cs_equation_param.h File Reference
+ Include dependency graph for cs_equation_param.h:
Classes
struct  cs_equation_param_t
 Set of parameters to handle an unsteady convection-diffusion-reaction equation with term sources. More...
Macros
Flags specifying the behavior of an equation (activated terms like the
convection, diffusion, etc.).
#define CS_EQUATION_LOCKED   (1 << 0) /* 1 */
 Parameters for setting an equation are not modifiable anymore. More...
#define CS_EQUATION_UNSTEADY   (1 << 1) /* 2 */
 Unsteady term is needed. More...
#define CS_EQUATION_CONVECTION   (1 << 2) /* 4 */
 Convection term is needed. More...
#define CS_EQUATION_DIFFUSION   (1 << 3) /* 8 */
 Diffusion term is needed. A scalar-/vector-valued Laplacian with div .grad. More...
#define CS_EQUATION_CURLCURL   (1 << 4) /* 16 */
 The term related to the curl-curl operator is needed. More...
#define CS_EQUATION_GRADDIV   (1 << 5) /* 32 */
 The term related to the grad-div operator is needed. More...
#define CS_EQUATION_REACTION   (1 << 6) /* 64 */
 Reaction term is needed. More...
#define CS_EQUATION_FORCE_VALUES   (1 << 7) /* 128 */
 Add an algebraic manipulation to set the value of a given set of interior degrees of freedom. More...
#define CS_EQUATION_INSIDE_SYSTEM   (1 << 8) /* 256 */
 The current equation settings belong to a system of equation. More...
#define CS_EQUATION_BUILD_HOOK   (1 << 9) /* 512 */
 Activate a build hook function to get a fine control of the discretization process during the cellwise building of the linear system. Need a function matching the cs_equation_build_hook_t prototype. More...
#define CS_EQUATION_USER_TRIGGERED   (1 << 10) /* 1024 */
 The stage at which the equation is solved is driven by the user. So, this user-defined equation is not solved at the same time as the other user-defined equations. More...
Flags specifying which extra operation related to an equation is
needed.
#define CS_EQUATION_POST_BALANCE   (1 << 0) /* 1 */
 Compute and postprocess the equation balance. More...
#define CS_EQUATION_POST_PECLET   (1 << 1) /* 2 */
 Compute and postprocess the Peclet number. More...
#define CS_EQUATION_POST_UPWIND_COEF   (1 << 2) /* 4 */
 Postprocess the value of the upwinding coefficient. Only useful if variable coefficient controls the amount of upwinding. For instant, in schemes such as Schaffeter-Gummel, the upwind portion is driven by the local Peclet number. More...
#define CS_EQUATION_POST_NORMAL_FLUX   (1 << 3) /* 8 */
 Postprocess the value of the normal flux across the boundary faces. More...
Enumerations
enum  cs_equation_type_t {
  CS_EQUATION_TYPE_GROUNDWATER , CS_EQUATION_TYPE_MAXWELL , CS_EQUATION_TYPE_NAVSTO , CS_EQUATION_TYPE_PREDEFINED ,
  CS_EQUATION_TYPE_THERMAL , CS_EQUATION_TYPE_SOLIDIFICATION , CS_EQUATION_TYPE_USER , CS_EQUATION_N_TYPES
 Type of equations managed by the solver. More...
enum  cs_equation_key_t {
  CS_EQKEY_ADV_CIP_COEF , CS_EQKEY_ADV_EXTRAPOL , CS_EQKEY_ADV_FORMULATION , CS_EQKEY_ADV_SCHEME ,
  CS_EQKEY_ADV_STRATEGY , CS_EQKEY_ADV_UPWIND_PORTION , CS_EQKEY_AMG_TYPE , CS_EQKEY_BC_ENFORCEMENT ,
  CS_EQKEY_BC_STRONG_PENA_COEFF , CS_EQKEY_BC_WEAK_PENA_COEFF , CS_EQKEY_DO_LUMPING , CS_EQKEY_DOF_REDUCTION ,
  CS_EQKEY_EXTRA_OP , CS_EQKEY_HODGE_DIFF_ALGO , CS_EQKEY_HODGE_DIFF_COEF , CS_EQKEY_HODGE_TIME_ALGO ,
  CS_EQKEY_HODGE_REAC_ALGO , CS_EQKEY_ITSOL , CS_EQKEY_ITSOL_ATOL , CS_EQKEY_ITSOL_DTOL ,
  CS_EQKEY_ITSOL_EPS , CS_EQKEY_ITSOL_MAX_ITER , CS_EQKEY_ITSOL_RESNORM_TYPE , CS_EQKEY_ITSOL_RESTART ,
  CS_EQKEY_ITSOL_RTOL , CS_EQKEY_SOLVER , CS_EQKEY_SOLVER_ATOL , CS_EQKEY_SOLVER_DTOL ,
  CS_EQKEY_SOLVER_MAX_ITER , CS_EQKEY_SOLVER_NO_OP , CS_EQKEY_SOLVER_RESNORM_TYPE , CS_EQKEY_SOLVER_RESTART ,
  CS_EQKEY_SOLVER_RTOL , CS_EQKEY_OMP_ASSEMBLY_STRATEGY , CS_EQKEY_PRECOND , CS_EQKEY_PRECOND_BLOCK_TYPE ,
  CS_EQKEY_SADDLE_ATOL , CS_EQKEY_SADDLE_AUGMENT_SCALING , CS_EQKEY_SADDLE_DTOL , CS_EQKEY_SADDLE_MAX_ITER ,
  CS_EQKEY_SADDLE_PRECOND , CS_EQKEY_SADDLE_RTOL , CS_EQKEY_SADDLE_SCHUR_APPROX , CS_EQKEY_SADDLE_SOLVER ,
  CS_EQKEY_SADDLE_SOLVER_CLASS , CS_EQKEY_SADDLE_SOLVER_RESTART , CS_EQKEY_SADDLE_VERBOSITY , CS_EQKEY_SLES_VERBOSITY ,
  CS_EQKEY_SOLVER_FAMILY , CS_EQKEY_SPACE_SCHEME , CS_EQKEY_TIME_SCHEME , CS_EQKEY_TIME_THETA ,
  CS_EQKEY_VERBOSITY , CS_EQKEY_N_KEYS
 List of available keys for setting the parameters of an equation. More...
static void cs_equation_param_set_flag (cs_equation_param_t *eqp, cs_flag_t flag)
 Update the flag related to a cs_equation_param_t structure. More...
static bool cs_equation_param_has_diffusion (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a diffusion term. More...
static bool cs_equation_param_has_curlcurl (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a curl-curl term. More...
static bool cs_equation_param_has_graddiv (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a grad-div term. More...
static bool cs_equation_param_has_convection (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a convection term. More...
static bool cs_equation_param_has_reaction (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a reaction term. More...
static bool cs_equation_param_has_time (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs an unsteady term. More...
static bool cs_equation_param_has_sourceterm (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation needs a source term. More...
static bool cs_equation_param_has_internal_enforcement (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation has an internal enforcement of the degrees of freedom. More...
static bool cs_equation_param_has_implicit_advection (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation induces an implicit treatment of the advection term. More...
static bool cs_equation_param_has_user_hook (const cs_equation_param_t *eqp)
 Ask if the parameters of the equation has activated a user hook to get a fine tuning of the cellwise system building. More...
static bool cs_equation_param_has_name (cs_equation_param_t *eqp, const char *name)
 Check if a cs_equation_param_t structure has its name member equal to the given name. More...
cs_equation_param_t * cs_equation_param_create (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
 Create a cs_equation_param_t structure. More...
static cs_equation_param_t * cs_equation_create_param (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
void cs_equation_param_copy_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fld_id)
 Copy the settings from one cs_equation_param_t structure to another one. The name is not copied. More...
void cs_equation_param_copy_bc (const cs_equation_param_t *ref, cs_equation_param_t *dst)
 Copy only the part dedicated to the boundary conditions and the DoF (degrees of freedom) enforcement from one cs_equation_param_t structure to another one. More...
static void cs_equation_copy_param_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid)
void cs_equation_param_clear (cs_equation_param_t *eqp)
 Free the contents of a cs_equation_param_t. More...
cs_equation_param_t * cs_equation_param_free (cs_equation_param_t *eqp)
 Free a cs_equation_param_t. More...
void cs_equation_param_set (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
 Set a parameter attached to a keyname in a cs_equation_param_t structure. More...
static void cs_equation_set_param (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
cs_param_sles_t * cs_equation_param_get_sles_param (cs_equation_param_t *eqp)
 Get the pointer to the set of parameters to handle the SLES solver associated to this set of equation parameters. More...
cs_param_saddle_t * cs_equation_param_get_saddle_param (cs_equation_param_t *eqp)
void cs_equation_param_set_sles (cs_equation_param_t *eqp)
 Set parameters for initializing SLES structures used for the resolution of the linear system. Settings are related to this equation. More...
void cs_equation_param_set_quadrature_to_all (cs_equation_param_t *eqp, cs_quadrature_type_t qtype)
 Apply the given quadrature rule to all existing definitions under the cs_equation_param_t structure. To get a more detailed control of the quadrature rule, please consider the function cs_xdef_set_quadrature. More...
void cs_equation_param_lock_settings (cs_equation_param_t *eqp)
 Lock settings to prevent from unwanted modifications. More...
void cs_equation_param_unlock_settings (cs_equation_param_t *eqp)
 Unlock settings. Be sure that is really wanted (inconsistency between the setup logging and what is used may appear) More...
void cs_equation_param_ensure_consistent_settings (cs_equation_param_t *eqp)
 At this stage, the numerical settings should not be modified anymore by the user. One makes a last set of modifications if needed to ensure a consistent numerical settings. More...
void cs_equation_param_log (const cs_equation_param_t *eqp)
 Print the detail of a cs_equation_param_t structure. More...
bool cs_equation_param_has_robin_bc (const cs_equation_param_t *eqp)
 Ask if the parameter settings of the equation has requested the treatment of Robin boundary conditions. More...
cs_xdef_t * cs_equation_add_ic_by_value (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here a constant value is set to all the unknows belonging to the given zone with name z_name. More...
cs_xdef_t * cs_equation_add_ic_by_qov (cs_equation_param_t *eqp, const char *z_name, double quantity)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the value set to each unknown belonging to the given zone with name z_name is such that the integral over the cells of the zone returns the requested quantity. More...
cs_xdef_t * cs_equation_add_ic_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the initial value for each unknown associated to the zone with name z_name is set according to an analytical function. More...
cs_xdef_t * cs_equation_add_ic_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Case of a definition by a DoF function. More...
void cs_equation_add_xdef_bc (cs_equation_param_t *eqp, cs_xdef_t *xdef)
 Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structure is now managed by the current cs_equation_param_t structure. More...
cs_xdef_t * cs_equation_add_bc_by_value (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
 Define and initialize a new structure to set a boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More...
cs_xdef_t * cs_equation_add_bc_by_array (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
cs_xdef_t * cs_equation_add_bc_by_field (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field)
cs_xdef_t * cs_equation_add_bc_by_analytic (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More...
cs_xdef_t * cs_equation_add_bc_by_time_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_time_func_t *t_func, void *input)
 Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t Definition relying on a cs_time_func_t function pointer. More...
cs_xdef_t * cs_equation_add_bc_by_dof_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Define and initialize a new structure to set a boundary condition related to the given cs_equation_param_t structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_real_t *array, bool is_owner, bool full_length)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an array. More...
cs_xdef_t * cs_equation_find_bc (cs_equation_param_t *eqp, const char *z_name)
 Return pointer to existing boundary condition definition structure for the given equation param structure and zone. More...
void cs_equation_remove_bc (cs_equation_param_t *eqp, const char *z_name)
 Remove boundary condition from the given equation param structure for a given zone. More...
void cs_equation_remove_ic (cs_equation_param_t *eqp, const char *z_name)
 Remove initial condition from the given equation param structure for a given zone. More...
void cs_equation_add_sliding_condition (cs_equation_param_t *eqp, const char *z_name)
 Define and initialize a new structure to set a sliding boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More...
void cs_equation_add_diffusion (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the Laplacian operator for the equation associated to the given cs_equation_param_t structure Laplacian means div-grad (either for vector-valued or scalar-valued equations) More...
void cs_equation_add_curlcurl (cs_equation_param_t *eqp, cs_property_t *property, int inversion)
 Associate a new term related to the curl-curl operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_graddiv (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the grad-div operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_time (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the time derivative operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_advection (cs_equation_param_t *eqp, cs_adv_field_t *adv_field)
 Associate a new term related to the advection operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_advection_scaling_property (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a scaling property to the advection. More...
int cs_equation_add_reaction (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the reaction operator for the equation associated to the given cs_equation_param_t structure. More...
cs_xdef_t * cs_equation_add_source_term_by_val (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value. More...
cs_xdef_t * cs_equation_add_source_term_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical function. More...
cs_xdef_t * cs_equation_add_source_term_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function. More...
cs_xdef_t * cs_equation_add_source_term_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value (cs_equation_param_t *eqp, const char *z_name, double *val)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant value. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov (cs_equation_param_t *eqp, const char *z_name, double *quantity)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant quantity distributed over the associated zone's volume. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an analytical function. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a DoF function. More...
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh vertices. The spatial discretization scheme for the given equation has to be CDO vertex-based or CDO vertex+cell-based schemes. More...
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discretization scheme for the given equation has to be CDO edge-based schemes. More...
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discretization scheme for the given equation has to be CDO face-based schemes. More...
cs_enforcement_param_t * cs_equation_add_cell_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
 Add an enforcement of the value related to the degrees of freedom associated to the list of selected cells. More...
cs_enforcement_param_t * cs_equation_add_or_replace_cell_enforcement (cs_equation_param_t *eqp, int enforcement_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
 Add a new enforcement if enforcement_id does not exist or replace it otherwise. Enforcement of the value related to the degrees of freedom associated to the list of selected cells. More...
void cs_equation_time_control_clear (cs_equation_param_t *eqp)
 Clear time_control data from the given equation param. More...
void cs_equation_time_control_add (cs_equation_param_t *eqp, cs_time_control_t *time_control, bool shallow_copy)
 Add a time control instance to an equation param structure. More...
void cs_equation_time_control_add_default (cs_equation_param_t *eqp)
 Add a time control instance to an equation param structure based on default values (hard copy). More...
◆ CS_EQUATION_BUILD_HOOK
◆ CS_EQUATION_CONVECTION
◆ CS_EQUATION_CURLCURL
◆ CS_EQUATION_DIFFUSION
◆ CS_EQUATION_FORCE_VALUES
◆ CS_EQUATION_GRADDIV
◆ CS_EQUATION_INSIDE_SYSTEM
◆ CS_EQUATION_LOCKED
◆ CS_EQUATION_POST_BALANCE
◆ CS_EQUATION_POST_NORMAL_FLUX
◆ CS_EQUATION_POST_PECLET
◆ CS_EQUATION_POST_UPWIND_COEF
◆ CS_EQUATION_REACTION
◆ CS_EQUATION_UNSTEADY
◆ CS_EQUATION_USER_TRIGGERED
◆ cs_equation_key_t
Enumerator
Set the value of the stabilization scaling coefficient when a CIP advection scheme is used. This value should be > 0
Choice in the way to extrapolate the advection field when building the advection operator
Kind of formulation of the advective term. There are two possible choices:
  • "conservative" (also called "divergence" formulation)
  • "non_conservative" (also called "gradient" formulation)
CS_EQKEY_ADV_SCHEME
Specify the type of numerical scheme for the advective term. The available choices depend on the space discretization scheme. Please refer to the section Set the advection scheme of the user guide for more details
Strategy used to handle the advection term
  • "fully_implicit" or "implicit" (default choice)
  • "linearized" or "implicit_linear"
  • "explicit" There is a difference between the two first choices when the advection term induces a non-linearity. In this situation, the first choice implies that a non-linear algorithm has to be used.
Value between 0 and 1 specifying the portion of upwind added to a centered discretization.
CS_EQKEY_AMG_TYPE
Specify which type of algebraic multigrid (AMG) to choose. Available choices are:
  • "boomer"/"boomer_v"/"bamg" --> Boomer AMG V-cycle multigrid. The HYPRE library is needed in this case during the installation process.
  • "boomer_w"/"bamg_w" --> Boomer AMG W-cycle multigrid. The HYPRE library is needed in this case during the installation process.
  • "gamg"/"gamg_v" --> GAMG V-cycle multigrid. The PETSc library is needed in this case during the installation process.
  • "gamg_w" --> GAMG W-cycle multigrid from the PETSc library. The PETSc library is needed in this case during the installation process.
  • "pcmg" --> MG multigrid as preconditioner from the PETSc library
  • "v_cycle" --> code_saturne's built-in multigrid with a V-cycle strategy
  • "k_cycle"/ "kamg" --> code_saturne's built-in multigrid with a K-cycle strategy (cf. Notay's articles on that subject).
Set the type of enforcement of the boundary conditions. Available choices are:
  • "algebraic": Modify the linear system so as to add the contribution of the Dirichlet in the right-hand side and replace the line associated to a Dirichlet BC by identity. This is a good choice for pure diffusinon or pure convection problem.
  • "penalization": Add a huge penalization coefficient on the diagonal term of the line related to DoFs associated a Dirichlet BC. The right-hand side is also modified to take into account this penalization. Be aware that it may worsen the matrix conditioning.
  • "weak": weak enforcement using the Nitsche method (there is also penalization term but the scaling is such that a moderate value (1-100) of the penalization coefficient is sufficient). This a good choice for convection/diffusion problem.
  • "weak_sym": Same as the "weak" option but with a modification so as to add a symmetric contribution to the system. If the problem yields a symmetric matrix. This choice is more relevant than "weak". This a good choice for a diffusion problem.
For HHO and CDO-Face based schemes, only the "penalization" and "algebraic" technique is available up to now.
Set the value of the penalization coefficient when "penalization" is activated The default value is 1e12. cf. CS_PARAM_BC_ENFORCE_PENALIZED
Set the value of the penalization coefficient when "weak" or "weak_sym" is activated. The default value is 100. cf. CS_PARAM_BC_ENFORCE_WEAK_NITSCHE or CS_PARAM_BC_ENFORCE_WEAK_SYM
CS_EQKEY_DO_LUMPING
Set how is defined each degree of freedom (DoF).
  • "de_rham" or "derham" (default): Evaluation at vertices for potentials, integral along a line for circulations, integral across the normal component of a face for fluxes and integral inside a cell for densities. In case of "potential", no quadrature rule is applied.
  • "average": DoF are defined as the average on the element
CS_EQKEY_EXTRA_OP
Set the additional post-processing to perform. Available choices are:
  • "balance" post-process the balance result in each control volume for each main term of an equation (diffusion, convection, time...)
  • "peclet" post-process an estimation of the Peclet number in each cell
  • "upwind_coef" post-process an estimation of the upwinding coefficient
  • "normal_flux" post-process the normal flux across boundary faces
Set the algorithm used for building the discrete Hodge operator used in the diffusion term. Available choices are:
  • "voronoi" --> leads to a diagonal discrete Hodge operator but is not consistent for all meshes. Require an "orthogonal" (or admissible) mesh; Warning: do not use this algorithm on general meshes.
  • "bubble" --> Reconstruction op. relying on a stabilization which is built with a bubble function associated to edges
  • "cost" or "ocs" --> Orthogonal decomposition of the Consistent and Stabilized part. (cost = COnsitent + STabilized) The stabilization part of the reconstruction op. is a piecewise constant polynom on a partition of each cell
  • "wbs" --> is robust and accurate but is limited to the reconstruction of potential-like degrees of freedom and needs a correct computation of the cell barycenter. Make sense only in the case of a CDOVB or CDOVCB scheme. In the case of tetrahedral meshes, the stiffness matrix is the same as the one encountered in FE P1 schemes
This key is only useful if the key CS_EQKEY_HODGE_DIFF_ALGO is set to "cost" or "ocs". keyval is either a name or a value:
  • "dga" corresponds to the value $ 1./3. $
  • "sushi" corresponds to the value $1./\sqrt(3.)$
  • "gcr" corresponds to the value $1$.
  • "frac23" or "2/3" corresponds to the value $2./3.$.
  • use an expression like "1.5", "9" for a user-defined value
Set the algorithm used for building the discrete Hodge operator used in the unsteady term. Available choices are:
  • "voronoi" --> (default) leads to diagonal discrete Hodge operator. It acts as a mass lumping.
  • "wbs" is robust and accurate but is less efficient. It needs a correct computation of the cell barycenter
Set the algorithm used for building the discrete Hodge operator used in the reaction term. Available choices are:
  • "voronoi" --> leads to diagonal discrete Hodge operator (similar to a lumping).
  • "wbs" --> (default) is robust and accurate but is limited to the reconstruction of potential-like degrees of freedom and needs a correct computation of the cell barycenter
CS_EQKEY_ITSOL
--> deprecated key (use CS_EQKEY_SOLVER instead)
CS_EQKEY_ITSOL_ATOL
--> deprecated key (use CS_EQKEY_SOLVER_ATOL instead)
CS_EQKEY_ITSOL_DTOL
--> deprecated key (use CS_EQKEY_SOLVER_DTOL instead)
CS_EQKEY_ITSOL_EPS
--> deprecated key (use CS_EQKEY_SOLVER_RTOL instead)
--> deprecated key (use CS_EQKEY_SOLVER_MAX_ITER instead)
--> deprecated key (use CS_EQKEY_SOLVER_RESNORM_TYPE instead)
--> deprecated key (use CS_EQKEY_SOLVER_RESTART instead)
CS_EQKEY_ITSOL_RTOL
CS_EQKEY_SOLVER
Specify the solver for the resolution of the linear system related to an equation. Please refer to the section Set the linear solver of the user guide for more details
Absolute tolerance factor for stopping the iterative process during the iterative resolution of a linear system related to an equation. Most iterative solver are not using this tolerance (the relative tolerance is always used). PETSc solvers use this information for instance. Please refer to CS_EQKEY_SOLVER_RTOL
  • Example: "1e-14"
Divergence tolerance factor for stopping the iterative process during the iterative resolution of a linear system related to an equation. Most iterative solver are not using this tolerance (the relative tolerance is always used). PETSc solvers use this information for instance. Please refer to CS_EQKEY_SOLVER_RTOL
  • Example: "1e3"
Maximum number of iterations for solving the linear system
  • Example: "2000"
Set if the solver can be skipt if some specific situation
  • Exmaples: "true" or "false
Normalized or not the residual before testing if one continues iterating for solving the linear system. This normalization is performed before applying the boundary conditions to avoid handling the penalization of Dirichlet boundary conditions. If the RHS norm is equal to zero, then the "vol_tot" option is used for rescaling the residual.
Available choices are: "false" or "none" (default) "rhs" "weighted_rhs" or "weighted" "filtered_rhs" or "filtered_rhs"
Maximum number of iterations before restarting a Krylov solver Only useful with GMRES, flexible GMRES or GCR solvers. This value has an impact on the memory footprint since one has to store a buffer of double with a size equal to restart*sizeof(solution array)
  • Example: "20"
Relative tolerance factor for stopping the iterative process during the iterative resolution of a linear system related to an equation.
  • Example: "1e-10"
CS_EQKEY_PRECOND
Specify the preconditioner associated to an iterative solver. Please refer to the section Set the preconditioner of the user guide for more details. Be careful since some options are only available with a given family of solvers. If this is the case, be sure that your installation has been installed with the appropriate library.
Specify the type of block preconditioner associated to a preconditioner. Useful for a vector-valued equation for instance, where each component can be associated to a block. Warning: Most of these options are available only with PETSc/HYPRE.
  • "none": no block preconditioner (default choice)
  • "diag": diagonal (or additive) block preconditoner
  • "lower": lower triangular (multiplicative) block preconditioner
  • "upper": upper triangular (multiplicative) block preconditioner
  • "symm"/"sgs": symmetric Gauss-Seidel block preconditioner
Absolute tolerance under which the iterative process stops when solving a saddle-point problem related to this equation. Read the description of the structure cs_param_saddle_t for more details.
  • Example: "1e-12"
Value of the scaling coefficient for the augmentation when solving a saddle-point problem. The initial system can namely be augmented with an operator for instance the grad-div operator when using an Augmented Lagrangian approach or the GKB solver.
  • Example: "1e2"
Divergence tolerance above which the iterative process stops when solving a saddle-point problem related to this equation. This triggers an error for divergence of the solver when detected. Read the description of the structure cs_param_saddle_t for more details.
  • Example: "1e3"
Max. number of iterations before stopping the "saddle-point" solver when solving a saddle-point problem related to this equation. This is different from CS_EQKEY_SOLVER_MAX_ITER This latter key is dedicated to the preconditioning of the (1,1)-block when a saddle-point system has to be solved. Read the description of the structure cs_param_saddle_t for more details.
  • Example: "1000"
Block preconditioner used to solve a saddle-point system.
Please refer to cs_param_saddle_precond_t for more details.
  • "none" No preconditioner is used (default)
  • "diag",
  • "lower",
  • "upper",
  • "sgs" (symmetric Gauss-Seidel)
Relative tolerance under which the iterative process stops when solving a saddle-point problem related to this equation. Read the description of the structure cs_param_saddle_t for more details.
  • Example: "1e-6"
Choice of the approximation of the Schur complement when solving a saddle-point problem. Not useful when there is no saddle-point problem to be solved. Some solvers or choices of preconditioner/solver may not need an approximation of the schur complement (ALU or GKB for instance). Please refer to cs_param_saddle_schur_approx_t for more details.
Available choices are: "none" or "identity" no Schur approximation --> the identity is used "diag_inv" use the inverse of the (1,1)-block diagonal "lumped_inv" use the inverse of the (1,1)-block after lumping "mass" use a scaled mass matrix for the space related to the (2,2)-block "mass_scaled_diag_inv" for a combination of "mass_scaled" and "diag_inv" "mass_scaled_lumped_inv" for a combination of "mass_scaled" and "lumped_inv"
Set the strategy/solver used to solve a saddle-point system.
Read the description of the structure cs_param_saddle_t for more details. Specify the solver for the resolution of the linear system related to an equation. Please refer to the section Solve a saddle-point linear system of the user guide for more details.
Strategy/solver used to solve a saddle-point system.
Available choices are: "cs" or "saturne" for "in-house" solver "petsc" or "mumps" for external libraries
Number of iterations before restarting a Krylov solver used as the main solver for a saddle-point problem. This key is useful when the main solver is a GMRES, a flexible GMRES or a GCR. Read the description of the structure cs_param_saddle_t for more details.
  • Example: "30"
Level of details displayed for the resolution of a saddle-point system
  • Examples: "0", "1", "2"
Level of details written by the code for the resolution of the linear system
  • Examples: "0", "1", "2" or higher
Set the space discretization scheme. Available choices are:
  • "cdo_vb" or "cdovb" for CDO vertex-based scheme
  • "cdo_vcb" or "cdovcb" for CDO vertex+cell-based scheme
  • "cdo_fb" or "cdofb" for CDO face-based scheme
  • "cdo_eb" or "cdoeb" for CDO edge-based scheme
  • "cdo_cb" or "cdocb" for CDO cell-based scheme
  • "hho_p1" for HHO schemes with $\mathbb{P}_1$ polynomial approximation
  • "hho_p2" for HHO schemes with $\mathbb{P}_2$ polynomial approximation
  • "mac_fb" for MAC face-based scheme and cartesian grid
Set the scheme for the temporal discretization. Available choices are:
  • "euler_implicit" or "forward_euler" (1st order)
  • "euler_explicit" or "backward_euler" (1st order, conditional stability)
  • "theta_scheme": Time scheme encompassing several other schemes according to the value of theta. One recovers for instance "euler_implicit" with theta equal to "1", "euler_explicit" with "0" or "crank_nicolson" with theta equal to "0.5"
  • "crank_nicolson": Shortcut to set a theta scheme with theta equal to 0.5. This time discretization is second_order in time accurate.
  • "bdf2": 2nd order, implicit time scheme
CS_EQKEY_TIME_THETA
Set a value betwwen 0 and 1 for the theta parameter when a "theta_scheme" is set for the time discretization. Only useful if CS_EQKEY_TIME_SCHEME is set to "theta_scheme".
  • Example: "0.75"
CS_EQKEY_VERBOSITY
Set the level of details written by the code for an equation. The higher the more detailed information is displayed.
  • "0" (default)
  • "1" detailed setup resume and coarse grain timer stats
  • "2" fine grain for timer stats
CS_EQKEY_N_KEYS
◆ cs_equation_type_t
Enumerator
Equation related to the groundwater flow module
Equation related to the Maxwell module
Equation related to the resolution of the Navier-Stokes system
  • Example: momentum, prediction, correction, energy...
Predefined equation (most part of the setting is already done)
  • Example: equation for the wall distance or ALE
Equation related to the heat transfer
Equation related to the solidification module
User-defined equation (no interaction with energy and momentum equations) Resolution is performed after all predefined equations have been solved.
CS_EQUATION_N_TYPES
◆ cs_equation_add_advection()
void cs_equation_add_advection ( cs_equation_param_t *  eqp,
cs_adv_field_t *  adv_field
[in,out]eqppointer to a cs_equation_param_t structure
[in]adv_fieldpointer to a cs_adv_field_t structure
◆ cs_equation_add_advection_scaling_property()
void cs_equation_add_advection_scaling_property ( cs_equation_param_t *  eqp,
cs_property_t *  property
[in]propertypointer to a cs_property_t structure
◆ cs_equation_add_bc_by_analytic()
cs_xdef_t * cs_equation_add_bc_by_analytic ( cs_equation_param_t *  eqp,
const char *  z_name,
cs_analytic_func_t *  analytic,
void *  input
[in]bc_typetype of boundary condition to add
[in]z_namename of the associated zone (if null or "" if all cells are considered)
[in]analyticpointer to an analytic function defining the value
[in]inputnull or pointer to a structure cast on-the-fly
a pointer to the new cs_xdef_t structure
[in]z_namename of the associated zone (if nullptr or "" if all cells are considered)
[in]inputnullptr or pointer to a structure cast on-the-fly
◆ cs_equation_add_bc_by_array()
cs_xdef_t * cs_equation_add_bc_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]z_namename of the related boundary zone
[in]locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t struct. (true or false)
[in]full_lengthif true, size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
a pointer to the new allocated cs_xdef_t structure
◆ cs_equation_add_bc_by_dof_func()
cs_xdef_t * cs_equation_add_bc_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
cs_dof_func_t *  func,
void *  input
[in]loc_flaglocation where values are computed
[in]funcpointer to cs_dof_func_t function
◆ cs_equation_add_bc_by_field()
cs_xdef_t * cs_equation_add_bc_by_field ( cs_equation_param_t *  eqp,
cs_field_t *  field
[in]fieldpointer to a cs_field_t structure
◆ cs_equation_add_bc_by_time_func()
cs_xdef_t * cs_equation_add_bc_by_time_func ( cs_equation_param_t *  eqp,
cs_time_func_t *  t_func,
void *  input
[in]t_funcpointer to an analytic function defining the value
◆ cs_equation_add_bc_by_value()
cs_xdef_t * cs_equation_add_bc_by_value ( cs_equation_param_t *  eqp,
cs_real_t *  values
[in]valuespointer to a array storing the values
◆ cs_equation_add_cell_enforcement()
cs_enforcement_param_t * cs_equation_add_cell_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_cells,
One assumes that values are interlaced if eqp->dim > 1 ref_value or elt_values has to be defined. If both parameters are defined, one keeps the definition in elt_values
[in]n_cellsnumber of selected cells
[in]cell_idslist of cell ids
[in]ref_valueignored if null
[in]cell_valueslist of associated values, ignored if null
a pointer to a cs_enforcement_param_t structure
[in]ref_valueignored if nullptr
[in]cell_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_curlcurl()
void cs_equation_add_curlcurl ( cs_equation_param_t *  eqp,
cs_property_t *  property,
int  inversion
[in]inversion1: true, false otherwise
[in]inversion> 0: true, false otherwise
◆ cs_equation_add_diffusion()
void cs_equation_add_diffusion ( cs_equation_param_t *  eqp,
◆ cs_equation_add_edge_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_edges,
[in]n_edgesnumber of edges to enforce
[in]edge_idslist of edges
[in]ref_valuedefault values or ignored (may be null)
[in]edge_valueslist of associated values, ignored if null
[in]ref_valuedefault values or ignored (may be nullptr)
[in]edge_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_face_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_faces,
[in]n_facesnumber of faces to enforce
[in]face_idslist of faces
[in]face_valueslist of associated values, ignored if null
[in]face_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_graddiv()
void cs_equation_add_graddiv ( cs_equation_param_t *  eqp,
◆ cs_equation_add_ic_by_analytic()
cs_xdef_t * cs_equation_add_ic_by_analytic ( cs_equation_param_t *  eqp,
void *  input
◆ cs_equation_add_ic_by_dof_func()
cs_xdef_t * cs_equation_add_ic_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
[in]loc_flagwhere information is computed
[in]funcpointer to a DoF function
◆ cs_equation_add_ic_by_qov()
cs_xdef_t * cs_equation_add_ic_by_qov ( cs_equation_param_t *  eqp,
double  quantity
[in]z_namename of the associated zone (if null or "" all cells are considered)
[in]quantityquantity to distribute over the mesh location
◆ cs_equation_add_ic_by_value()
cs_xdef_t * cs_equation_add_ic_by_value ( cs_equation_param_t *  eqp,
cs_real_t *  val
[in]z_namename of the associated zone (if nullptr or "" all cells are considered)
[in]valpointer to the value
◆ cs_equation_add_or_replace_cell_enforcement()
cs_enforcement_param_t * cs_equation_add_or_replace_cell_enforcement ( cs_equation_param_t *  eqp,
int  enforcement_id,
cs_lnum_t  n_cells,
[in]enforcement_idid of the enforcement to handle
◆ cs_equation_add_reaction()
int cs_equation_add_reaction ( cs_equation_param_t *  eqp,
the id related to the reaction term
◆ cs_equation_add_sliding_condition()
void cs_equation_add_sliding_condition ( cs_equation_param_t *  eqp,
const char *  z_name
◆ cs_equation_add_source_term_by_analytic()
cs_xdef_t * cs_equation_add_source_term_by_analytic ( cs_equation_param_t *  eqp,
cs_analytic_func_t *  func,
void *  input
[in]funcpointer to an analytical function
◆ cs_equation_add_source_term_by_array()
cs_xdef_t * cs_equation_add_source_term_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_equation_add_source_term_by_dof_func()
cs_xdef_t * cs_equation_add_source_term_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
[in]loc_flaglocation of element ids given as parameter
◆ cs_equation_add_source_term_by_val()
cs_xdef_t * cs_equation_add_source_term_by_val ( cs_equation_param_t *  eqp,
cs_real_t *  val
[in]valvalue to set
[in]valvalue to set
◆ cs_equation_add_time()
void cs_equation_add_time ( cs_equation_param_t *  eqp,
◆ cs_equation_add_vertex_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement ( cs_equation_param_t *  eqp,
[in]n_verticesnumber of vertices to enforce
[in]vertex_idslist of vertices
[in]vtx_valueslist of associated values, ignored if null
[in]vtx_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_volume_mass_injection_by_analytic()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic ( cs_equation_param_t *  eqp,
void *  input
◆ cs_equation_add_volume_mass_injection_by_array()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
cs_real_t *  array,
bool  is_owner,
bool  full_length
◆ cs_equation_add_volume_mass_injection_by_dof_func()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
◆ cs_equation_add_volume_mass_injection_by_qov()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov ( cs_equation_param_t *  eqp,
double *  quantity
[in]quantitypointer to quantity to distribute over the zone
◆ cs_equation_add_volume_mass_injection_by_value()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value ( cs_equation_param_t *  eqp,
double *  val
◆ cs_equation_add_xdef_bc()
void cs_equation_add_xdef_bc ( cs_equation_param_t *  eqp,
cs_xdef_t *  xdef
[in]xdefpointer to the cs_xdef_t structure to transfer
◆ cs_equation_copy_param_from()
static void cs_equation_copy_param_from ( const cs_equation_param_t *  ref,
cs_equation_param_t *  dst,
bool  copy_fid
inlinestatic
Deprecated:
Renamed tocs_equation_param_copy_from.
[in]refpointer to the reference cs_equation_param_t
[in,out]dstpointer to the cs_equation_param_t to update
[in]copy_fidcopy also the field id or not
◆ cs_equation_create_param()
static cs_equation_param_t * cs_equation_create_param ( const char *  name,
int  dim,
inlinestatic
Deprecated:
Renamed tocs_equation_param_create.
[in]namename of the equation
[in]typetype of equation
[in]dimdim of the variable associated to this equation
[in]default_bctype of boundary condition set by default
a pointer to a new allocated cs_equation_param_t structure
◆ cs_equation_find_bc()
cs_xdef_t * cs_equation_find_bc ( cs_equation_param_t *  eqp,
const char *  z_name
a pointer to the cs_xdef_t structure if present, or null
a pointer to the cs_xdef_t structure if present, or nullptr
◆ cs_equation_param_clear()
void cs_equation_param_clear ( cs_equation_param_t *  eqp)
The cs_equation_param_t structure itself is not freed, but all its sub-structures are freed.
This is useful for equation parameters which are accessed through field keywords.
◆ cs_equation_param_copy_bc()
void cs_equation_param_copy_bc ( const cs_equation_param_t *  ref,
◆ cs_equation_param_copy_from()
void cs_equation_param_copy_from ( const cs_equation_param_t *  ref,
bool  copy_fld_id
[in]copy_fld_idcopy also the field id or not
◆ cs_equation_param_create()
cs_equation_param_t * cs_equation_param_create ( const char *  name,
int  dim,
◆ cs_equation_param_ensure_consistent_settings()
void cs_equation_param_ensure_consistent_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_param_free()
cs_equation_param_t * cs_equation_param_free ( cs_equation_param_t *  eqp)
[in]eqppointer to a cs_equation_param_t
a null pointer
a null pointer
◆ cs_equation_param_get_saddle_param()
cs_param_saddle_t * cs_equation_param_get_saddle_param ( cs_equation_param_t *  eqp)
a pointer to a cs_param_saddle_t structure
◆ cs_equation_param_get_sles_param()
cs_param_sles_t * cs_equation_param_get_sles_param ( cs_equation_param_t *  eqp)
a pointer to a cs_param_sles_t structure
◆ cs_equation_param_has_convection()
static bool cs_equation_param_has_convection ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_curlcurl()
static bool cs_equation_param_has_curlcurl ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_diffusion()
static bool cs_equation_param_has_diffusion ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_graddiv()
static bool cs_equation_param_has_graddiv ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_implicit_advection()
static bool cs_equation_param_has_implicit_advection ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_internal_enforcement()
static bool cs_equation_param_has_internal_enforcement ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_name()
static bool cs_equation_param_has_name ( cs_equation_param_t *  eqp,
const char *  name
inlinestatic
true if the given eqp has the same name the one given as parameter otherwise false
◆ cs_equation_param_has_reaction()
static bool cs_equation_param_has_reaction ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_robin_bc()
bool cs_equation_param_has_robin_bc ( const cs_equation_param_t *  eqp)
true or false
◆ cs_equation_param_has_sourceterm()
static bool cs_equation_param_has_sourceterm ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_time()
static bool cs_equation_param_has_time ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_has_user_hook()
static bool cs_equation_param_has_user_hook ( const cs_equation_param_t *  eqp)
inlinestatic
true or false
◆ cs_equation_param_lock_settings()
void cs_equation_param_lock_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_param_log()
void cs_equation_param_log ( const cs_equation_param_t *  eqp)
◆ cs_equation_param_set()
void cs_equation_param_set ( cs_equation_param_t *  eqp,
const char *  keyval
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
◆ cs_equation_param_set_flag()
static void cs_equation_param_set_flag ( cs_equation_param_t *  eqp,
cs_flag_t  flag
inlinestatic
[in]flagflag to add
◆ cs_equation_param_set_quadrature_to_all()
void cs_equation_param_set_quadrature_to_all ( cs_equation_param_t *  eqp,
[in]qtypetype of quadrature to apply
If the default quadrature has been modified by the code, this function set the value of the quadrture to the given parameter whatever was the previous value.
◆ cs_equation_param_set_sles()
void cs_equation_param_set_sles ( cs_equation_param_t *  eqp)
◆ cs_equation_param_unlock_settings()
void cs_equation_param_unlock_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_remove_bc()
void cs_equation_remove_bc ( cs_equation_param_t *  eqp,
const char *  z_name
If no matching boundary condition is found, the function returns silently.
◆ cs_equation_remove_ic()
void cs_equation_remove_ic ( cs_equation_param_t *  eqp,
const char *  z_name
◆ cs_equation_set_param()
static void cs_equation_set_param ( cs_equation_param_t *  eqp,
const char *  keyval
inlinestatic
Deprecated:
Renamed tocs_equation_param_set.
◆ cs_equation_time_control_add()
void cs_equation_time_control_add ( cs_equation_param_t *  eqp,
cs_time_control_t *  time_control,
bool  shallow_copy
[in]eqppointer to equation param structure
[in]time_controlpointer to cs_time_control to add.
[in]shallow_copyshould the addition be only a shallow copy (pointer) or a real copy (data copy).
◆ cs_equation_time_control_add_default()
void cs_equation_time_control_add_default ( cs_equation_param_t *  eqp)
◆ cs_equation_time_control_clear()
void cs_equation_time_control_clear ( cs_equation_param_t *  eqp)
[in,out]eqpEquation param instance
