cs_cdo_system_nblock_t Struct Reference
Structure associated to the nested type of block. More...
#include <cs_cdo_system.h>
+ Collaboration diagram for cs_cdo_system_nblock_t:
Public Attributes
int n_matrices
cs_matrix_t ** matrices
cs_matrix_assembler_values_t ** mav_array
cs_cdo_assembly_func_t * assembly_func
cs_cdo_assembly_func_t * slave_assembly_func
cs_range_set_t * range_set
cs_interface_set_t * interface_set
bool matrix_struct_ownership
cs_matrix_assembler_t * matrix_assembler
cs_matrix_structure_t * matrix_structure
In this case, the block is built by a set of nested (sub) matrices sharing the same pattern (structure and function to perform the assembly)
Member Data Documentation
◆ assembly_func
cs_cdo_assembly_func_t* assembly_func
◆ interface_set
cs_interface_set_t* interface_set
◆ matrices
cs_matrix_t** matrices
◆ matrix_assembler
cs_matrix_assembler_t* matrix_assembler
◆ matrix_struct_ownership
◆ matrix_structure
cs_matrix_structure_t* matrix_structure
◆ mav_array
◆ n_matrices
int n_matrices
◆ range_set
cs_range_set_t* range_set
◆ slave_assembly_func
cs_cdo_assembly_func_t* slave_assembly_func
