cs_join_mesh.h File Reference
#include "fvm/fvm_defs.h"
#include "base/cs_base.h"
#include "mesh/cs_join_util.h"
+ Include dependency graph for cs_join_mesh.h:
cs_join_mesh_t * cs_join_mesh_create (const char *name)
cs_join_mesh_t * cs_join_mesh_create_from_glob_sel (const char *mesh_name, cs_lnum_t n_elts, const cs_gnum_t glob_sel[], const cs_gnum_t gnum_rank_index[], const cs_join_mesh_t *local_mesh)
cs_join_mesh_t * cs_join_mesh_create_from_subset (const char *mesh_name, cs_lnum_t subset_size, const cs_lnum_t selection[], const cs_join_mesh_t *parent_mesh)
cs_join_mesh_t * cs_join_mesh_create_from_select (const char *name, const cs_join_param_t param, cs_join_select_t *selection, const cs_lnum_t b_f2v_idx[], const cs_lnum_t b_f2v_lst[], const cs_lnum_t i_f2v_idx[], const cs_lnum_t i_f2v_lst[], const cs_lnum_t n_vertices, const cs_real_t vtx_coord[], const cs_gnum_t vtx_gnum[])
void cs_join_mesh_destroy (cs_join_mesh_t **mesh)
void cs_join_mesh_reset (cs_join_mesh_t *mesh)
void cs_join_mesh_copy (cs_join_mesh_t **mesh, const cs_join_mesh_t *ref_mesh)
void cs_join_mesh_minmax_tol (cs_join_param_t param, cs_join_mesh_t *mesh)
void cs_join_mesh_exchange (cs_lnum_t n_send, const int send_rank[], const cs_lnum_t send_faces[], const cs_join_mesh_t *send_mesh, cs_join_mesh_t *recv_mesh, MPI_Comm comm)
void cs_join_mesh_destroy_edges (cs_join_edges_t **edges)
void cs_join_mesh_face_order (cs_join_mesh_t *mesh)
void cs_join_mesh_sync_vertices (cs_join_mesh_t *mesh)
void cs_join_mesh_vertex_clean (cs_join_mesh_t *mesh)
void cs_join_mesh_clean (cs_join_mesh_t *mesh, int verbosity)
cs_join_edges_t * cs_join_mesh_define_edges (const cs_join_mesh_t *mesh)
cs_lnum_t cs_join_mesh_get_edge (cs_lnum_t v1_num, cs_lnum_t v2_num, const cs_join_edges_t *edges)
void cs_join_mesh_update (cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_lnum_t edge_index[], const cs_lnum_t edge_new_vtx_lst[], cs_lnum_t n_new_vertices, const cs_lnum_t old2new[])
cs_real_t * cs_join_mesh_get_face_normal (const cs_join_mesh_t *mesh)
void cs_join_mesh_get_edge_face_adj (const cs_join_mesh_t *mesh, const cs_join_edges_t *edges, cs_lnum_t *edge_face_idx[], cs_lnum_t *edge_face_lst[])
void cs_join_mesh_dump_vertex (FILE *f, const cs_join_vertex_t vertex)
void cs_join_mesh_dump (FILE *f, const cs_join_mesh_t *mesh)
void cs_join_mesh_dump_edges (FILE *f, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh)
◆ cs_join_mesh_clean()
void cs_join_mesh_clean ( cs_join_mesh_t *  mesh,
int  verbosity
◆ cs_join_mesh_copy()
void cs_join_mesh_copy ( cs_join_mesh_t **  mesh,
const cs_join_mesh_t *  ref_mesh
◆ cs_join_mesh_create()
cs_join_mesh_t * cs_join_mesh_create ( const char *  name)
◆ cs_join_mesh_create_from_glob_sel()
cs_join_mesh_t * cs_join_mesh_create_from_glob_sel ( const char *  mesh_name,
cs_lnum_t  n_elts,
const cs_join_mesh_t *  local_mesh
◆ cs_join_mesh_create_from_select()
cs_join_mesh_t * cs_join_mesh_create_from_select ( const char *  name,
cs_join_select_t *  selection,
◆ cs_join_mesh_create_from_subset()
cs_join_mesh_t * cs_join_mesh_create_from_subset ( const char *  mesh_name,
const cs_join_mesh_t *  parent_mesh
◆ cs_join_mesh_define_edges()
cs_join_edges_t * cs_join_mesh_define_edges ( const cs_join_mesh_t *  mesh)
◆ cs_join_mesh_destroy()
void cs_join_mesh_destroy ( cs_join_mesh_t **  mesh)
◆ cs_join_mesh_destroy_edges()
void cs_join_mesh_destroy_edges ( cs_join_edges_t **  edges)
◆ cs_join_mesh_dump()
void cs_join_mesh_dump ( FILE *  f,
◆ cs_join_mesh_dump_edges()
void cs_join_mesh_dump_edges ( FILE *  f,
const cs_join_edges_t *  edges,
◆ cs_join_mesh_dump_vertex()
void cs_join_mesh_dump_vertex ( FILE *  f,
◆ cs_join_mesh_exchange()
void cs_join_mesh_exchange ( cs_lnum_t  n_send,
const cs_join_mesh_t *  send_mesh,
cs_join_mesh_t *  recv_mesh,
MPI_Comm  comm
◆ cs_join_mesh_face_order()
void cs_join_mesh_face_order ( cs_join_mesh_t *  mesh)
◆ cs_join_mesh_get_edge()
cs_lnum_t cs_join_mesh_get_edge ( cs_lnum_t  v1_num,
cs_lnum_t  v2_num,
◆ cs_join_mesh_get_edge_face_adj()
void cs_join_mesh_get_edge_face_adj ( const cs_join_mesh_t *  mesh,
cs_lnum_t *  edge_face_idx[],
cs_lnum_t *  edge_face_lst[]
◆ cs_join_mesh_get_face_normal()
cs_real_t * cs_join_mesh_get_face_normal ( const cs_join_mesh_t *  mesh)
◆ cs_join_mesh_minmax_tol()
void cs_join_mesh_minmax_tol ( cs_join_param_t  param,
◆ cs_join_mesh_reset()
void cs_join_mesh_reset ( cs_join_mesh_t *  mesh)
◆ cs_join_mesh_sync_vertices()
void cs_join_mesh_sync_vertices ( cs_join_mesh_t *  mesh)
◆ cs_join_mesh_update()
void cs_join_mesh_update ( cs_join_mesh_t *  mesh,
◆ cs_join_mesh_vertex_clean()
void cs_join_mesh_vertex_clean ( cs_join_mesh_t *  mesh)
