cs_adv_field_t Struct Reference
#include <cs_advection_field.h>
+ Collaboration diagram for cs_adv_field_t:
Public Attributes
int id
char *restrict name
cs_advection_field_status_t status
cs_flag_t post_flag
int vtx_field_id
int cell_field_id
int bdy_field_id
int int_field_id
cs_xdef_t * definition
int n_bdy_flux_defs
cs_xdef_t ** bdy_flux_defs
short int * bdy_def_ids
Member Data Documentation
◆ bdy_def_ids
short int* bdy_def_ids
◆ bdy_field_id
bdy_field_id
id to retrieve the related cs_field_t structure corresponding to the value of the normal flux across boundary faces. It's always defined since it's used for dealing with the boundary conditions.
◆ bdy_flux_defs
bdy_flux_defs
Array of pointers to the definitions of the normal flux at the boundary
◆ cell_field_id
cell_field_id
id to retrieve the related cs_field_t structure. It's always defined since it's used during the building of the advection scheme
◆ definition
definition
pointer to the generic structure used to define the advection field. We assume that only one definition is available (i.e. there is a unique zone related to "cells").
◆ id
id
identification number
◆ int_field_id
int_field_id
id to retrieve the related cs_field_t structure corresponding to the value of the normal flux across interior faces. It's always defined when the advection field arise from the resolution of the Navier-Stokes system with the legacy FV solver.
◆ n_bdy_flux_defs
n_bdy_flux_defs
Number of definitions related to the normal flux at the boundary
◆ name
name
name of the advection field
◆ post_flag
post_flag
short descriptor dedicated to postprocessing
◆ status
status
category (user, navsto, gwf...) and type (velocity, flux...) of the advection field
◆ vtx_field_id
vtx_field_id
id to retrieve the related cs_field_t structure (-1 if not used)
