cs_cdo_system.h File Reference
+ Include dependency graph for cs_cdo_system.h:
Classes
struct  cs_cdo_system_block_info_t
struct  cs_cdo_system_dblock_t
 Structure associated to the default type of block. More...
struct  cs_cdo_system_nblock_t
 Structure associated to the nested type of block. More...
struct  cs_cdo_system_ublock_t
 Structure associated to the unassembled type of block. More...
struct  cs_cdo_system_xblock_t
 Structure associated to the extended type of block. More...
struct  cs_cdo_system_block_t
struct  cs_cdo_system_helper_t
Enumerations
enum  cs_cdo_system_type_t { CS_CDO_SYSTEM_DEFAULT , CS_CDO_SYSTEM_COUPLED , CS_CDO_SYSTEM_SADDLE_POINT }
enum  cs_cdo_system_block_type_t {
  CS_CDO_SYSTEM_BLOCK_DEFAULT , CS_CDO_SYSTEM_BLOCK_NESTED , CS_CDO_SYSTEM_BLOCK_UNASS , CS_CDO_SYSTEM_BLOCK_EXTERN ,
  CS_CDO_SYSTEM_N_BLOCK_TYPES
 type of block composing a (block) matrix More...
enum  cs_cdo_system_matrix_class_t {
  CS_CDO_SYSTEM_MATRIX_NONE , CS_CDO_SYSTEM_MATRIX_CS , CS_CDO_SYSTEM_MATRIX_PETSC , CS_CDO_SYSTEM_MATRIX_HYPRE ,
  CS_CDO_SYSTEM_N_MATRIX_CLASSES
 Class of matrices to consider. More...
static cs_cdo_system_matrix_class_t cs_cdo_system_which_matrix_class (cs_param_solver_class_t solver_class)
 Get the best available class of matrix knowing the solver class. More...
static cs_cdo_system_matrix_class_t cs_cdo_system_get_matrix_class (const cs_cdo_system_helper_t *sh, int block_id)
 Get the matrix class related to the given block_id CS_CDO_SYSTEM_MATRIX_NONE is returned if not stored in assembled matrix structure (i.e. block of type equal to CS_CDO_SYSTEM_BLOCK_DEFAULT or CS_CDO_SYSTEM_BLOCK_EXTERN. More...
void cs_cdo_system_init_sharing (cs_mesh_t *mesh, cs_cdo_connect_t *connect)
 Allocate and initialize matrix-related structures according to the type of discretization used for this simulation. More...
cs_cdo_system_helper_t * cs_cdo_system_helper_create (cs_cdo_system_type_t type, int n_col_blocks, const cs_lnum_t *col_block_sizes, int n_blocks)
 Create a system_helper structure from its set of metadata. n_col_blocks and n_blocks may differ according to the settings. For instance, for a saddle-point system, n_col_blocks >= n_blocks. More...
cs_cdo_system_block_t * cs_cdo_system_add_dblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced, bool unrolled)
 Add a default block definition at position "block_id" in the helper structure Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_nblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride)
 Add a nested block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_ublock (cs_cdo_system_helper_t *sh, int block_id, const cs_adjacency_t *adjacency, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced)
 Add an unassembled block definition at position "block_id" in the helper structure Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_xblock (cs_cdo_system_helper_t *sh, int block_id, cs_lnum_t n_dofs)
 Add an external block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More...
cs_range_set_t * cs_cdo_system_get_range_set (const cs_cdo_system_helper_t *sh, int block_id)
 Retrieve the range set structure associated to the given block_id. More...
cs_matrix_t * cs_cdo_system_get_matrix (const cs_cdo_system_helper_t *sh, int block_id)
 Retrieve the matrix associated to the given block_id. If the type of block is either CS_CDO_SYSTEM_BLOCK_DEFAULT or CS_CDO_SYSTEM_BLOCK_EXTERN. In other cases, a null pointer is returned. The unassembled block has no matrix and to get a matrix of a split block, one should use cs_cdo_system_get_sub_matrix(sh, block_id, sub_id) More...
cs_matrix_t * cs_cdo_system_get_sub_matrix (cs_cdo_system_helper_t *sh, int block_id, int sub_id)
 Retrieve the (sub-)matrix associated to a split block with id equal to block_id. sub_id is the id in the list of matrices of size equal to stride*stride. If the type of the block is not CS_CDO_SYSTEM_BLOCK_NESTED, then a null pointer is returned. More...
void cs_cdo_system_build_block (cs_cdo_system_helper_t *sh, int block_id)
 Build the associated structures for the given system_helper structure If a member is already allocated, one keeps the member as it is. More...
void cs_cdo_system_helper_init_system (cs_cdo_system_helper_t *sh, cs_real_t **p_rhs)
 Allocate and initialize the matrix, rhs and the matrix assembler values. More...
void cs_cdo_system_helper_finalize_assembly (cs_cdo_system_helper_t *sh)
 Finalize the assembly after the cellwise building and assembly. More...
void cs_cdo_system_helper_reset (cs_cdo_system_helper_t *sh)
 Free matrix and rhs after the solve step. More...
void cs_cdo_system_helper_free (cs_cdo_system_helper_t **p_helper)
 Free a cs_cdo_system_helper_t structure. More...
void cs_cdo_system_allocate_assembly (void)
 Initialize shared assembly structures from the existing helper structures. More...
void cs_cdo_system_destroy_all (void)
 Free all members associated to system helpers. More...
◆ cs_cdo_system_block_type_t
Enumerator
Simplest block type. One matrix inside a block.
The block is described by several (sub)matrices.
The block is unassembled so that there is no matrix and related structures to describe this type of block. For instance, this block can be associated to the pressure block in some strategy for solving sadle-point problems.
External way to define a block. This block does not rely on the generic function to assemble and build the associated structures. For instance, it corresponds to the full assembly strategy in case of a saddle-point problem.
◆ cs_cdo_system_matrix_class_t
Enumerator
No matrix is considered (unassembled treatment for instance)
Matrix format specific to code_saturne (native)
Matrix format specific to the library PETSC (external)
Matrix format specific to the library HYPRE (external)
◆ cs_cdo_system_type_t
Enumerator
‍One matrix with one block
‍System arising of a system of equations
◆ cs_cdo_system_add_dblock()
cs_cdo_system_block_t * cs_cdo_system_add_dblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_flag_t  location,
int  stride,
bool  interlaced,
bool  unrolled
[in,out]shpointer to the system helper to update
[in]block_idid in blocks array in a system helper
[in]matclassclass of the matrix to handle
[in]locationwhere DoFs are defined
[in]n_elementsnumber of elements (support entities for DoFs)
[in]stridenumber of DoFs by element
[in]interlaceduseful if stride > 1; way to store components
[in]unrolleduseful if stride > 1; true=as scalar-valued
a pointer to the newly allocated structure
◆ cs_cdo_system_add_nblock()
cs_cdo_system_block_t * cs_cdo_system_add_nblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_flag_t  location,
int  stride
◆ cs_cdo_system_add_ublock()
cs_cdo_system_block_t * cs_cdo_system_add_ublock ( cs_cdo_system_helper_t *  sh,
int  block_id,
const cs_adjacency_t *  adjacency,
cs_flag_t  location,
int  stride,
bool  interlaced
[in]adjacencyshared adjacency structure
◆ cs_cdo_system_add_xblock()
cs_cdo_system_block_t * cs_cdo_system_add_xblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_lnum_t  n_dofs
[in]n_dofsnumber of degrees of freedom
◆ cs_cdo_system_allocate_assembly()
void cs_cdo_system_allocate_assembly ( void  )
◆ cs_cdo_system_build_block()
void cs_cdo_system_build_block ( cs_cdo_system_helper_t *  sh,
int  block_id
[in,out]shpointer to the system_helper structure to update
[in]block_idspecific block to handle or -1 for all blocks
◆ cs_cdo_system_destroy_all()
void cs_cdo_system_destroy_all ( void  )
◆ cs_cdo_system_get_matrix()
cs_matrix_t * cs_cdo_system_get_matrix ( const cs_cdo_system_helper_t *  sh,
int  block_id
[in]shpointer to the system_helper structure to update
[in]block_idid of the block to consider
a pointer to a cs_matrix_t structure or null
a pointer to a cs_matrix_t structure or nullptr
◆ cs_cdo_system_get_matrix_class()
static cs_cdo_system_matrix_class_t cs_cdo_system_get_matrix_class ( const cs_cdo_system_helper_t *  sh,
int  block_id
inlinestatic
[in]shpointer to a system helper structure
[in]block_idid of the block to work with
the class of matrix
◆ cs_cdo_system_get_range_set()
cs_range_set_t * cs_cdo_system_get_range_set ( const cs_cdo_system_helper_t *  sh,
int  block_id
a pointer to a range set structure or null
a pointer to a range set structure or nullptr
◆ cs_cdo_system_get_sub_matrix()
cs_matrix_t * cs_cdo_system_get_sub_matrix ( cs_cdo_system_helper_t *  sh,
int  block_id,
int  sub_id
[in]sub_idid in the slip block
◆ cs_cdo_system_helper_create()
cs_cdo_system_helper_t * cs_cdo_system_helper_create ( cs_cdo_system_type_t  type,
int  n_col_blocks,
const cs_lnum_t *  col_block_sizes,
int  n_blocks
[in]typetype of system to handle
[in]n_col_blocksnumber of blocks in a row
[in]col_block_sizesnumber of DoFs in each block of the row
[in]n_blocksnumber of blocks associated to this system
the pointer to the new allocated structure
◆ cs_cdo_system_helper_finalize_assembly()
void cs_cdo_system_helper_finalize_assembly ( cs_cdo_system_helper_t *  sh)
[in,out]shpointer to a system helper structure
◆ cs_cdo_system_helper_free()
void cs_cdo_system_helper_free ( cs_cdo_system_helper_t **  p_helper)
[in,out]p_helperdouble pointer to the structure to free
◆ cs_cdo_system_helper_init_system()
void cs_cdo_system_helper_init_system ( cs_cdo_system_helper_t *  sh,
cs_real_t **  p_rhs
[in,out]p_rhsdouble pointer to the RHS array to initialize
◆ cs_cdo_system_helper_reset()
void cs_cdo_system_helper_reset ( cs_cdo_system_helper_t *  sh)
◆ cs_cdo_system_init_sharing()
void cs_cdo_system_init_sharing ( cs_mesh_t *  mesh,
cs_cdo_connect_t *  connect
◆ cs_cdo_system_which_matrix_class()
static cs_cdo_system_matrix_class_t cs_cdo_system_which_matrix_class ( cs_param_solver_class_t  solver_class)
inlinestatic
[in]solver_classfamily of solver to consider
the best class of matrices which is available for this solver class
