cs_domain_setup.cpp File Reference
Functions to handle the setup of a computational domain High level interface for handling the computation. More...
#include <cassert>
#include "base/cs_mem.h"
#include "base/cs_ale.h"
#include "base/cs_log.h"
#include "base/cs_log_iteration.h"
#include "base/cs_parall.h"
#include "base/cs_pressure_correction.h"
#include "cdo/cs_cdo_blas.h"
#include "cdo/cs_cdo_system.h"
#include "cdo/cs_equation.h"
#include "cdo/cs_equation_param.h"
#include "cdo/cs_evaluate.h"
#include "cdo/cs_hodge.h"
#include "cdo/cs_maxwell.h"
#include "cdo/cs_mesh_deform.h"
#include "cdo/cs_navsto_system.h"
#include "cdo/cs_solidification.h"
#include "cdo/cs_thermal_system.h"
#include "cdo/cs_walldistance.h"
#include "gui/cs_gui.h"
#include "gwf/cs_gwf.h"
#include "cdo/cs_domain_setup.h"
+ Include dependency graph for cs_domain_setup.cpp:
static void _set_scheme_flags (cs_domain_t *domain)
 Define the scheme flags for the current computational domain Requirement: domain->cdo_context is alloctated. More...
void cs_domain_set_time_param (cs_domain_t *domain, int nt_max, double t_max)
 Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation. More...
void cs_domain_automatic_time_step_settings (cs_domain_t *domain)
 Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step. More...
cs_xdef_t * cs_domain_def_time_step_by_function (cs_domain_t *domain, cs_time_func_t *func, void *func_input)
 Define the value of the time step thanks to a predefined function. More...
void cs_domain_def_time_step_by_value (cs_domain_t *domain, double dt)
 Define the value of the time step. More...
void cs_domain_setup_init_cdo_structures (cs_domain_t *domain)
 After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes. More...
void cs_domain_setup_initialize (cs_domain_t *domain)
 First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields (already done in the FV part) Define cs_sles_t structures for variable fields. More...
void cs_domain_setup_finalize (cs_domain_t *domain)
 Last GUI and then user setup stage of the cs_domain_t structure. More...
void cs_domain_setup_finalize_module (cs_domain_t *domain)
 Last user setup stage of the cs_domain_t structure. More...
void cs_domain_setup_init_state (cs_domain_t *domain)
 Initialize systems of equations and their related field/properties values according to the user settings. More...
void cs_domain_setup_log (const cs_domain_t *domain)
 Summary of the main domain settings. More...
◆ _set_scheme_flags()
static void _set_scheme_flags ( cs_domain_t *  domain)
static
◆ cs_domain_automatic_time_step_settings()
void cs_domain_automatic_time_step_settings ( cs_domain_t *  domain)
◆ cs_domain_def_time_step_by_function()
cs_xdef_t * cs_domain_def_time_step_by_function ( cs_domain_t *  domain,
cs_time_func_t *  func,
void *  func_input
[in]funcpointer to a cs_time_func_t function
[in]func_inputpointer to a structure cast on-the-fly
a pointer to the created definition (cs_xdef_t structure)
◆ cs_domain_def_time_step_by_value()
void cs_domain_def_time_step_by_value ( cs_domain_t *  domain,
double  dt
[in]dtvalue of the constant time step
◆ cs_domain_set_time_param()
void cs_domain_set_time_param ( cs_domain_t *  domain,
int  nt_max,
double  t_max
[in]nt_maxmax. number of time step iterations
[in]t_maxfinal physical time of the simulation
◆ cs_domain_setup_finalize()
void cs_domain_setup_finalize ( cs_domain_t *  domain)
[in,out]domainpointer to a cs_domain_t struct.
◆ cs_domain_setup_finalize_module()
void cs_domain_setup_finalize_module ( cs_domain_t *  domain)
◆ cs_domain_setup_init_cdo_structures()
void cs_domain_setup_init_cdo_structures ( cs_domain_t *  domain)
◆ cs_domain_setup_init_state()
void cs_domain_setup_init_state ( cs_domain_t *  domain)
◆ cs_domain_setup_initialize()
void cs_domain_setup_initialize ( cs_domain_t *  domain)
◆ cs_domain_setup_log()
void cs_domain_setup_log ( const cs_domain_t *  domain)
[in]domainpointer to the cs_domain_t structure to summarize
