cs_lagr_extract.h
1#ifndef CS_LAGR_EXTRACT_H
2#define CS_LAGR_EXTRACT_H
5 * Extract information from lagrangian particles.
35 * Local headers
38#include "fvm/fvm_nodal.h"
39#include "fvm/fvm_writer.h"
41#include "base/cs_base.h"
43#include "base/cs_time_step.h"
45/*----------------------------------------------------------------------------*/
46
48
50 * Macro definitions
52
53/*============================================================================
54 * Local type definitions
55 *============================================================================*/
56
57/*=============================================================================
58 * Global variables
59 *============================================================================*/
60
61/*============================================================================
62 * Public function prototypes
63 *============================================================================*/
64
65/*----------------------------------------------------------------------------
66 * Get the local number of particles.
67 *
68 * returns:
69 * current number of particles.
70 *----------------------------------------------------------------------------*/
71
74
75/*----------------------------------------------------------------------------
76 * Extract a list of particles using an optional cell filter and
77 * statistical density filter.
78 *
79 * The output array must have been allocated by the caller and be of
80 * sufficient size.
81 *
82 * parameters:
83 * n_cells <-- number of cells in filter
84 * cell_list <-- optional list of containing cells filter
85 * density <-- if < 1, fraction of particles to select
86 * n_particles --> number of selected particles, or NULL
87 * particle_list --> particle_list (1 to n numbering), or NULL
88 *----------------------------------------------------------------------------*/
89
90void
92 const cs_lnum_t cell_list[],
93 double density,
94 cs_lnum_t *n_particles,
95 cs_lnum_t *particle_list);
96
97/*----------------------------------------------------------------------------
98 * Extract values for a set of particles.
99 *
100 * The output array must have been allocated by the caller and be of
101 * sufficient size.
102 *
103 * parameters:
104 * particle_set <-- associated particle set
105 * attr <-- attribute whose values are required
106 * datatype <-- associated value type
107 * stride <-- number of values per particle
108 * component_id <-- if -1 : extract the whole attribute
109 * if >0 : id of the component to extract
110 * n_particles <-- number of particles in filter
111 * particle_list <-- particle_list (0 to n-1 numbering), or NULL
112 * values --> particle values for given attribute
113 *
114 * returns:
115 * 0 in case of success, 1 if attribute is not present
116 *----------------------------------------------------------------------------*/
117
118int
121 cs_datatype_t datatype,
122 int stride,
123 int component_id,
124 cs_lnum_t n_particles,
125 const cs_lnum_t particle_list[],
126 void *values);
127
128/*----------------------------------------------------------------------------
129 * Extract trajectory values for a set of particles.
130 *
131 * Trajectories are defined as a mesh of segments, whose start and end
132 * points are copied in an interleaved manner in the segment_values array
133 * (p1_old, p1_new, p2_old, p2_new, ... pn_old, pn_new).
134 *
135 * The output array must have been allocated by the caller and be of
136 * sufficient size.
137 *
138 * parameters:
139 * particles <-- associated particle set
140 * attr <-- attribute whose values are required
141 * datatype <-- associated value type
142 * stride <-- number of values per particle
143 * component_id <-- if -1 : extract the whole attribute
144 * if >0 : id of the component to extract
145 * n_particles <-- number of particles in filter
146 * particle_list <-- particle_list (0 to n-1 numbering), or NULL
147 * segment_values --> particle segment values
148 *
149 * returns:
150 * 0 in case of success, 1 if attribute is not present
151 *----------------------------------------------------------------------------*/
152
153int
156 cs_datatype_t datatype,
157 int stride,
158 int component_id,
159 cs_lnum_t n_particles,
160 const cs_lnum_t particle_list[],
161 void *segment_values);
162
163/*----------------------------------------------------------------------------*/
164
166
167#endif /* CS_LAGR_EXTRACT_H */
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_defs.h:325
int cs_lagr_get_particle_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *values)
Definition: cs_lagr_extract.cpp:255
int cs_lagr_get_trajectory_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *segment_values)
Definition: cs_lagr_extract.cpp:357
void cs_lagr_get_particle_list(cs_lnum_t n_cells, const cs_lnum_t cell_list[], double density, cs_lnum_t *n_particles, cs_lnum_t *particle_list)
Extract a list of particles using an optional cell filter and statistical density filter.
Definition: cs_lagr_extract.cpp:129
cs_lnum_t cs_lagr_get_n_particles(void)
Definition: cs_lagr_extract.cpp:101
cs_lagr_attribute_t
Definition: cs_lagr_particle.h:76
Definition: cs_lagr_particle.h:324
