min ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ min() [4/4]
static void min ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ sum() [1/6]
static void sum ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
[in,out]valuesScalar values to update
◆ sum() [2/6]
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
[in,out]valuesValues to update
◆ sum() [3/6]
T(&)  first[N],
Vals &&...  values
static
This overload detects the size of fixed-array.
Template Parameters
T: datatype
N: dimension of the array
[in,out]firstFirst array to update
[in,out]valuesAdditional arrays to update
◆ sum() [4/6]
static void sum ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ sum() [5/6]
static void sum ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ sum() [6/6]
static void sum ( T(&)  first[N],
Vals &&...  values
static
Template Parameters
T: datatype
