cs_macfb_advection.cpp File Reference
Build discrete advection operators for MAC face-based schemes. More...
#include <cassert>
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_flag.h"
#include "cdo/cs_macfb_builder.h"
#include "cdo/cs_property.h"
#include "cdo/cs_scheme_geometry.h"
#include "cdo/cs_macfb_advection.h"
+ Include dependency graph for cs_macfb_advection.cpp:
void cs_macfb_advection_open_default (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
 Perform preprocessing such as the computation of the advection flux at the expected location in order to be able to build the advection matrix. Follow the prototype given by cs_macfb_adv_open_hook_t Default case. More...
void cs_macfb_advection_close_default_vect (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_macfb_adv_close_hook_t Default vector-valued case. More...
void cs_macfb_advection_close_exp_none_vect (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_macfb_adv_close_hook_t Explicit treatment without extrapolation for vector-valued DoFs. More...
void cs_macfb_advection_no_diffusion (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_macfb_adv_scheme_t *scheme_func, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Build the cellwise advection operator for MAC-Fb schemes The local matrix related to this operator is stored in cb->loc. More...
void cs_macfb_advection (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_macfb_adv_scheme_t *scheme_func, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Main function to build the cellwise advection operator for MAC face-based schemes. The local matrix related to this operator is stored in cb->loc. More...
void cs_macfb_advection_upwnoc (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_builder_t *cb, cs_sdm_t *adv, cs_real_t *rhs)
 Compute the convection operator attached to a cell with a MAC face-based scheme. More...
void cs_macfb_advection_upwcsv (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_builder_t *cb, cs_sdm_t *adv, cs_real_t *rhs)
void cs_macfb_advection_cennoc (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_builder_t *cb, cs_sdm_t *adv, cs_real_t *rhs)
void cs_macfb_advection_cencsv (const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_builder_t *cb, cs_sdm_t *adv, cs_real_t *rhs)
◆ cs_macfb_advection()
void cs_macfb_advection ( const cs_equation_param_t *  eqp,
const cs_cell_mesh_t *  cm,
const cs_macfb_builder_t *  macb,
cs_macfb_adv_scheme_t *  scheme_func,
cs_cell_sys_t *  csys,
cs_cell_builder_t *  cb
One assumes that a diffusion term is present so that there is no need to perform additional checkings on the well-posedness of the operator.
[in]macbpointer to a cs_macfb_builder_t structure
[in]scheme_funcpointer to the function building the system
◆ cs_macfb_advection_cencsv()
void cs_macfb_advection_cencsv ( const cs_cell_mesh_t *  cm,
cs_cell_builder_t *  cb,
cs_sdm_t *  adv,
cs_real_t *  rhs
  • conservative formulation $ \vec{beta} \cdot \nabla u $
  • centered scheme
[in]cbpointer to a cs_cell_builder_t structure
[in,out]advpointer to a local matrix to build
[in,out]rhspointer to a cs_real_t array. It is filled inside the function. Have to preallocated.
◆ cs_macfb_advection_cennoc()
void cs_macfb_advection_cennoc ( const cs_cell_mesh_t *  cm,
cs_sdm_t *  adv,
cs_real_t *  rhs
  • non-conservative formulation $ \vec{beta} \cdot \nabla u $
  • centered scheme
◆ cs_macfb_advection_close_default_vect()
void cs_macfb_advection_close_default_vect ( const cs_cell_mesh_t *  cm,
const cs_cell_builder_t *  cb,
[in,out]csyspointer to a cs_cell_sys_t structure
◆ cs_macfb_advection_close_exp_none_vect()
void cs_macfb_advection_close_exp_none_vect ( const cs_cell_mesh_t *  cm,
◆ cs_macfb_advection_no_diffusion()
void cs_macfb_advection_no_diffusion ( const cs_equation_param_t *  eqp,
Main function to build the cellwise advection operator for MAC-Fb schemes The local matrix related to this operator is stored in cb->loc.
Case of an advection term without a diffusion operator. In this situation, a numerical issue may arise if an internal or a border face is such that there is no advective flux. A special treatment is performed to tackle this issue.
◆ cs_macfb_advection_open_default()
void cs_macfb_advection_open_default ( const cs_equation_param_t *  eqp,
const cs_cell_sys_t *  csys,
void *  input,
[in]csyspointer to a cs_cell_sys_t structure
[in,out]inputnullptr or pointer to a structure cast on-the-fly
◆ cs_macfb_advection_upwcsv()
void cs_macfb_advection_upwcsv ( const cs_cell_mesh_t *  cm,
cs_sdm_t *  adv,
cs_real_t *  rhs
  • upwind scheme
◆ cs_macfb_advection_upwnoc()
void cs_macfb_advection_upwnoc ( const cs_cell_mesh_t *  cm,
cs_sdm_t *  adv,
cs_real_t *  rhs
  • upwind scheme
