cs_lagr_physico_chemical_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_physico_chemical_t:
Public Attributes
cs_real_t cstham
cs_real_t lambda_vdw
cs_real_t epseau
cs_real_t phi_p
cs_real_t phi_s
cs_real_t valen
cs_real_t fion
Physical and chemical model parameters
Member Data Documentation
◆ cstham
cs_real_t cstham
Hamaker constant for the particle/fluid/substrate system
◆ epseau
cs_real_t epseau
Dielectric constant of the fluid
◆ fion
cs_real_t fion
Ionic force
◆ lambda_vdw
Retardation wavelength for VDW forces for the particle/fluid/substrate system
◆ phi_p
cs_real_t phi_p
Electrokinetic potential of the first solid - particle
◆ phi_s
cs_real_t phi_s
Electrokinetic potential of the second solid - surface
◆ valen
cs_real_t valen
Valence of ions in the solution (used for EDL forces)
