cs_cdovb_vecteq.h
1#ifndef CS_CDOVB_VECTEQ_H
2#define CS_CDOVB_VECTEQ_H
5 * Build an algebraic CDO vertex-based system for unsteady convection diffusion
6 * reaction of vector-valued equations with source terms
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2026 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------
30 * Local headers
31 *----------------------------------------------------------------------------*/
32
33#include "alge/cs_matrix.h"
34#include "base/cs_base.h"
35#include "base/cs_field.h"
36#include "base/cs_time_step.h"
37#include "cdo/cs_cdo_connect.h"
38#include "cdo/cs_cdo_local.h"
42#include "cdo/cs_source_term.h"
43#include "mesh/cs_mesh.h"
45/*============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/*============================================================================
54 * Public function prototypes
55 *============================================================================*/
56
57/*----------------------------------------------------------------------------*/
64/*----------------------------------------------------------------------------*/
65
66bool
68
69/*----------------------------------------------------------------------------*/
79/*----------------------------------------------------------------------------*/
80
81void
83 const cs_cdo_connect_t *connect,
84 const cs_time_step_t *time_step);
85
86/*----------------------------------------------------------------------------*/
93/*----------------------------------------------------------------------------*/
94
95void
98
104/*----------------------------------------------------------------------------*/
105
106void
108
109/*----------------------------------------------------------------------------*/
121/*----------------------------------------------------------------------------*/
122
123void *
125 int var_id,
126 int bflux_id,
128
129/*----------------------------------------------------------------------------*/
137/*----------------------------------------------------------------------------*/
138
139void *
140cs_cdovb_vecteq_free_context(void *builder);
141
155/*----------------------------------------------------------------------------*/
156
157void
159 const int field_id,
160 const cs_mesh_t *mesh,
161 const cs_equation_param_t *eqp,
163 void *context);
164
165/*----------------------------------------------------------------------------*/
178/*----------------------------------------------------------------------------*/
179
180void
182 const cs_mesh_t *mesh,
183 const int field_id,
184 const cs_equation_param_t *eqp,
186 void *context);
187
188/*----------------------------------------------------------------------------*/
200/*----------------------------------------------------------------------------*/
201
202void
204 const cs_real_t *rhs,
205 const cs_equation_param_t *eqp,
207 void *data,
208 cs_real_t *field_val);
209
210/*----------------------------------------------------------------------------*/
222/*----------------------------------------------------------------------------*/
223
224cs_real_t *
226 bool previous);
227
228/*----------------------------------------------------------------------------*/
241/*----------------------------------------------------------------------------*/
242
243cs_real_t *
245 bool previous);
246
247/*----------------------------------------------------------------------------*/
256/*----------------------------------------------------------------------------*/
257
258void
261 void *context);
262
263/*----------------------------------------------------------------------------*/
271/*----------------------------------------------------------------------------*/
272
273void
276 void *context);
277
278#endif /* CS_CDOVB_VECTEQ_H */
time step descriptor
Definition: cs_time_step.h:60
void cs_cdovb_vecteq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction eq...
Definition: cs_cdovb_vecteq.cpp:1329
bool cs_cdovb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Vb scheme are allocated.
Definition: cs_cdovb_vecteq.cpp:691
void cs_cdovb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO vertex-based schemes.
Definition: cs_cdovb_vecteq.cpp:791
void cs_cdovb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdovb_vecteq.cpp:1210
void cs_cdovb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set sha...
Definition: cs_cdovb_vecteq.cpp:712
void cs_cdovb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovb_vecteq.cpp:774
void cs_cdovb_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values if required (...
Definition: cs_cdovb_vecteq.cpp:1555
void * cs_cdovb_vecteq_free_context(void *builder)
Destroy a cs_cdovb_vecteq_t structure.
Definition: cs_cdovb_vecteq.cpp:1173
void cs_cdovb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_vecteq.cpp:1694
void cs_cdovb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdovb_vecteq.cpp:1670
void * cs_cdovb_vecteq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdovb_vecteq.cpp:827
cs_real_t * cs_cdovb_vecteq_get_vertex_values(void *context, bool previous)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovb_vecteq.cpp:1593
cs_real_t * cs_cdovb_vecteq_get_cell_values(void *context, bool previous)
Compute an array of values at mesh cells by interpolating the variable field associated to the given ...
Definition: cs_cdovb_vecteq.cpp:1624
Definition: cs_defs.h:332
double precision, dimension(:,:), pointer solu
Definition: atincl.f90:260
Definition: mesh.f90:26
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:163
Definition: cs_mesh.h:85
