cs_cdo_connect.cpp File Reference
Build additional connectivities (or adjacencies) useful for building CDO or HHO schemes. More...
#include <cassert>
#include <cstdio>
#include <cstring>
#include "base/cs_array.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "base/cs_param_types.h"
#include "base/cs_sort.h"
#include "base/cs_volume_zone.h"
#include "cdo/cs_flag.h"
#include "cdo/cs_param_cdo.h"
#include "fvm/fvm_io_num.h"
#include "mesh/cs_mesh_adjacencies.h"
+ Include dependency graph for cs_cdo_connect.cpp:
cs_cdo_connect_t * cs_cdo_connect_build (cs_mesh_t *mesh, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t cb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag, cs_flag_t mac_scheme_flag)
 Allocate and define a new cs_cdo_connect_t structure Range sets and interface sets are allocated and defined according to the value of the different scheme flags. cs_range_set_t structure related to vertices is shared the cs_mesh_t structure (the global one) More...
cs_cdo_connect_t * cs_cdo_connect_free (const cs_mesh_t *mesh, cs_cdo_connect_t *connect)
 Destroy a cs_cdo_connect_t structure. More...
void cs_cdo_connect_log_summary (const cs_cdo_connect_t *connect, cs_flag_t eb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag)
 Summary of the connectivity information. More...
void cs_cdo_connect_allocate_cw_buffer (const cs_cdo_connect_t *connect)
 Allocate and initialize the cell-wise buffer(s) More...
void cs_cdo_connect_free_cw_buffer (void)
 Free the cell-wise buffer(s) More...
double * cs_cdo_connect_get_cw_buffer (int thr_id)
 Retrieve the cell-wise buffer associated to the current thread. Use cs_get_thread_id when the thread id is not directly available. More...
long long cs_cdo_connect_get_time_perfo (void)
 Retrieve the time elapsed to build the cs_cdo_connect_t structure. More...
void cs_cdo_connect_assign_vtx_ifs_rs (const cs_mesh_t *mesh, int n_vtx_dofs, bool interlaced, cs_interface_set_t **p_ifs, cs_range_set_t **p_rs)
 Allocate and define a cs_range_set_t structure and a cs_interface_set_t structure for schemes with DoFs at vertices. More...
void cs_cdo_connect_discrete_curl (const cs_cdo_connect_t *connect, const cs_real_t *edge_values, cs_real_t **p_curl_values)
 Compute the discrete curl operator across each primal faces. From an edge-based array (seen as circulations) compute a face-based array (seen as fluxes) More...
void cs_cdo_connect_dump (const cs_cdo_connect_t *connect)
 Dump a cs_cdo_connect_t structure for debugging purpose. More...
Allocate and define a cs_adjacency_t structure related to the connectivity vertex to vertices through edges.
Adjacent vertices are accessed based on the vertex with lowest id. Another v2v connectivity through cells is possible. Please read the source code if interested
[in]mpointer to a cs_mesh_t structure
a pointer to a new allocated cs_adjacency_t structure
◆ cs_cdo_connect_allocate_cw_buffer()
void cs_cdo_connect_allocate_cw_buffer ( const cs_cdo_connect_t *  connect)
[in]connectpointer to additional connectivities
◆ cs_cdo_connect_assign_vtx_ifs_rs()
void cs_cdo_connect_assign_vtx_ifs_rs ( const cs_mesh_t *  mesh,
int  n_vtx_dofs,
bool  interlaced,
cs_interface_set_t **  p_ifs,
cs_range_set_t **  p_rs
[in]n_vtx_dofsnumber of DoFs per vertex
[in]interlacedfalse means a block viewpoint
[in,out]p_ifspointer of pointer to a cs_interface_set_t
[in,out]p_rspointer of pointer to a cs_range_set_t
◆ cs_cdo_connect_build()
cs_cdo_connect_t * cs_cdo_connect_build ( cs_mesh_t *  mesh,
DOXYGEN_SHOULD_SKIP_THIS
[in,out]meshpointer to a cs_mesh_t structure
[in]eb_scheme_flagmetadata for Edge-based schemes
[in]fb_scheme_flagmetadata for Face-based schemes
[in]cb_scheme_flagmetadata for Cell-based schemes
[in]vb_scheme_flagmetadata for Vertex-based schemes
[in]vcb_scheme_flagmetadata for Vertex+Cell-based schemes
[in]hho_scheme_flagmetadata for HHO schemes
a pointer to a cs_cdo_connect_t structure
◆ cs_cdo_connect_discrete_curl()
void cs_cdo_connect_discrete_curl ( const cs_cdo_connect_t *  connect,
const cs_real_t *  edge_values,
cs_real_t **  p_curl_values
[in]edge_valuesarray of values at edges
[in,out]p_curl_valuesarray storing the curl across faces. This array is allocated if necessary.
◆ cs_cdo_connect_dump()
void cs_cdo_connect_dump ( const cs_cdo_connect_t *  connect)
[in]connectpointer to cs_cdo_connect_t structure
◆ cs_cdo_connect_free()
cs_cdo_connect_t * cs_cdo_connect_free ( const cs_mesh_t *  mesh,
[in]meshpointer to a mesh structure
[in,out]connectpointer to additional CDO connectivities
a null pointer
◆ cs_cdo_connect_free_cw_buffer()
void cs_cdo_connect_free_cw_buffer ( void  )
◆ cs_cdo_connect_get_cw_buffer()
double * cs_cdo_connect_get_cw_buffer ( int  thr_id)
[in]thr_idthread_id (0 if no openMP)
a pointer to an allocated auxiliary cell-wise buffer
◆ cs_cdo_connect_get_time_perfo()
long long cs_cdo_connect_get_time_perfo ( void  )
the value of the time elapsed in ns
◆ cs_cdo_connect_log_summary()
void cs_cdo_connect_log_summary ( const cs_cdo_connect_t *  connect,
