cs_join_util.h
1#ifndef CS_JOIN_UTIL_H
2#define CS_JOIN_UTIL_H
5 * Manipulation of low-level structures for joining operations
6 *===========================================================================*/
32 *---------------------------------------------------------------------------*/
34#include <stdio.h>
37 * Local headers
38 *---------------------------------------------------------------------------*/
40#include "fvm/fvm_defs.h"
41#include "fvm/fvm_periodicity.h"
43#include "base/cs_base.h"
44#include "base/cs_selector.h"
45#include "base/cs_timer.h"
46
47/*---------------------------------------------------------------------------*/
48
50
51/*============================================================================
52 * Macro and type definitions
53 *============================================================================*/
54
55typedef enum {
56
60
62
63typedef enum {
64
72
74
75/*----------------------------------------------------------------------------
76 * Joining statistics
77 *----------------------------------------------------------------------------*/
78
79typedef struct {
80
81 int n_calls; /* number of calls */
82
83 /* Intersection determination info */
84
85 int bbox_layout; /* bounding box layout */
86 cs_gnum_t bbox_depth[3]; /* box tree depth */
87 cs_gnum_t n_leaves[3]; /* number of leaves */
88 cs_gnum_t n_boxes[3]; /* number of boxes */
89 cs_gnum_t n_th_leaves[3]; /* number leaves over threshold */
90 cs_gnum_t n_leaf_boxes[3]; /* number of boxes per leaf */
91 uint64_t box_mem_final[3]; /* final box memory required */
92 uint64_t box_mem_required[3]; /* memory required */
93
94 cs_timer_counter_t t_box_build; /* box build times */
95 cs_timer_counter_t t_box_query; /* box query times */
96 cs_timer_counter_t t_inter_sort; /* sort intersections times */
97
98 /* other info */
99
100 cs_timer_counter_t t_l_join_mesh; /* build local joining mesh times */
101 cs_timer_counter_t t_edge_inter; /* edge intersection times */
102 cs_timer_counter_t t_new_vtx; /* new vertices times */
103 cs_timer_counter_t t_merge_vtx; /* merge vertices times */
104 cs_timer_counter_t t_u_merge_vtx; /* update after merge vertices times */
105 cs_timer_counter_t t_split_faces; /* split faces times */
106
107 cs_timer_counter_t t_total; /* total time */
108
110
111/*----------------------------------------------------------------------------
112 * Set of user parameters to control the join operation
113 *----------------------------------------------------------------------------*/
114
115typedef struct {
116
117 int num; /* number associated to the current join operation */
118 int perio_type; /* FVM_PERIODICITY_NULL for non-periodic joinings,
119 periodicity type for periodic joinings. */
120
121 double perio_matrix[3][4]; /* Periodicity matrix for periodic joinings */
122
123 /* Octree - Quadtree search algorithm */
124 /* ---------------------------------- */
125
126 int tree_max_level; /* Deepest level reachable during tree building */
127 int tree_n_max_boxes; /* Max. number of boxes which can be related to
128 a leaf of the tree if level != tree_max_level */
129
130 float tree_max_box_ratio; /* Stop building tree when:
131 ( n_linked_boxes
132 > tree_max_box_ratio * n_init_boxes) */
133 float tree_max_box_ratio_distrib; /* In parallel, tree_max_box_ratio for
134 initial coarse tree used to
135 determine load-distribution */
136
137 /* Geometric parameters */
138 /* -------------------- */
139
140 /* parameter used to compute the tolerance associated to each vertex.
141 Also used for finding equivalent vertices during edge intersections */
142
143 float fraction;
144
145 /* maximum angle between normals of two faces considered to
146 be in the same plane (for face split) */
147
148 float plane; /* in degree */
149 double plane_criteria; /* cos(plane in rad)*cos(plane in rad) */
150
151 /* Coef. used to modify the tolerance associated to each vertex before the
152 merge operation.
153 If coef = 0.0 => no vertex merge
154 If coef < 1.0 => reduce vertex merge
155 If coef = 1.0 => no change
156 If coef > 1.0 => increase vertex merge */
157
159
160 /* Coef. used to compute a limit on staightfoward merge between
161 two vertices before the merge step. It should be a small value. */
162
164
165 /* Maximum number of equivalence breaks */
166
168
169 /* Tolerance computation mode: tcm
170 1: (default) tol = min. edge length related to a vertex * fraction
171 2: tolerance is computed like in mode 1 with in addition, the
172 multiplication by a coef. which is equal to the max sin(e1, e2)
173 where e1 and e2 are two edges sharing the same vertex V for which
174 we want to compute the tolerance
175 11: like 1 but only in taking into account only the selected faces
176 12: like 2 but only in taking into account only the selected faces */
177
178 int tcm;
179
180 /* Intersection computation mode: icm
181 1: (default) Original algorithm. Try to clip intersection on extremity
182 2: New intersection algorithm. Avoid to clip intersection on extremity
183 */
184
185 int icm;
186
187 /* Maximum number of sub-faces when splitting a face */
188
190
191 /* Verbosity:
192 O : no information printed
193 1 : general information printed
194 2 : more information printed
195 5 and beyond : highest level (DEBUG LEVEL) */
196
198
199 /* Visualization level:
200 O : no visualization output
201 1 : visualization output of joined faces
202 2 : faces modified by joining
203 */
204
206
207 /* Preprocessing flag:
208 true if this joining is part of preprocessing, false otherwise */
209
211
213
214/*----------------------------------------------------------------------------
215 * Set of variables to synchronize single elements
216 *---------------------------------------------------------------------------*/
217
220typedef struct {
221
222 cs_lnum_t n_elts;
223 int n_ranks;
224 int *ranks;
225 cs_lnum_t *index;
226 cs_lnum_t *array;
227
228} cs_join_sync_t;
229
230/*----------------------------------------------------------------------------
231 * Structure used to store the result of the extraction of entities
232 * implied in the joining operation
233 *---------------------------------------------------------------------------*/
234
235typedef struct {
236
237 cs_lnum_t n_init_b_faces; /* Number of border faces before joining */
238 cs_lnum_t n_init_i_faces; /* Number of interior faces before joining */
239 cs_lnum_t n_init_vertices; /* Number of vertices before joining */
240
241 cs_lnum_t n_faces; /* Number of border faces selected
242 for the joining operation */
243 cs_gnum_t n_g_faces; /* Global number of border faces selected
244 for the joining operation */
245 cs_lnum_t *faces; /* List of selected border faces (1-based) */
246
247 cs_gnum_t *compact_face_gnum; /* Global face numbering defined
248 on the selected faces */
249 cs_gnum_t *compact_rank_index; /* Distribution of the selected faces
250 over the ranks */
251
252 cs_lnum_t n_vertices; /* Number of vertices selected
253 for the joining operation */
254 cs_gnum_t n_g_vertices; /* Global number of selected vertices */
255 cs_lnum_t *vertices; /* List of selected vertices */
256
257 /* Adjacent faces of the current face selection: border and interior */
258
259 cs_lnum_t n_b_adj_faces;
260 cs_lnum_t n_i_adj_faces;
261
262 cs_lnum_t *b_adj_faces;
263 cs_lnum_t *i_adj_faces;
264
265 /* Keep the status of all faces of the related cs_mesh_t */
266
267 cs_join_state_t *b_face_state;
268 cs_join_state_t *i_face_state;
269
270 /* For periodicity handling: list of periodic vertex couples */
271
272 cs_lnum_t n_couples;
273 cs_gnum_t *per_v_couples;
274
275 /*
276 Single elements (Only possible in parallel). Appear mainly
277 when the domain splitting has a poor quality and elements
278 on the joining interface are prisms or tetrahedra
279 s = single (receiver) / c = coupled (owner).
280 */
281
282 bool do_single_sync;
283
284 cs_join_sync_t *s_vertices;
285 cs_join_sync_t *c_vertices;
286 cs_join_sync_t *s_edges;
287 cs_join_sync_t *c_edges;
288
289} cs_join_select_t;
290
291/*----------------------------------------------------------------------------
292 * Highest level structure to manage the joining algorithm
293 *---------------------------------------------------------------------------*/
294
295typedef struct {
296
297 cs_join_param_t param; /* Set of parameters used to control
298 the joining operations */
299
300 cs_join_stats_t stats; /* Performance statistics */
301
302 cs_join_select_t *selection; /* Store entities implied in the joining
303 operation */
304
305 char *criteria; /* Criteria used to select border faces
306 implied in the joining operation */
307
308 char *log_name; /* Optional log file name */
309
310} cs_join_t;
311
312/*=============================================================================
313 * Global variables
314 *===========================================================================*/
315
316extern int cs_glob_join_count;
317extern int cs_glob_n_joinings;
318extern cs_join_t **cs_glob_join_array;
319
320extern FILE *cs_glob_join_log;
321
324/*============================================================================
325 * Public function prototypes
326 *===========================================================================*/
327
328/*----------------------------------------------------------------------------
329 * Create and initialize a cs_join_t structure.
330 *
331 * parameters:
332 * join_number <-- number related to the joining operation
333 * sel_criteria <-- boundary face selection criteria
334 * fraction <-- value of the fraction parameter
335 * plane <-- value of the plane parameter
336 * perio_type <-- periodicity type (FVM_PERIODICITY_NULL if none)
337 * perio_matrix <-- periodicity transformation matrix
338 * verbosity <-- level of verbosity required
339 * visualization <-- level of visualization required
340 * preprocessing <-- is joining part of the preprocessing stage ?
341 *
342 * returns:
343 * a pointer to a new allocated cs_join_t structure
344 *---------------------------------------------------------------------------*/
345
346cs_join_t *
347cs_join_create(int join_number,
348 const char *sel_criteria,
349 float fraction,
350 float plane,
351 fvm_periodicity_type_t perio_type,
352 double perio_matrix[3][4],
353 int verbosity,
354 int visualization,
355 bool preprocessing);
356
357/*----------------------------------------------------------------------------
358 * Destroy a cs_join_t structure.
359 *
360 * parameters:
361 * join <-> pointer to the cs_join_t structure to destroy
362 *---------------------------------------------------------------------------*/
363
364void
365cs_join_destroy(cs_join_t **join);
366
367/*----------------------------------------------------------------------------
368 * Create and initialize a cs_join_select_t structure.
369 *
370 * parameters:
371 * selection_criteria <-- pointer to a cs_mesh_select_t structure
372 * perio_type <-- periodicity type (FVM_PERIODICITY_NULL if none)
373 * verbosity <-- level of verbosity required
374 *
375 * returns:
376 * pointer to a newly created cs_join_select_t structure
377 *---------------------------------------------------------------------------*/
378
379cs_join_select_t *
380cs_join_select_create(const char *selection_criteria,
381 fvm_periodicity_type_t perio_type,
382 int verbosity);
383
384/*----------------------------------------------------------------------------
385 * Destroy a cs_join_select_t structure.
386 *
387 * parameters:
388 * param <-- user-defined joining parameters
389 * join_select <-- pointer to pointer to structure to destroy
390 *---------------------------------------------------------------------------*/
391
392void
394 cs_join_select_t **join_select);
395
396/*----------------------------------------------------------------------------
397 * Extract vertices from a selection of faces.
398 *
399 * This function uses 1-based selection lists
400 * (select_faces and select_vertices)
401 *
402 * parameters:
403 * n_select_faces <-- number of selected faces
404 * select_faces <-- list of faces selected
405 * f2v_idx <-- "face -> vertex" connect. index
406 * f2v_lst <-- "face -> vertex" connect. list
407 * n_vertices <-- number of vertices
408 * n_sel_vertices <-> pointer to the number of selected vertices
409 * sel_vertices <-> pointer to the list of selected vertices
410 *---------------------------------------------------------------------------*/
411
412void
414 const cs_lnum_t *select_faces,
415 const cs_lnum_t *f2v_idx,
416 const cs_lnum_t *f2v_lst,
417 cs_lnum_t n_vertices,
418 cs_lnum_t *n_select_vertices,
419 cs_lnum_t *select_vertices[]);
420
421/*----------------------------------------------------------------------------
422 * Eliminate redundancies found between two lists of elements.
423 * Delete elements in elts[] and keep elements in the reference list.
424 *
425 * parameters:
426 * n_elts <-> number of elements in the list to clean
427 * elts <-> list of elements in the list to clean
428 * n_ref_elts <-- number of elements in the reference list
429 * ref_elts <-- list of reference elements
430 *---------------------------------------------------------------------------*/
431
432void
434 cs_lnum_t *elts[],
435 cs_lnum_t n_ref_elts,
436 cs_lnum_t ref_elts[]);
437
438/*----------------------------------------------------------------------------
439 * Build vertex -> vertex index for a selection of faces.
440 *
441 * "v2v_idx" is already allocated to the number of vertices in the mesh.
442 * At this stage, it is just a counter.
443 *
444 * parameters:
445 * n_faces <-- number of selected faces
446 * faces <-- list of selected faces
447 * f2v_idx <-- face -> vertex connectivity index
448 * f2v_lst <-- face -> vertex connectivity list
449 * v2v_idx <-> index to build (already allocated and may be used again)
450 *---------------------------------------------------------------------------*/
451
452void
454 const cs_lnum_t faces[],
455 const cs_lnum_t f2v_idx[],
456 const cs_lnum_t f2v_lst[],
457 cs_lnum_t v2v_idx[]);
458
459/*----------------------------------------------------------------------------
460 * Build vertex -> vertex list for a selection of faces.
461 * "count" and "v2v_lst" are already allocated to the number of vertices in
462 * the mesh.
463 *
464 * parameters:
465 * n_faces <-- number of selected faces
466 * faces <-- list of selected faces
467 * f2v_idx <-- face -> vertex connectivity index
468 * f2v_lst <-- face -> vertex connectivity list
469 * count <-> array used to count the number of values already added
470 * v2v_idx <-- vertex -> vertex connect. index
471 * v2v_lst <-> vertex -> vertex connect. list to build (can be used again)
472 *---------------------------------------------------------------------------*/
473
474void
476 const cs_lnum_t faces[],
477 const cs_lnum_t f2v_idx[],
478 const cs_lnum_t f2v_lst[],
479 cs_lnum_t count[],
480 const cs_lnum_t v2v_idx[],
481 cs_lnum_t v2v_lst[]);
482
483/*---------------------------------------------------------------------------*/
484
486
487#endif /* CS_JOIN_UTIL_H */
Definition: cs_defs.h:528
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:529
Definition: cs_defs.h:325
cs_join_t * cs_join_create(int join_number, const char *sel_criteria, float fraction, float plane, fvm_periodicity_type_t perio_type, double perio_matrix[3][4], int verbosity, int visualization, bool preprocessing)
Definition: cs_join_util.cpp:2096
cs_join_type_t
Definition: cs_join_util.h:55
@ CS_JOIN_TYPE_CONFORMING
Definition: cs_join_util.h:58
@ CS_JOIN_TYPE_NULL
Definition: cs_join_util.h:57
@ CS_JOIN_TYPE_NON_CONFORMING
Definition: cs_join_util.h:59
cs_join_select_t * cs_join_select_create(const char *selection_criteria, fvm_periodicity_type_t perio_type, int verbosity)
Definition: cs_join_util.cpp:2217
void cs_join_clean_selection(cs_lnum_t *n_elts, cs_lnum_t *elts[], cs_lnum_t n_ref_elts, cs_lnum_t ref_elts[])
Definition: cs_join_util.cpp:2666
void cs_join_destroy(cs_join_t **join)
Definition: cs_join_util.cpp:2189
cs_join_state_t
Definition: cs_join_util.h:63
@ CS_JOIN_STATE_MERGE
Definition: cs_join_util.h:69
@ CS_JOIN_STATE_NEW
Definition: cs_join_util.h:66
@ CS_JOIN_STATE_PERIO_MERGE
Definition: cs_join_util.h:70
@ CS_JOIN_STATE_SPLIT
Definition: cs_join_util.h:71
Definition: cs_join_util.h:68
@ CS_JOIN_STATE_ORIGIN
Definition: cs_join_util.h:67
@ CS_JOIN_STATE_UNDEF
Definition: cs_join_util.h:65
void cs_join_build_edges_lst(cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t count[], const cs_lnum_t v2v_idx[], cs_lnum_t v2v_lst[])
Definition: cs_join_util.cpp:2778
void cs_join_select_destroy(cs_join_param_t param, cs_join_select_t **join_select)
Definition: cs_join_util.cpp:2555
void cs_join_build_edges_idx(cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t v2v_idx[])
Definition: cs_join_util.cpp:2710
void cs_join_extract_vertices(cs_lnum_t n_select_faces, const cs_lnum_t *select_faces, const cs_lnum_t *f2v_idx, const cs_lnum_t *f2v_lst, cs_lnum_t n_vertices, cs_lnum_t *n_select_vertices, cs_lnum_t *select_vertices[])
Definition: cs_join_util.cpp:2603
Definition: fvm_periodicity.h:50
Definition: cs_join_util.h:115
int icm
Definition: cs_join_util.h:185
int n_max_equiv_breaks
Definition: cs_join_util.h:167
int verbosity
Definition: cs_join_util.h:197
int perio_type
Definition: cs_join_util.h:118
float fraction
Definition: cs_join_util.h:143
Definition: cs_join_util.h:133
float plane
Definition: cs_join_util.h:148
bool preprocessing
Definition: cs_join_util.h:210
Definition: cs_join_util.h:149
Definition: cs_join_util.h:127
int num
Definition: cs_join_util.h:117
float merge_tol_coef
Definition: cs_join_util.h:158
int visualization
Definition: cs_join_util.h:205
int tcm
Definition: cs_join_util.h:178
Definition: cs_join_util.h:130
int tree_max_level
Definition: cs_join_util.h:126
int max_sub_faces
Definition: cs_join_util.h:189
float pre_merge_factor
Definition: cs_join_util.h:163
Definition: cs_join_util.h:79
Definition: cs_join_util.h:94
Definition: cs_join_util.h:101
int n_calls
Definition: cs_join_util.h:81
Definition: cs_join_util.h:103
Definition: cs_join_util.h:105
Definition: cs_join_util.h:96
Definition: cs_join_util.h:107
Definition: cs_join_util.h:104
Definition: cs_join_util.h:95
Definition: cs_join_util.h:100
int bbox_layout
Definition: cs_join_util.h:85
Definition: cs_join_util.h:102
Definition: cs_timer.h:51
