cs_cdo_system_ublock_t Struct Reference
Structure associated to the unassembled type of block. More...
#include <cs_cdo_system.h>
+ Collaboration diagram for cs_cdo_system_ublock_t:
Public Attributes
cs_real_t * values
cs_real_t * _values
const cs_adjacency_t * adjacency
bool shared_structures
cs_range_set_t * range_set
cs_interface_set_t * interface_set
With this type of block, there is no matrix and its associated structures. Only the pointer to a range set and its associated interface set are stored.
Member Data Documentation
◆ _values
_values
Private. The structure has the ownership of the operator values. According to the stride value in the block metadata, one can apply a stride to access to the array of values.
◆ adjacency
adjacency
Always shared. The associated adjacency to acces to the values. It corresponds to the connectivity x2y. n_x is equal to adjacency->n_elts and n_y is equal to info.n_elts
◆ interface_set
cs_interface_set_t* interface_set
◆ range_set
cs_range_set_t* range_set
◆ shared_structures
◆ values
values
Shared. values of the operator. According to the stride value in the block metadata, one can apply a stride to access to the array of values.
