cs_combustion_read_data.cpp File Reference
Combustion combustion model: setup data from input. More...
#include <ctype.h>
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "base/cs_assert.h"
#include "base/cs_field.h"
#include "base/cs_file.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "gui/cs_gui_specific_physics.h"
#include "pprt/cs_combustion_model.h"
#include "cogz/cs_combustion_gas.h"
#include "cogz/cs_combustion_bsh.h"
#include "cogz/cs_combustion_ht_convert.h"
#include "rayt/cs_rad_transfer.h"
#include "cogz/cs_combustion_read_data.h"
+ Include dependency graph for cs_combustion_read_data.cpp:
static void _next_line (const char *name, int &line_num, char *&s, char *last, bool allow_end)
 Point to next line in text buffer. More...
static char * _extract_token (const char *buffer_name, const char *token_name, char *&next, char *last, int line_num, int idx)
 Extract i-th token from buffer. More...
static void _solve_ax_b_gauss (int n, double a[], double *restrict b, double *restrict x)
static void _combustion_slfm_read_thermophysical_library (void)
 Read gas combustion thermophysical data for steady laminar flamelet. More...
static void _combustion_slfm_read_radiation_library (void)
 Read absorption/emmission coefficients for steady laminar flamelet. More...
void cs_combustion_read_data (void)
 Read gas combustion thermochemistry data. More...
void cs_combustion_slfm_read_library (void)
 Read necessary libraries for steady laminar flamelet. More...
◆ _combustion_slfm_read_radiation_library()
static void _combustion_slfm_read_radiation_library ( void  )
static
◆ _combustion_slfm_read_thermophysical_library()
static void _combustion_slfm_read_thermophysical_library ( void  )
static
◆ _extract_token()
static char * _extract_token ( const char *  buffer_name,
const char *  token_name,
char *&  next,
char *  last,
int  line_num,
int  idx
static
A null-termination character is added to to end of the token unless the end of line has been reached, so the buffer values are modified. The pointer to the next portion of the string is set just after this null character.
[in]buffer_namebuffer name (for error logging)
[in]token_nametoken type name (for error logging)
[in,out]nextpointer to next part of buffer
[in]lastpointer to last byte of buffer
[in]line_numline number (for error logging)
[in]idxtoken index in line (for error logging)
◆ _next_line()
static void _next_line ( const char *  name,
int &  line_num,
char *&  s,
char *  last,
bool  allow_end
static
[in]namename of associated file (for error logging)
[in,out]line_numline number counter
[in,out]startany position in current line before line break in, pointer to start of line out
[in]lastlast possible position in buffer
[in]allow_endif true, return null if last position in buffer is reached; otherwise, this is considered a premature end
pointer to start of next line, or null if end reached
◆ _solve_ax_b_gauss()
static void _solve_ax_b_gauss ( int  n,
double  a[],
double *restrict  b,
double *restrict  x
static
◆ cs_combustion_read_data()
void cs_combustion_read_data ( void  )
Number of global reactions: we can only balance one reaction.
◆ cs_combustion_slfm_read_library()
void cs_combustion_slfm_read_library ( void  )
