cs_cdo_system_dblock_t Struct Reference
Structure associated to the default type of block. More...
#include <cs_cdo_system.h>
+ Collaboration diagram for cs_cdo_system_dblock_t:
Public Attributes
cs_matrix_t * matrix
cs_matrix_assembler_values_t * mav
cs_cdo_assembly_func_t * assembly_func
cs_cdo_assembly_func_t * slave_assembly_func
cs_range_set_t * range_set
cs_interface_set_t * interface_set
cs_matrix_assembler_t * matrix_assembler
cs_matrix_structure_t * matrix_structure
The standard case is to have only one (sub-)matrix which is the system matrix. This type of block is used in scalar-valued and vector-valued problems and corresponds to the simplest usage of block to define a linear system.
Member Data Documentation
◆ assembly_func
cs_cdo_assembly_func_t* assembly_func
◆ interface_set
cs_interface_set_t* interface_set
◆ matrix
cs_matrix_t* matrix
◆ matrix_assembler
cs_matrix_assembler_t* matrix_assembler
◆ matrix_structure
cs_matrix_structure_t* matrix_structure
◆ mav
◆ range_set
cs_range_set_t* range_set
◆ slave_assembly_func
cs_cdo_assembly_func_t* slave_assembly_func
