cs_equation.cpp File Reference
#include <ctype.h>
#include <float.h>
#include "base/cs_mem.h"
#include "alge/cs_sles.h"
#include "base/cs_array.h"
#include "base/cs_log.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "base/cs_range_set.h"
#include "base/cs_timer_stats.h"
#include "cdo/cs_cdo_toolbox.h"
#include "cdo/cs_cdocb_scaleq.h"
#include "cdo/cs_cdoeb_vecteq.h"
#include "cdo/cs_cdofb_scaleq.h"
#include "cdo/cs_cdofb_vecteq.h"
#include "cdo/cs_cdovb_scaleq.h"
#include "cdo/cs_cdovb_vecteq.h"
#include "cdo/cs_cdovcb_scaleq.h"
#include "cdo/cs_evaluate.h"
#include "cdo/cs_hho_scaleq.h"
#include "cdo/cs_hho_vecteq.h"
#include "cdo/cs_macfb_vecteq.h"
#include "cdo/cs_equation.h"
+ Include dependency graph for cs_equation.cpp:
Macros
#define CS_EQUATION_DBG   0
int cs_equation_get_n_equations (void)
 Retrieve the number of equations. More...
cs_equation_t * cs_equation_by_name (const char *eqname)
 Find the cs_equation_t structure with name eqname Return null if not find. More...
cs_equation_t * cs_equation_by_field_name (const char *field_name)
 Return the pointer to a cs_equation_t structure thanks to the field name of the variable field associated to a cs_equation_t structure. More...
bool cs_equation_has_field_name (const cs_equation_t *eq, const char *fld_name)
 Check if the asociated field to a cs_equation_t structure has name equal to fld_name. More...
cs_equation_param_t * cs_equation_param_by_name (const char *eqname)
 Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equation name. More...
cs_equation_param_t * cs_equation_param_by_field_name (const char *field_name)
 Return the cs_equation_param_t structure related to a cs_equation_t structure thanks to the field name of the variable field associated to a cs_equation_t structure. More...
cs_equation_param_t * cs_equation_get_param (const cs_equation_t *eq)
 Return the cs_equation_param_t structure associated to a cs_equation_t structure. More...
cs_equation_t * cs_equation_by_id (int eq_id)
 Find the cs_equation_t structure with id eq_id Return null if not find. More...
const char * cs_equation_get_name (const cs_equation_t *eq)
 Return the name related to the given cs_equation_t structure. More...
int cs_equation_get_id (const cs_equation_t *eq)
 Return the id number related to the given cs_equation_t structure. More...
cs_field_t * cs_equation_get_field (const cs_equation_t *eq)
 Return the field structure associated to a cs_equation_t structure. More...
int cs_equation_get_field_id (const cs_equation_t *eq)
 Return the id related to the variable field structure associated to the cs_equation_t structure. More...
const char * cs_equation_get_field_name (const cs_equation_t *eq)
 Return the name related to the variable field structure associated to the given cs_equation_t structure. More...
const cs_range_set_t * cs_equation_get_range_set (const cs_equation_t *eq)
 Return the range set structure associated to a cs_equation_t structure. One assumes that there is only one block (it could be a split block) otherwise this means that one handles systems of equations. More...
cs_gnum_t cs_equation_get_global_n_dofs (const cs_equation_t *eq, const cs_cdo_quantities_t *cdoq)
 Return the global number of degrees of freedom associated to this cs_equation_t structure. More...
cs_field_t * cs_equation_get_boundary_flux (const cs_equation_t *eq)
 Return the field structure for the (normal) boundary flux associated to a cs_equation_t structure. More...
cs_equation_builder_t * cs_equation_get_builder (const cs_equation_t *eq)
 Return the cs_equation_builder_t structure associated to a cs_equation_t structure. Only for an advanced usage. More...
void * cs_equation_get_scheme_context (const cs_equation_t *eq)
 Return a pointer to a structure useful to handle low-level operations for the given equation. More...
cs_equation_core_t cs_equation_get_core_structure (const cs_equation_t *eq)
cs_real_t * cs_equation_get_source_term_array (const cs_equation_t *eq)
 Return a pointer to an array of values corresponding to the values of the source terms (cumulated values if several source terms are defined) More...
cs_property_t * cs_equation_get_diffusion_property (const cs_equation_t *eq)
 Return a pointer to the cs_property_t structure associated to the diffusion term for this equation (nullptr if not activated). More...
cs_property_t * cs_equation_get_time_property (const cs_equation_t *eq)
 Return a pointer to the cs_property_t structure associated to the unsteady term for this equation (nullptr if not activated). More...
cs_property_t * cs_equation_get_reaction_property (const cs_equation_t *eq, const int reaction_id)
 Return a pointer to the cs_property_t structure associated to the reaction term with id equal to reaction_id and related to this equation. More...
cs_param_time_scheme_t cs_equation_get_time_scheme (const cs_equation_t *eq)
 Return the type of numerical scheme used for the discretization in time. More...
cs_real_t cs_equation_get_theta_time_val (const cs_equation_t *eq)
 Return the value of the theta parameter in theta time scheme discretization. More...
cs_param_space_scheme_t cs_equation_get_space_scheme (const cs_equation_t *eq)
 Return the type of numerical scheme used for the discretization in space. More...
int cs_equation_get_space_poly_degree (const cs_equation_t *eq)
 Return the max. degree used in the polynomial basis for the space discretization. More...
int cs_equation_get_var_dim (const cs_equation_t *eq)
 Return the dimension of the variable solved by this equation. More...
cs_equation_type_t cs_equation_get_type (const cs_equation_t *eq)
 Return the type of equation for the given equation structure. More...
double cs_equation_get_time_eval (const cs_time_step_t *ts, const cs_equation_t *eq)
 Estimate the time at which the evaluation of properties related to the different terms of an equation should be done. More...
cs_flag_t cs_equation_get_flag (const cs_equation_t *eq)
 Return the flag associated to an equation. More...
void cs_equation_set_flag (cs_equation_t *eq, cs_flag_t flag)
 Redefine the flag associated to an equation. More...
void cs_equation_add_build_hook (cs_equation_t *eq, void *context, cs_equation_build_hook_t *func)
 Add a hook function to enable an advanced control during the cellwise system building. Only for an advanced usage. The context may be set to null if there is no need to get additional information. More...
bool cs_equation_is_steady (const cs_equation_t *eq)
 Return true is the given equation is steady otherwise false. More...
bool cs_equation_uses_new_mechanism (const cs_equation_t *eq)
 Return true is the given equation follows the new mechanism otherwise false Only HHO and MAC schemes rely on the older mechanism. More...
cs_equation_t * cs_equation_add (const char *eqname, const char *varname, cs_equation_type_t eqtype, int dim, cs_param_bc_type_t default_bc)
 Add a new equation structure and set a first set of parameters. More...
cs_equation_t * cs_equation_add_user (const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc)
 Add a new user equation structure and set a first set of parameters. More...
cs_equation_t * cs_equation_add_user_tracer (const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc, cs_property_t *time_pty, cs_adv_field_t *adv, cs_property_t *diff_pty)
 Add a new user transport equation and set a first set of parameters If time_pty is nullptr, then no unsteady term is added. If adv is nullptr, then no advection term is added. If diff_pty is nullptr, then no diffusion term is added. More...
void cs_equation_destroy_all (void)
 Destroy all cs_equation_t structures. More...
bool cs_equation_needs_steady_state_solve (void)
 Check if a steady-state computation is requested according to the setting. More...
void cs_equation_log_monitoring (const cs_time_step_t *ts, const cs_cdo_quantities_t *cdoq)
 Print a synthesis of the monitoring information in the performance file. More...
void cs_equation_get_count (int *n_equations, int *n_predef_equations, int *n_user_equations)
 Get the count of equations of each macro type. More...
void cs_equation_log_setup (void)
 Summarize all cs_equation_t structures. More...
void cs_equation_set_default_param (cs_equation_key_t key, const char *keyval)
 Set a parameter attached to a keyname for the default settigns. More...
void cs_equation_set_sles (void)
 Setup the linear algebra requirements. More...
void cs_equation_init_sharing (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step, cs_flag_t cb_scheme_flag, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag, cs_flag_t mac_scheme_flag)
 Set shared pointers to the main structures. Associate these structures among the activated class of discretization schemes. More...
void cs_equation_finalize_sharing (cs_flag_t cb_scheme_flag, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag, cs_flag_t mac_scheme_flag)
 Free shared local structures among the discretization schemes. More...
bool cs_equation_set_functions (void)
 Assign a set of pointer functions for managing the cs_equation_t structure during the computation. More...
void cs_equation_lock_settings (void)
 After this call, parameters related to an equation are set once for all. More...
void cs_equation_predefined_create_field (int n_previous, cs_equation_t *eq)
 Create a field structure related to the predefined equation given as parameter. This includes an equation associated to all modules and also the wall distance or mesh deformation computations for instance. More...
void cs_equation_user_create_fields (void)
 Create a field structure related to all user-defined equations. More...
void cs_equation_define_builders (const cs_mesh_t *mesh)
 Allocate and define the builder structure. More...
void cs_equation_define_context_structures (void)
 Allocate and define the context structure associated to each equation. More...
void cs_equation_define_core_structure (const cs_equation_t *eq, cs_equation_core_t **p_core)
 Build a pointer to a core structure. If the input core structure is not allocated, then one allocates the structure. More...
void cs_equation_init_field_values (const cs_mesh_t *mesh, const cs_time_step_t *ts)
 Set the initialize condition to all variable fields associated to each cs_equation_t structure. More...
void cs_equation_build_system (const cs_mesh_t *mesh, cs_equation_t *eq)
 Build the linear system for this equation (deprecated). Only for HHO schemes. More...
void cs_equation_solve_deprecated (const cs_mesh_t *mesh, cs_equation_t *eq)
 Solve the linear system for this equation (deprecated). Only for HHO schemes. More...
void cs_equation_solve_steady_state (const cs_mesh_t *mesh, cs_equation_t *eq)
 Build and then solve the linear system for this equation when the goal is to find the steady state. More...
void cs_equation_solve (bool cur2prev, const cs_mesh_t *mesh, cs_equation_t *eq)
 Build and then solve the linear system for an equation with an unsteady term. More...
void cs_equation_current_to_previous (const cs_equation_t *eq)
 Apply the current to previous to all fields (and potentially arrays) related to an equation. This function fas to be called when a solve step is called with the parameter: cur2prev = false. More...
void cs_equation_get_cellwise_builders (const cs_equation_t *eq, cs_cell_sys_t **csys, cs_cell_builder_t **cb)
 For a given equation, retrieve the related cellwise builder structures: cs_cell_builder_t and cs_cell_system_t structures. More...
cs_real_t * cs_equation_get_cell_values (const cs_equation_t *eq, bool previous)
 For a given equation, retrieve an array of values related to each cell of the mesh for the unknowns. More...
cs_real_t * cs_equation_get_face_values (const cs_equation_t *eq, bool previous)
 For a given equation, retrieve an array of values related to each face of the mesh for the unknowns. More...
cs_real_t * cs_equation_get_edge_values (const cs_equation_t *eq, bool previous)
 For a given equation, retrieve an array of values related to each edge of the mesh for the unknowns. More...
cs_real_t * cs_equation_get_vertex_values (const cs_equation_t *eq, bool previous)
 For a given equation, retrieve an array of values related to each vertex of the mesh for the unknowns. More...
void cs_equation_integrate_variable (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, cs_real_t *result)
 Compute the integral over the domain of the current variable field associated to the given equation. Parallel synchronization is performed in this function. No need to do it outside. More...
void cs_equation_compute_boundary_diff_flux (const cs_equation_t *eq, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t *dof_vals, const cs_real_t *cell_vals, cs_real_t t_eval, cs_real_t *diff_flux)
 Compute the diffusive flux across all boundary faces According to the space discretization scheme, the size of the resulting array differs. For Vb and VCb schemes, this array relies on the bf2v adjacency. More...
void cs_equation_compute_flux_across_plane (const cs_equation_t *eq, const char *ml_name, const cs_real_3_t direction, cs_real_t *diff_flux, cs_real_t *conv_flux)
 Compute the diffusive and convective flux across a plane defined by a mesh location structure attached to the name ml_name. More...
void cs_equation_compute_diffusive_flux (const cs_equation_t *eq, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t *dof_vals, const cs_real_t *cell_vals, cs_flag_t location, cs_real_t t_eval, cs_real_t *diff_flux)
 Computation of the diffusive flux across the requested location. If the location is not the "natural" one (which depends on the space discretization scheme) then the diffusive flux is interpolated and thus there is an approximation. The computation is threaded and performed cell-wise. More...
void cs_equation_compute_vtx_field_gradient (const cs_equation_t *eq, cs_real_t *v_gradient)
 Cellwise computation of the discrete gradient at vertices. More...
void cs_equation_compute_peclet (const cs_equation_t *eq, const cs_time_step_t *ts, cs_real_t peclet[])
 Compute and post-process Peclet number if requested. More...
void cs_equation_read_extra_restart (cs_restart_t *restart)
 Write into the restart file additionnal arrays (not defined as fields) but useful for the checkpoint/restart process. More...
void cs_equation_write_extra_restart (cs_restart_t *restart)
void cs_equation_post_balance (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts)
 Predefined extra-operations related to all equations. More...
void cs_equation_apply_stiffness (cs_equation_t *eq, const cs_property_t *property, const cs_real_t *pot, cs_flag_t loc_res, cs_real_t *res)
 Compute the cellwise stiffness matrix associated to the property given as a parameter and apply it to the pot array to define the resulting array associated to entities defined at loc_res. More...
void cs_equation_extra_post (void)
 Predefined extra-operations related to equations according to the type of numerical scheme (for the space discretization) More...
static int _n_equations = 0
static int _n_predef_equations = 0
static int _n_user_equations = 0
static cs_equation_t ** _equations = nullptr
◆ CS_EQUATION_DBG
◆ cs_equation_add()
cs_equation_t * cs_equation_add ( const char *  eqname,
const char *  varname,
int  dim,
[in]eqnamename of the equation
[in]varnamename of the variable associated to this equation
[in]eqtypetype of equation (user, predefined...)
[in]dimdimension of the unknow attached to this equation
[in]default_bctype of boundary condition set by default
a pointer to the new allocated cs_equation_t structure
◆ cs_equation_add_build_hook()
void cs_equation_add_build_hook ( cs_equation_t *  eq,
void *  context,
cs_equation_build_hook_t *  func
[in,out]eqpointer to the cs_equation_t stucture to update
[in]contextpointer to a structure for additional information
[in]funcpointer to the user function
◆ cs_equation_add_user()
cs_equation_t * cs_equation_add_user ( const char *  eqname,
int  dim,
◆ cs_equation_add_user_tracer()
cs_equation_t * cs_equation_add_user_tracer ( const char *  eqname,
int  dim,
cs_property_t *  time_pty,
cs_adv_field_t *  adv,
cs_property_t *  diff_pty
Add a new user transport equation and set a first set of parameters If time_pty is null, then no unsteady term is added. If adv is null, then no advection term is added. If diff_pty is null, then no diffusion term is added.
[in]time_ptyproperty related to the unsteady term
[in]advadvection field
[in]diff_ptyproperty related to the diffusion term
◆ cs_equation_apply_stiffness()
void cs_equation_apply_stiffness ( cs_equation_t *  eq,
const cs_property_t *  property,
const cs_real_t *  pot,
cs_flag_t  loc_res,
cs_real_t *  res
[in]eqpointer to a cs_equation_t structure
[in]propertypointer to the property to consider
[in]potarray to multiply with the stiffness matrix
[in]loc_reslocation of entities in the resulting array
[in,out]resresulting array
◆ cs_equation_build_system()
void cs_equation_build_system ( const cs_mesh_t *  mesh,
cs_equation_t *  eq
[in,out]eqpointer to a cs_equation_t structure
◆ cs_equation_by_field_name()
cs_equation_t * cs_equation_by_field_name ( const char *  field_name)
[in]field_namename of the field
a pointer to a cs_equation_t structure or null if not found
◆ cs_equation_by_id()
cs_equation_t * cs_equation_by_id ( int  eq_id)
Find the cs_equation_t structure with id eq_id Return nullptr if not found.
[in]eq_idid of the equation to find
◆ cs_equation_by_name()
cs_equation_t * cs_equation_by_name ( const char *  eqname)
Find the cs_equation_t structure with name eqname Return nullptr if not found.
[in]eqnamename of the equation to find
◆ cs_equation_compute_boundary_diff_flux()
void cs_equation_compute_boundary_diff_flux ( const cs_equation_t *  eq,
const cs_property_t *  diff_pty,
const cs_real_t *  dof_vals,
const cs_real_t *  cell_vals,
cs_real_t  t_eval,
cs_real_t *  diff_flux
If eqp is set to nullptr, then one uses eq->param. Otherwise, one checks that the given eqp structure is relevant (same space discretization as eq->param) Using a different eqp allows one to build a diffusive flux relying on another property associated to the diffusion term.
If pty is set to nullptr then one considers the diffusion property related to the eqp structure which will be used. Otherwise, one considers the one given.
If dof_vals is set to nullptr (and cell_values too), then one uses the current values of the variable associated to the given equation (cs_equation_get_*_values functions). The calling function has to ensure that the location of the values is relevant with the one expected with the given equation. Using dof_vals (and possibly cell_vals) allows one to compute the diffusive flux for an array of values which is not the one associated to the given equation.
cell_values is not useful for CDO vertex-based schemes while it is mandatory for CDO vertex+cell-based schemes and CDO face-based schemes. For CDO cell-based schemes, the flux is a variable so that neither dof_vals nor cell_vals are used.
Be aware that the boundary conditions are applied through the equation builder structure which has to be consistent with what is used in eqp
[in]eqpset of equation parameters to use or nullptr
[in]diff_ptydiffusion property or nullptr
[in]dof_valsvalues at the location of the degrees of freedom
[in]cell_valsvalues at the cell centers or nullptr
[in]t_evaltime at which one the property is evaluated
[in,out]diff_fluxvalue of the diffusive part of the flux
◆ cs_equation_compute_diffusive_flux()
void cs_equation_compute_diffusive_flux ( const cs_equation_t *  eq,
cs_flag_t  location,
cs_real_t  t_eval,
If pty is set to null then one considers the diffusion property related to the eqp structure which will be used. Otherwise, one considers the one given.
If dof_vals is set to null (and cell_values too), then one uses the current values of the variable associated to the given equation (cs_equation_get_*_values functions). The calling function has to ensure that the location of the values is relevant with the one expected with the given equation. Using dof_vals (and possibly cell_vals) allows one to compute the diffusive flux for an array of values which is not the one associated to the given equation.
[in]locationindicate where the flux has to be computed
[in,out]diff_fluxvalue of the diffusive flux (must be allocated)
◆ cs_equation_compute_flux_across_plane()
void cs_equation_compute_flux_across_plane ( const cs_equation_t *  eq,
const char *  ml_name,
cs_real_t *  diff_flux,
cs_real_t *  conv_flux
[in]ml_namename of the related mesh location
[in]directionvector indicating in which direction flux is > 0
[in,out]conv_fluxvalue of the convective part of the flux
◆ cs_equation_compute_peclet()
void cs_equation_compute_peclet ( const cs_equation_t *  eq,
const cs_time_step_t *  ts,
cs_real_t  peclet[]
[in]tspointer to a cs_time_step_t struct.
[in,out]pecletpointer to an array storing the resulting Peclet number in each cell
◆ cs_equation_compute_vtx_field_gradient()
void cs_equation_compute_vtx_field_gradient ( const cs_equation_t *  eq,
cs_real_t *  v_gradient
[in,out]v_gradientgradient at vertices
◆ cs_equation_current_to_previous()
void cs_equation_current_to_previous ( const cs_equation_t *  eq)
◆ cs_equation_define_builders()
void cs_equation_define_builders ( const cs_mesh_t *  mesh)
◆ cs_equation_define_context_structures()
void cs_equation_define_context_structures ( void  )
◆ cs_equation_define_core_structure()
void cs_equation_define_core_structure ( const cs_equation_t *  eq,
cs_equation_core_t **  p_core
[in,out]p_coredouble pointer to a core structure to build
◆ cs_equation_destroy_all()
void cs_equation_destroy_all ( void  )
◆ cs_equation_extra_post()
void cs_equation_extra_post ( void  )
◆ cs_equation_finalize_sharing()
void cs_equation_finalize_sharing ( cs_flag_t  cb_scheme_flag,
[in]cb_scheme_flagmetadata for Cb schemes
[in]eb_scheme_flagmetadata for Eb schemes
[in]fb_scheme_flagmetadata for Fb schemes
[in]vb_scheme_flagmetadata for Vb schemes
[in]vcb_scheme_flagmetadata for V+C schemes
[in]hho_scheme_flagmetadata for HHO schemes
[in]mac_scheme_flagmetadata for MAC schemes
◆ cs_equation_get_boundary_flux()
cs_field_t * cs_equation_get_boundary_flux ( const cs_equation_t *  eq)
a cs_field_t structure or nullptr
◆ cs_equation_get_builder()
cs_equation_builder_t * cs_equation_get_builder ( const cs_equation_t *  eq)
a cs_equation_builder_t structure or null if not found
◆ cs_equation_get_cell_values()
cs_real_t * cs_equation_get_cell_values ( const cs_equation_t *  eq,
bool  previous
a pointer to an array of cell values
◆ cs_equation_get_cellwise_builders()
void cs_equation_get_cellwise_builders ( const cs_equation_t *  eq,
cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
[out]cbpointer to a pointer on a cs_cell_sys_t structure
[out]csyspointer to a pointer on a cs_cell_builder_t structure
◆ cs_equation_get_core_structure()
cs_equation_core_t cs_equation_get_core_structure ( const cs_equation_t *  eq)
structure storing the main structure associated to an equation
◆ cs_equation_get_count()
void cs_equation_get_count ( int *  n_equations,
int *  n_predef_equations,
int *  n_user_equations
[out]n_equationstotal number of equations
[out]n_predef_equationsnumber of predefined equations
[out]n_user_equationsnumber of user equations
◆ cs_equation_get_diffusion_property()
cs_property_t * cs_equation_get_diffusion_property ( const cs_equation_t *  eq)
Return a pointer to the cs_property_t structure associated to the diffusion term for this equation (null if not activated).
a pointer to a cs_property_t structure
◆ cs_equation_get_edge_values()
cs_real_t * cs_equation_get_edge_values ( const cs_equation_t *  eq,
bool  previous
a pointer to an array of edge values
◆ cs_equation_get_face_values()
cs_real_t * cs_equation_get_face_values ( const cs_equation_t *  eq,
bool  previous
a pointer to an array of face values
◆ cs_equation_get_field()
cs_field_t * cs_equation_get_field ( const cs_equation_t *  eq)
a cs_field_t structure or null if not found
◆ cs_equation_get_field_id()
int cs_equation_get_field_id ( const cs_equation_t *  eq)
an integer (-1 if the field is not defined)
◆ cs_equation_get_field_name()
const char * cs_equation_get_field_name ( const cs_equation_t *  eq)
a string with the the field name (nullptr if not defined)
◆ cs_equation_get_flag()
cs_flag_t cs_equation_get_flag ( const cs_equation_t *  eq)
a flag (cs_flag_t type)
◆ cs_equation_get_global_n_dofs()
cs_gnum_t cs_equation_get_global_n_dofs ( const cs_equation_t *  eq,
const cs_cdo_quantities_t *  cdoq
a global number of degrees of freedom (DoFs)
◆ cs_equation_get_id()
int cs_equation_get_id ( const cs_equation_t *  eq)
an id (0 ... n-1) or -1 if not found
◆ cs_equation_get_n_equations()
int cs_equation_get_n_equations ( void  )
the current number of allocated cs_equation_t structures
◆ cs_equation_get_name()
const char * cs_equation_get_name ( const cs_equation_t *  eq)
a name or null if not found
◆ cs_equation_get_param()
cs_equation_param_t * cs_equation_get_param ( const cs_equation_t *  eq)
a cs_equation_param_t structure or null if not found
◆ cs_equation_get_range_set()
const cs_range_set_t * cs_equation_get_range_set ( const cs_equation_t *  eq)
a cs_range_set_t structure or null if not found
◆ cs_equation_get_reaction_property()
cs_property_t * cs_equation_get_reaction_property ( const cs_equation_t *  eq,
[in]reaction_idid related to this reaction term
a pointer to a cs_property_t structure or null if not found
◆ cs_equation_get_scheme_context()
void * cs_equation_get_scheme_context ( const cs_equation_t *  eq)
a pointer to a structure to cast on-the-fly or null if not found
◆ cs_equation_get_source_term_array()
cs_real_t * cs_equation_get_source_term_array ( const cs_equation_t *  eq)
a pointer to an array of cs_real_t
◆ cs_equation_get_space_poly_degree()
int cs_equation_get_space_poly_degree ( const cs_equation_t *  eq)
the polynomial order
◆ cs_equation_get_space_scheme()
cs_param_space_scheme_t cs_equation_get_space_scheme ( const cs_equation_t *  eq)
a cs_param_space_scheme_t variable
◆ cs_equation_get_theta_time_val()
cs_real_t cs_equation_get_theta_time_val ( const cs_equation_t *  eq)
the value of the theta coefficient. -1 if the time scheme is not a theta time scheme
◆ cs_equation_get_time_eval()
double cs_equation_get_time_eval ( const cs_time_step_t *  ts,
[in]tspointer to a cs_time_step_t structure
[in]eqpointer to an equation structure
the time value at which one has to perform the evaluation
◆ cs_equation_get_time_property()
cs_property_t * cs_equation_get_time_property ( const cs_equation_t *  eq)
Return a pointer to the cs_property_t structure associated to the unsteady term for this equation (null if not activated).
◆ cs_equation_get_time_scheme()
cs_param_time_scheme_t cs_equation_get_time_scheme ( const cs_equation_t *  eq)
a cs_param_time_scheme_t variable
◆ cs_equation_get_type()
cs_equation_type_t cs_equation_get_type ( const cs_equation_t *  eq)
the type of the given equation
◆ cs_equation_get_var_dim()
int cs_equation_get_var_dim ( const cs_equation_t *  eq)
an integer corresponding to the dimension of the variable
◆ cs_equation_get_vertex_values()
cs_real_t * cs_equation_get_vertex_values ( const cs_equation_t *  eq,
bool  previous
a pointer to an array of vertex values
◆ cs_equation_has_field_name()
bool cs_equation_has_field_name ( const cs_equation_t *  eq,
const char *  fld_name
[in]eqpointer to a cs_equation_t structure to test
[in]fld_namename of the field
true if the cs_equation_t structure has an associated field named fld_name, otherwise false
◆ cs_equation_init_field_values()
void cs_equation_init_field_values ( const cs_mesh_t *  mesh,
◆ cs_equation_init_sharing()
void cs_equation_init_sharing ( const cs_mesh_t *  mesh,
const cs_cdo_quantities_t *  cdoq,
const cs_time_step_t *  time_step,
[in]meshpointer to a mesh structure
[in]cdoqpointer to additional mesh quantities struct.
[in]cb_scheme_flagmetadata for cell-based schemes
[in]eb_scheme_flagmetadata for edge-based schemes
[in]fb_scheme_flagmetadata for face_based schemes
[in]vb_scheme_flagmetadata for vertex-based schemes
[in]vcb_scheme_flagmetadata for vertex+cell-based schemes
◆ cs_equation_integrate_variable()
void cs_equation_integrate_variable ( const cs_cdo_connect_t *  connect,
cs_real_t *  result
Compute the integral over the domain of the variable field associated to the given equation. Parallel synchronization is performed in this function. No need to do it outside.
[in,out]resultresult of the computation
◆ cs_equation_is_steady()
bool cs_equation_is_steady ( const cs_equation_t *  eq)
true or false
◆ cs_equation_lock_settings()
void cs_equation_lock_settings ( void  )
◆ cs_equation_log_monitoring()
void cs_equation_log_monitoring ( const cs_time_step_t *  ts,
[in]time_stepspointer to a structure managing the time stepping
[in]cdoqpointer to a structure managing CDO quantities
◆ cs_equation_log_setup()
void cs_equation_log_setup ( void  )
◆ cs_equation_needs_steady_state_solve()
bool cs_equation_needs_steady_state_solve ( void  )
true or false
◆ cs_equation_param_by_field_name()
cs_equation_param_t * cs_equation_param_by_field_name ( const char *  field_name)
◆ cs_equation_param_by_name()
cs_equation_param_t * cs_equation_param_by_name ( const char *  eqname)
If no equation matches the given name but a field does, equation parameter structure associated to the field will be returned instead. This allows using this function with non-CDO (legacy) fields.
◆ cs_equation_post_balance()
void cs_equation_post_balance ( const cs_mesh_t *  mesh,
◆ cs_equation_predefined_create_field()
void cs_equation_predefined_create_field ( int  n_previous,
cs_equation_t *  eq
When an automatic behavior is asked then one checks the flag CS_EQUATION_UNSTEADY to decide. One can force the behavior when handling predefined equations since more complex situations can occur such as a steady computation with non-linearities (in which case one wants a field with a previous state)
[in]n_previousnumber of previous states to keep n_previous equal to -1 means automatic
[in,out]eqpointer to an equation structure
◆ cs_equation_read_extra_restart()
void cs_equation_read_extra_restart ( cs_restart_t *  restart)
[in,out]restartpointer to a cs_restart_t structure
◆ cs_equation_set_default_param()
void cs_equation_set_default_param ( cs_equation_key_t  key,
const char *  keyval
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
◆ cs_equation_set_flag()
void cs_equation_set_flag ( cs_equation_t *  eq,
cs_flag_t  flag
[in]flagnew flag to set
◆ cs_equation_set_functions()
bool cs_equation_set_functions ( void  )
Assign a set of pointer functions for managing the cs_equation_t structure during the computation After this call, parameters related to an equation are set once for all.
true if all equations are steady-state otherwise false
◆ cs_equation_set_sles()
void cs_equation_set_sles ( void  )
◆ cs_equation_solve()
void cs_equation_solve ( bool  cur2prev,
cs_equation_t *  eq
◆ cs_equation_solve_deprecated()
void cs_equation_solve_deprecated ( const cs_mesh_t *  mesh,
cs_equation_t *  eq
◆ cs_equation_solve_steady_state()
void cs_equation_solve_steady_state ( const cs_mesh_t *  mesh,
cs_equation_t *  eq
◆ cs_equation_user_create_fields()
void cs_equation_user_create_fields ( void  )
◆ cs_equation_uses_new_mechanism()
bool cs_equation_uses_new_mechanism ( const cs_equation_t *  eq)
true or false
◆ cs_equation_write_extra_restart()
void cs_equation_write_extra_restart ( cs_restart_t *  restart)
◆ _equations
cs_equation_t** _equations = nullptr
static
◆ _n_equations
static
◆ _n_predef_equations
static
◆ _n_user_equations
static
