cs_gwf.h File Reference
+ Include dependency graph for cs_gwf.h:
bool cs_gwf_is_activated (void)
 Check if the groundwater flow module has been activated. More...
cs_gwf_t * cs_gwf_activate (cs_gwf_model_type_t model, cs_flag_t option_flag, cs_flag_t post_flag)
 Initialize the module dedicated to groundwater flows. More...
cs_gwf_t * cs_gwf_destroy_all (void)
 Free all structures related to groundwater flows. More...
cs_gwf_tpf_t * cs_gwf_get_two_phase_model (void)
 Get the main structure which manages a two-phase flow model. More...
void cs_gwf_set_two_phase_numerical_options (cs_gwf_tpf_approx_type_t approx, cs_gwf_tpf_solver_type_t solver, bool pg_pos)
 Set the numerical options related to the two phase flow models. More...
void cs_gwf_set_miscible_two_phase_model (cs_real_t l_mass_density, cs_real_t l_viscosity, cs_real_t g_viscosity, cs_real_t l_diffusivity_h, cs_real_t h_molar_mass, cs_real_t ref_temperature, cs_real_t henry_constant)
 Set the parameters defining the two-phase flow model in the miscible case. Use SI unit if not prescribed otherwise. More...
void cs_gwf_set_immiscible_two_phase_model (cs_real_t l_mass_density, cs_real_t l_viscosity, cs_real_t g_viscosity, cs_real_t h_molar_mass, cs_real_t ref_temperature)
 Set the parameters defining the immiscible two-phase flow model. Use SI unit if not prescribed otherwise. More...
void cs_gwf_log_setup (void)
 Summary of the main cs_gwf_t structure. More...
void cs_gwf_set_post_options (cs_flag_t post_flag, bool reset)
 Set the flag dedicated to the post-processing of the GWF module. More...
cs_adv_field_t * cs_gwf_get_adv_field (void)
 Retrieve the advection field related to the Darcy flux in the liquid phase. More...
cs_gwf_soil_t * cs_gwf_add_iso_soil (const char *z_name, double density, double k_abs, double porosity, cs_gwf_soil_model_t model)
 Create and add a new cs_gwf_soil_t structure. An initialization by default of all members is performed. Case of a soil with an isotropic absolute permeability. More...
cs_gwf_soil_t * cs_gwf_add_aniso_soil (const char *z_name, double density, double k_abs[3][3], double porosity, cs_gwf_soil_model_t model)
 Create and add a new cs_gwf_soil_t structure. An initialization by default of all members is performed. More...
cs_gwf_tracer_t * cs_gwf_add_tracer (cs_gwf_tracer_model_t tr_model, const char *eq_name, const char *var_name)
 Add a new equation related to the groundwater flow module. More...
cs_gwf_tracer_t * cs_gwf_add_radioactive_tracer (cs_gwf_tracer_model_t tr_model, const char *eq_name, const char *var_name, double lambda)
cs_gwf_tracer_t * cs_gwf_add_user_tracer (const char *eq_name, const char *var_name, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup)
cs_gwf_tracer_decay_chain_t * cs_gwf_add_decay_chain (int n_tracers, cs_gwf_tracer_unit_t unit, const char *chain_name, const char *var_names[], cs_gwf_tracer_model_t models[], double lambda_vals[])
 Add a set of tracer equations corresponding to a radioactive decay chain in the groundwater flow module. More...
void cs_gwf_init_sharing (const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
 Set shared pointers to main domain members. More...
void cs_gwf_init_model_context (void)
 Initialize the context of the model after the activation of the module and make first settings of the model parameters (physical and numerical). At this stage, cs_user_parameters() has not been called. More...
void cs_gwf_init_setup (void)
 Predefined settings for the groundwater flow model and its related equations. More...
void cs_gwf_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Last initialization step of the groundwater flow module. At this stage, the mesh quantities are defined. More...
void cs_gwf_hydraulic_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_flag_t update_flag)
 Update the groundwater system related to the hydraulic model: pressure head, head in law, moisture content, darcian velocity, soil capacity or permeability if needed. Quantities related to tracer model are updated elsewhere. More...
void cs_gwf_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
 Initialize the GWF module (done after all the setup phase and after the initialization of all equations) One sets an initial value to all quantities related to this module. More...
void cs_gwf_compute_steady_state (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the steady-state of the groundwater flows module. Nothing is done if all equations are unsteady. More...
void cs_gwf_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the system related to groundwater flows module. More...
void cs_gwf_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts)
 Predefined extra-operations for the groundwater flow module. More...
void cs_gwf_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
 Predefined post-processing output for the groundwater flow module. According to the model, additional postprocessing may be defined. Prototype of this function is given since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More...
◆ cs_gwf_activate()
cs_gwf_t * cs_gwf_activate ( cs_gwf_model_type_t  model,
cs_flag_t  post_flag
[in]modeltype of physical modelling
[in]option_flagoptional flag to specify this module
[in]post_flagoptional automatic postprocessing
a pointer to a new allocated groundwater flow structure
◆ cs_gwf_add_aniso_soil()
cs_gwf_soil_t * cs_gwf_add_aniso_soil ( const char *  z_name,
double  density,
double  k_abs[3][3],
double  porosity,
[in]z_namename of the volume zone corresponding to the soil
[in]densityvalue of the bulk mass density
[in]k_absabsolute (or intrisic) permeability (tensor-valued)
[in]porosityvalue of the porosity (saturated moisture content)
[in]modeltype of model for the soil behavior
a pointer to the new allocated soil structure
◆ cs_gwf_add_decay_chain()
cs_gwf_tracer_decay_chain_t * cs_gwf_add_decay_chain ( int  n_tracers,
const char *  chain_name,
const char *  var_names[],
This equation is a particular type of unsteady advection-diffusion reaction equation. Tracer is advected thanks to the darcian velocity and diffusion/reaction parameters result from a physical modelling. Terms solved in this equation are activated according to predefined settings. The advection field corresponds to that of the liquid phase. A difference w.r.t. to standard tracer is the definition of specific source term taking into account the source/sink of the parent/current equation.
[in]n_tracersnumber of tracers equations
[in]unittype of unit used in the tracer equations
[in]chain_namename of the decay chain
[in]var_namesarray of names of the related variable
[in]modelsmodel associated to each tracer equation
[in]lambda_valsset of first order radiactive decay coefficient
a pointer to the new cs_gwf_tracer_decay_chain_t structure
◆ cs_gwf_add_iso_soil()
cs_gwf_soil_t * cs_gwf_add_iso_soil ( const char *  z_name,
double  density,
double  k_abs,
double  porosity,
[in]k_absabsolute (or intrisic) permeability (scalar-valued)
◆ cs_gwf_add_radioactive_tracer()
cs_gwf_tracer_t * cs_gwf_add_radioactive_tracer ( cs_gwf_tracer_model_t  tr_model,
const char *  eq_name,
const char *  var_name,
double  lambda
    reaction equation. The tracer is advected thanks to the darcian
    velocity. The diffusion and reaction properties result from
    predefined physical modelling given by the parameter "tr_model".
    Other terms solved in this equation are activated according to
    liquid phase.
[in]tr_modelphysical modelling to consider (0 = default settings)
[in]eq_namename of the tracer equation
[in]var_namename of the related variable
[in]lambdafirst order radioactive decay coefficient
a pointer to the new cs_gwf_tracer_t structure
◆ cs_gwf_add_tracer()
cs_gwf_tracer_t * cs_gwf_add_tracer ( cs_gwf_tracer_model_t  tr_model,
    equation. The tracer is advected thanks to the darcian velocity and
    the diffusion property results from a physical modelling. Terms
    phase.
◆ cs_gwf_add_user_tracer()
cs_gwf_tracer_t * cs_gwf_add_user_tracer ( const char *  eq_name,
cs_gwf_tracer_init_setup_t *  init_setup,
cs_gwf_tracer_finalize_setup_t *  finalize_setup
    modelling. Terms are activated according to predefined settings.
    Modelling of the tracer parameters are left to the user
[in]init_setupfunction pointer (predefined prototype)
[in]finalize_setupfunction pointer (predefined prototype)
◆ cs_gwf_compute()
void cs_gwf_compute ( const cs_mesh_t *  mesh,
const cs_time_step_t *  time_step,
const cs_cdo_quantities_t *  cdoq
◆ cs_gwf_compute_steady_state()
void cs_gwf_compute_steady_state ( const cs_mesh_t *  mesh,
◆ cs_gwf_destroy_all()
cs_gwf_t * cs_gwf_destroy_all ( void  )
a null pointer
◆ cs_gwf_extra_op()
void cs_gwf_extra_op ( const cs_cdo_connect_t *  connect,
const cs_cdo_quantities_t *  cdoq,
const cs_time_step_t *  ts
[in]tspointer to a cs_time_step_t struct.
◆ cs_gwf_extra_post()
void cs_gwf_extra_post ( void *  input,
int  mesh_id,
int  cat_id,
int  ent_flag[5],
cs_lnum_t  n_cells,
[in,out]inputpointer to a optional structure (here a cs_gwf_t structure)
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for this call
[in]ent_flagindicate global presence of cells (ent_flag[0]), interior faces (ent_flag[1]), boundary faces (ent_flag[2]), particles (ent_flag[3]) or probes (ent_flag[4])
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]i_face_idslist of interior faces (0 to n-1)
[in]b_face_idslist of boundary faces (0 to n-1)
[in]time_steppointer to a cs_time_step_t struct.
◆ cs_gwf_finalize_setup()
void cs_gwf_finalize_setup ( const cs_cdo_connect_t *  connect,
const cs_cdo_quantities_t *  quant
◆ cs_gwf_get_adv_field()
cs_adv_field_t * cs_gwf_get_adv_field ( void  )
a pointer to a cs_adv_field_t structure or null
a pointer to a cs_adv_field_t structure or nullptr
◆ cs_gwf_get_two_phase_model()
cs_gwf_tpf_t * cs_gwf_get_two_phase_model ( void  )
a pointer to the structure cs_gwf_tpf_t
◆ cs_gwf_hydraulic_update()
void cs_gwf_hydraulic_update ( const cs_mesh_t *  mesh,
const cs_time_step_t *  ts,
[in]tspointer to a cs_time_step_t structure
[in]update_flagmetadata associated to the status of the update step to perform
◆ cs_gwf_init_model_context()
void cs_gwf_init_model_context ( void  )
◆ cs_gwf_init_setup()
void cs_gwf_init_setup ( void  )
At this stage, all soils have been defined and equation parameters are set (cs_user_parameters() has been called and settings performed).
Create new cs_field_t structures according to the setting.
◆ cs_gwf_init_sharing()
void cs_gwf_init_sharing ( const cs_cdo_quantities_t *  cdoq,
[in]cdoqpointer to additional mesh quantities for CDO schemes
[in]connectpointer to additional mesh connectivities for CDO schemes
◆ cs_gwf_init_values()
void cs_gwf_init_values ( const cs_mesh_t *  mesh,
◆ cs_gwf_is_activated()
bool cs_gwf_is_activated ( void  )
true or false
◆ cs_gwf_log_setup()
void cs_gwf_log_setup ( void  )
◆ cs_gwf_set_immiscible_two_phase_model()
void cs_gwf_set_immiscible_two_phase_model ( cs_real_t  l_mass_density,
[in]l_mass_densitymass density of the main liquid component
[in]l_viscosityviscosity in the liquid phase (Pa.s)
[in]g_viscosityviscosity in the gas phase (Pa.s)
[in]h_molar_massmolar mass of the main gas component
[in]ref_temperaturereference temperature in Kelvin
◆ cs_gwf_set_miscible_two_phase_model()
void cs_gwf_set_miscible_two_phase_model ( cs_real_t  l_mass_density,
[in]l_diffusivity_hdiffusivity of the main gas component in the liquid phase
[in]henry_constantconstant in the Henry law
◆ cs_gwf_set_post_options()
void cs_gwf_set_post_options ( cs_flag_t  post_flag,
bool  reset
[in]post_flagflag to set
[in]resetreset post flag before
◆ cs_gwf_set_two_phase_numerical_options()
void cs_gwf_set_two_phase_numerical_options ( cs_gwf_tpf_approx_type_t  approx,
bool  pg_pos
[in]approxtype of coefficient approximation
[in]solvertype of solver
[in]pg_posactivate an enforcement of gas pressure >= 0
