1#ifndef CS_CDOVB_SCALEQ_H
2#define CS_CDOVB_SCALEQ_H
time step descriptor
Definition: cs_time_step.h:60
void cs_cdovb_scaleq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction eq...
Definition: cs_cdovb_scaleq.cpp:2738
void cs_cdovb_scaleq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vertex-based schemes. Set shared pointers.
Definition: cs_cdovb_scaleq.cpp:1362
void cs_cdovb_scaleq_diff_flux_in_cells(const cs_real_t *values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *eq_context, cs_real_t *diff_flux)
Cellwise and threaded computation of an approximation of a constant diffusive flux (a vector) in each...
Definition: cs_cdovb_scaleq.cpp:5208
void cs_cdovb_scaleq_finalize_sharing(void)
Free work buffer and general structure related to CDO vertex-based schemes.
Definition: cs_cdovb_scaleq.cpp:1429
void * cs_cdovb_scaleq_free_context(void *scheme_context)
Destroy a cs_cdovb_scaleq_t structure.
Definition: cs_cdovb_scaleq.cpp:2123
void cs_cdovb_scaleq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovb_scaleq.cpp:1412
void cs_cdovb_scaleq_apply_stiffness(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, const cs_property_t *pty, const cs_real_t *pot, cs_flag_t res_loc, cs_real_t *res)
Compute the cellwise stiffness matrix associated to the property given as a parameter and multiply it...
Definition: cs_cdovb_scaleq.cpp:4616
void cs_cdovb_scaleq_boundary_diff_flux(const cs_real_t *values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *vf_flux)
Compute for each vertex of a boundary face, the portion of diffusive flux across the boundary face....
Definition: cs_cdovb_scaleq.cpp:4780
cs_real_t * cs_cdovb_scaleq_get_cell_values(void *context, bool previous)
Compute an array of values at mesh cells by interpolating the variable field associated to the given ...
Definition: cs_cdovb_scaleq.cpp:4120
cs_real_t * cs_cdovb_scaleq_get_source_term_values(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Retrieve the array storing the source term values at dual mesh cells. If this array does not exist,...
Definition: cs_cdovb_scaleq.cpp:4173
void cs_cdovb_scaleq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdovb_scaleq.cpp:5517
void cs_cdovb_scaleq_init_properties(int t_id, cs_real_t t_eval, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the main properties before the main loop on cells. Case of scalar-valued CDO-Vb schemes.
Definition: cs_cdovb_scaleq.cpp:2208
void cs_cdovb_scaleq_solve_steady_state_incr(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_scaleq.cpp:2974
void cs_cdovb_scaleq_diff_flux_dfaces(const cs_real_t *values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *eq_context, cs_real_t *diff_flux)
Cellwise and threaded computation of the diffusive flux accross dual faces (a scalar) in each cell....
Definition: cs_cdovb_scaleq.cpp:5357
void cs_cdovb_scaleq_solve_theta(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equati...
Definition: cs_cdovb_scaleq.cpp:3792
cs_real_t * cs_cdovb_scaleq_get_vertex_values(void *context, bool previous)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovb_scaleq.cpp:4089
void * cs_cdovb_scaleq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovb_scaleq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdovb_scaleq.cpp:1465
void cs_cdovb_scaleq_solve_implicit(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_scaleq.cpp:3247
cs_cdo_balance_t * cs_cdovb_scaleq_balance(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Compute the balance for an equation over the full computational domain between time t_cur and t_cur +...
Definition: cs_cdovb_scaleq.cpp:4279
void cs_cdovb_scaleq_setup(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, cs_flag_t vtx_bc_flag[])
Set the boundary conditions known from the settings Define an indirection array for the enforcement o...
Definition: cs_cdovb_scaleq.cpp:2162
void cs_cdovb_scaleq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_scaleq.cpp:5541
bool cs_cdovb_scaleq_is_initialized(void)
Check if the generic structures for building a CDO-Vb scheme are allocated.
Definition: cs_cdovb_scaleq.cpp:1342
double cs_cdovb_scaleq_build_block_implicit_incr(int t_id, cs_lnum_t c_id, bool diag_block, const cs_real_t f_val[], const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Build the cell system for the given cell id when the build occurs in a coupled system....
Definition: cs_cdovb_scaleq.cpp:2442
void cs_cdovb_scaleq_solve_implicit_incr(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_scaleq.cpp:3498
void cs_cdovb_scaleq_flux_across_plane(const cs_real_t normal[], const cs_real_t *pdi, const cs_equation_param_t *eqp, int ml_id, cs_equation_builder_t *eqb, void *context, double *d_flux, double *c_flux)
Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-Vb schemes...
Definition: cs_cdovb_scaleq.cpp:5035
void cs_cdovb_scaleq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdovb_scaleq.cpp:2620
double cs_cdovb_scaleq_build_block_implicit(int t_id, cs_lnum_t c_id, bool diag_block, const cs_real_t f_val[], const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdovb_scaleq.cpp:2260
Definition: cs_defs.h:332
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
Definition: cs_cdo_toolbox.h:64
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:163
