1#ifndef CS_CDOEB_VECTEQ_H
2#define CS_CDOEB_VECTEQ_H
274 void *scheme_context);
290 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:60
Structures for building an algebraic CDO edge-based system for unsteady diffusion-reaction equations ...
cs_real_t * cs_cdoeb_vecteq_get_edge_values(void *context, bool previous)
Get the values at mesh edges (the DoFs) The lifecycle of this array is managed by the code....
Definition: cs_cdoeb_vecteq.cpp:1198
void cs_cdoeb_vecteq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction eq...
Definition: cs_cdoeb_vecteq.cpp:926
void cs_cdoeb_vecteq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_cdoeb_vecteq.cpp:1275
void cs_cdoeb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdoeb_vecteq.cpp:832
void cs_cdoeb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdoeb_vecteq.cpp:1175
cs_real_t * cs_cdoeb_vecteq_get_cell_values(void *context, bool previous)
Get the values at mesh cells from a reconstruction of edge values. The lifecycle of this array is man...
Definition: cs_cdoeb_vecteq.cpp:1226
void cs_cdoeb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdoeb_vecteq.cpp:1144
void cs_cdoeb_vecteq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_cdoeb_vecteq.cpp:1254
void * cs_cdoeb_vecteq_free_context(void *builder)
Destroy a cs_cdoeb_vecteq_t structure.
Definition: cs_cdoeb_vecteq.cpp:795
bool cs_cdoeb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Eb scheme are allocated.
Definition: cs_cdoeb_vecteq.cpp:469
void * cs_cdoeb_vecteq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdoeb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdoeb_vecteq.cpp:598
void cs_cdoeb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO edge-based schemes.
Definition: cs_cdoeb_vecteq.cpp:562
void cs_cdoeb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffers and general structures related to CDO edge-based schemes. Set shared pointers.
Definition: cs_cdoeb_vecteq.cpp:489
void cs_cdoeb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Retrieve work buffers used for building a CDO system cellwise in case of scalar-valued edge-based sch...
Definition: cs_cdoeb_vecteq.cpp:545
Definition: cs_defs.h:332
Definition: cs_restart.h:91
Definition: cs_cdoeb_priv.h:57
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:163
