cs_field_t Class Reference
Field descriptor. More...
#include <cs_field.h>
+ Collaboration diagram for cs_field_t:
Public Member Functions
cs_span< cs_real_t > get_vals_s (const int time_id=0) const
 Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked. More...
cs_span_2d< cs_real_t > get_vals_v (const int time_id=0) const
 Return a 2D span view of field values. If the field is not a vector a fatal error is provoked. More...
cs_span_2d< cs_real_t > get_vals_t (const int time_id=0) const
 Return a 2D span view of field values. If the field is not a tensor a fatal error is provoked. More...
cs_alloc_mode_t get_vals_alloc_mode (const int time_id=0) const
 Get the allocation mode of the values array. More...
void update_size (void)
 Resize field values automatically (vals, val, val_pre) based on the corresponding mesh_location. More...
int set_key_int (int key_id, int value)
 Assign a integer value for a given key to a field. More...
int set_key_int (const char *key, int value)
int get_key_int (int key_id)
 Return a integer value for a given key associated with a field. More...
int get_key_int (const char *key)
int set_key_int_bits (int key_id, int mask)
 Set integer bits matching a mask to 1 for a given key for a field. More...
int set_key_int_bits (const char *key, int mask)
int clear_key_int_bits (int key_id, int mask)
 Set integer bits matching a mask to 0 for a given key for a field. More...
int clear_key_int_bits (const char *key, int mask)
int set_key_double (int key_id, double value)
 Assign a floating point value for a given key to a field. More...
int set_key_double (const char *key, double value)
double get_key_double (int key_id)
 Return a floating point value for a given key associated with a field. More...
double get_key_double (const char *key)
int set_key_str (int key_id, const char *str)
 Assign a character string for a given key to a field. More...
int set_key_str (const char *key, const char *str)
const char * get_key_str (int key_id)
 Return a character string for a given key associated with a field. More...
const char * get_key_str (const char *key)
Public Attributes
const char * name
int id
int type
int dim
int location_id
int n_time_vals
cs_real_t ** vals
cs_real_t * val
cs_real_t * val_pre
cs_real_t * grad
cs_field_bc_coeffs_t * bc_coeffs
bool is_owner
cs_array_2d< cs_real_t > ** _vals
Members of this field are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Member Function Documentation
◆ clear_key_int_bits() [1/2]
int clear_key_int_bits ( const char *  key,
int  mask
If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned. If the field category is not compatible with the key (as defined by its type flag), CS_FIELD_INVALID_CATEGORY is returned. If the data type does not match, CS_FIELD_INVALID_TYPE is returned. If the key value has been locked, CS_FIELD_LOCKED is returned.
0 in case of success, > 1 in case of error
[in]keykey string
[in]maskmask
◆ clear_key_int_bits() [2/2]
int clear_key_int_bits ( int  key_id,
int  mask
[in]key_idkey id
[in]maskmask
◆ get_key_double() [1/2]
double get_key_double ( const char *  key)
If the key id is not valid, or the value type or field category is not compatible, a fatal error is provoked.
value associated with the key id for this field
[in]keykey string
◆ get_key_double() [2/2]
double get_key_double ( int  key_id)
[in]key_idkey id
◆ get_key_int() [1/2]
int get_key_int ( const char *  key)
[in]keykey string
◆ get_key_int() [2/2]
int get_key_int ( int  key_id)
[in]key_idkey id
◆ get_key_str() [1/2]
const char * get_key_str ( const char *  key)
string associated with the key id for this field
[in]keykey string
◆ get_key_str() [2/2]
const char * get_key_str ( int  key_id)
[in]key_idkey id
◆ get_vals_alloc_mode()
cs_alloc_mode_t get_vals_alloc_mode ( const int  time_id = 0) const
cs_alloc_mode_t corresponding to the used allocation mode.
[in]time_idtime value id to get. 0 for val, 1 for val_pre
◆ get_vals_s()
cs_span< cs_real_t > get_vals_s ( const int  time_id = 0) const
cs_span<cs_real_t> view of field values.
◆ get_vals_t()
cs_span_2d< cs_real_t > get_vals_t ( const int  time_id = 0) const
cs_span_2d<cs_real_t>(:,6) view of field values.
◆ get_vals_v()
cs_span_2d< cs_real_t > get_vals_v ( const int  time_id = 0) const
cs_span_2d<cs_real_t>(:,3) view of field values.
◆ set_key_double() [1/2]
int set_key_double ( const char *  key,
double  value
[in]keykey string
[in]valuevalue
◆ set_key_double() [2/2]
int set_key_double ( int  key_id,
double  value
[in]key_idkey id
[in]valuevalue
◆ set_key_int() [1/2]
int set_key_int ( const char *  key,
int  value
[in]keykey string
[in]valuevalue
◆ set_key_int() [2/2]
int set_key_int ( int  key_id,
int  value
[in]key_idkey id
[in]valuevalue
◆ set_key_int_bits() [1/2]
int set_key_int_bits ( const char *  key,
int  mask
[in]keykey string
[in]maskmask
◆ set_key_int_bits() [2/2]
int set_key_int_bits ( int  key_id,
int  mask
[in]key_idkey id
[in]maskmask
◆ set_key_str() [1/2]
int set_key_str ( const char *  key,
const char *  str
[in]keykey string
[in]strstring associated with the key
◆ set_key_str() [2/2]
int set_key_str ( int  key_id,
const char *  str
[in]key_idkey id
◆ update_size()
void update_size ( void  )
Member Data Documentation
◆ _vals
◆ bc_coeffs
bc_coeffs
Boundary condition coefficients, for variable type fields
◆ dim
dim
Field dimension (usually 1 for scalar, 3 for vector, or 6 for symmetric tensor)
◆ grad
cs_real_t* grad
◆ id
id
Field id (based on order of field declaration, starting at 0)
◆ is_owner
is_owner
Ownership flag for values
◆ location_id
location_id
Id of matching mesh location
◆ n_time_vals
n_time_vals
Number of time values
◆ name
name
Canonical name
◆ type
type
Field type flag (sum of field mask constants, defining if a field is a variable, a property, ...)
◆ val
val
For each active location, pointer to matching values array
◆ val_pre
val_pre
For each active location, pointer to matching previous values array (only if n_time_vals > 1)
◆ vals
vals
vals[0][:] is a pointer to val vals[1][:] is a pointer to val_pre vals[p][:] is a pointer to p ith previous field values
The documentation for this class was generated from the following files:
