cs_param_saddle_t Struct Reference
Structure storing all metadata related to the resolution of a saddle-point linear system. A saddle-point system is depicted as. More...
#include <cs_param_saddle.h>
+ Collaboration diagram for cs_param_saddle_t:
Public Attributes
int verbosity
char * name
const cs_param_sles_t * block11_sles_param
void * context
Main parameter settings
Set of parameters to drive the resolution of a saddle-point system
cs_param_solver_class_t solver_class
cs_param_saddle_solver_t solver
cs_param_saddle_precond_t precond
cs_param_convergence_t cvg_param
Schur complement approximation
Set of parameters to drive the resolution of the pressure-related block. This is often a Schur complement approximation to B.A^-1.Bt
cs_param_saddle_schur_approx_t schur_approx
cs_param_sles_t * schur_sles_param
| A : Bt | where A is the (1,1) block |--—:--—| Bt is the (1,2) block which the transposed operator | B : 0 | w.r.t. B, the (2,1)-block
According t the choice of the solver, the saddle-point system is totally or partially assembled.
Member Data Documentation
◆ block11_sles_param
block11_sles_param
Set of parameters used to solve (1,1)-block i.e. the A matrix. This is shared with the cs_equation_param_t structure.
◆ context
void* context
◆ cvg_param
cvg_param
Structure storing the parameters to know if an iterative process has to stop (convergence or divergence). These criteria are related the iterative algorithm used to solve the saddle-point system. This is the case for instance with an Uzawa or GKB algorithm.
◆ name
name
name of the saddle system or NULL (not mandatory). If NULL, the name of the (1,1)-block is used.
◆ precond
precond
Type of preconditioner for the saddle-point system which is viewed as a 2x2 block matrix.
◆ schur_approx
schur_approx
Choice of the way of preconditioning the schur approximation
◆ schur_sles_param
schur_sles_param
Set of parameters used to solve the Schur complement if needed. This depends on the type of Schur approximation which has been chosen.
◆ solver
solver
Type of solver to solve the saddle-point system If solver is set to CS_PARAM_SADDLE_N_SOLVERS, then there is no need to solve a saddle-point system.
◆ solver_class
solver_class
class of SLES to consider (advanced usage)
◆ verbosity
verbosity
verbosity (level of information displayed)
