cs_join_param_t Struct Reference
#include <cs_join_util.h>
+ Collaboration diagram for cs_join_param_t:
Public Attributes
int num
int perio_type
double perio_matrix [3][4]
int tree_max_level
int tree_n_max_boxes
float tree_max_box_ratio
float tree_max_box_ratio_distrib
float fraction
float plane
double plane_criteria
float merge_tol_coef
float pre_merge_factor
int n_max_equiv_breaks
int tcm
int icm
int max_sub_faces
int verbosity
int visualization
bool preprocessing
Member Data Documentation
◆ fraction
float fraction
◆ icm
int icm
◆ max_sub_faces
int max_sub_faces
◆ merge_tol_coef
◆ n_max_equiv_breaks
◆ num
int num
◆ perio_matrix
double perio_matrix[3][4]
◆ perio_type
int perio_type
◆ plane
float plane
◆ plane_criteria
◆ pre_merge_factor
◆ preprocessing
bool preprocessing
◆ tcm
int tcm
◆ tree_max_box_ratio
◆ tree_max_box_ratio_distrib
◆ tree_max_level
int tree_max_level
◆ tree_n_max_boxes
◆ verbosity
int verbosity
◆ visualization
int visualization
