cs_advection_field.cpp File Reference
#include <ctype.h>
#include <float.h>
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "cdo/cs_cdo_toolbox.h"
#include "cdo/cs_evaluate.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "cdo/cs_param_cdo.h"
#include "cdo/cs_reco.h"
#include "base/cs_volume_zone.h"
#include "cdo/cs_xdef.h"
#include "base/cs_zone.h"
#include "cdo/cs_advection_field.h"
+ Include dependency graph for cs_advection_field.cpp:
Macros
#define _dp3   cs_math_3_dot_product
#define CS_ADVECTION_FIELD_DBG   0
#define CS_ADVECTION_FIELD_ID_NOT_SET   -1
#define CS_ADVECTION_FIELD_ID_TO_BE_SET   -2
static int _get_dim_def (const cs_adv_field_t *adv)
 Return the required dimension for the definition of an advection field. More...
static void _fill_uniform_boundary_flux (const cs_cdo_quantities_t *const cdoq, const cs_adjacency_t *const f2e, const cs_adjacency_t *const e2v, cs_lnum_t bf_id, cs_real_t face_flux, cs_real_t *fluxes)
 Update the contribution of the flux. More...
static void _cw_fill_uniform_boundary_flux (const cs_cell_mesh_t *cm, short int f, cs_real_t face_flux, cs_real_t *fluxes)
 Update the contribution of the flux for each vertex. More...
static void _compute_adv_vector_at_vertices (cs_xdef_t *def, cs_real_t *vtx_values)
 Compute a vector-valued reconstruction of the advection field at vertices from the definition of the advection field. More...
void cs_advection_field_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
 Set shared pointers to main domain members. More...
int cs_advection_field_get_n_fields (void)
 Get the number of allocated cs_adv_field_t structures. More...
cs_adv_field_t * cs_advection_field_by_name (const char *name)
 Search in the array of advection field structures which one has the name given in argument. More...
cs_adv_field_t * cs_advection_field_by_id (int id)
 Search in the array of advection field structures which one has the id given in argument. More...
cs_adv_field_t * cs_advection_field_add_user (const char *name)
 Add and initialize a new user-defined advection field structure. More...
cs_adv_field_t * cs_advection_field_add (const char *name, cs_advection_field_status_t status)
 Add and initialize a new advection field structure. More...
void cs_advection_field_destroy_all (void)
 Free all allocated cs_adv_field_t structures and its related array. More...
bool cs_advection_field_check_name (const cs_adv_field_t *adv, const char *ref_name)
 Check if the given advection field has the name ref_name. More...
void cs_advection_field_log_setup (void)
 Print all setup information related to cs_adv_field_t structures. More...
void cs_advection_field_set_postprocess (cs_adv_field_t *adv, cs_flag_t post_flag)
 Set optional post-processings. More...
void cs_advection_field_def_by_value (cs_adv_field_t *adv, cs_real_t *values)
 Define the value of a cs_adv_field_t structure. More...
void cs_advection_field_def_by_analytic (cs_adv_field_t *adv, cs_analytic_func_t *func, void *input)
 Define a cs_adv_field_t structure thanks to an analytic function. More...
void cs_advection_field_def_by_dof_func (cs_adv_field_t *adv, cs_flag_t dof_location, cs_dof_func_t *func, void *input)
 Define a cs_adv_field_t structure using a cs_dof_func_t. More...
cs_xdef_t * cs_advection_field_def_by_array (cs_adv_field_t *adv, cs_flag_t val_location, cs_real_t *array, bool is_owner)
 Define a cs_adv_field_t structure thanks to an array of values. If an advanced usage of the definition by array is needed, then call cs_xdef_array_set_sublist or cs_xdef_array_set_adjacency. More...
void cs_advection_field_def_by_field (cs_adv_field_t *adv, cs_field_t *field)
 Define a cs_adv_field_t structure thanks to a field structure. More...
void cs_advection_field_def_boundary_flux_by_value (cs_adv_field_t *adv, const char *zname, cs_real_t normal_flux)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure. More...
void cs_advection_field_def_boundary_flux_by_analytic (cs_adv_field_t *adv, const char *zname, cs_analytic_func_t *func, void *input)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using an analytic function. More...
cs_xdef_t * cs_advection_field_def_boundary_flux_by_array (cs_adv_field_t *adv, const char *zname, cs_flag_t val_loc, cs_real_t *array, bool is_owner, bool full_length)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using an array of values. More...
void cs_advection_field_def_boundary_flux_by_field (cs_adv_field_t *adv, cs_field_t *field)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using a field structure. More...
void cs_advection_field_create_fields (void)
 Create all needed cs_field_t structures related to an advection field. More...
void cs_advection_field_finalize_setup (void)
 Last stage of the definition of an advection field based on several definitions (i.e. definition by subdomains on the boundary) More...
void cs_advection_field_get_cell_vector (cs_lnum_t c_id, const cs_adv_field_t *adv, cs_nvec3_t *vect)
 Compute the value of the advection field at the cell center. More...
void cs_advection_field_cw_eval_at_xyz (const cs_adv_field_t *adv, const cs_cell_mesh_t *cm, const cs_real_3_t xyz, cs_real_t time_eval, cs_nvec3_t *eval)
 Compute the vector-valued interpolation of the advection field at a given location inside a cell. More...
void cs_advection_field_in_cells (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *cell_values)
 Compute the mean-value of the vector-valued field related to the advection field inside each cell. More...
void cs_advection_field_at_vertices (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *vtx_values)
 Compute the value of the advection field at vertices. More...
void cs_advection_field_across_boundary (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *flx_values)
 Compute the value of the normal flux of the advection field across the boundary faces. More...
cs_real_t cs_advection_field_cw_boundary_face_flux (const cs_real_t time_eval, const short int f, const cs_cell_mesh_t *cm, const cs_adv_field_t *adv)
 Compute the value of the normal flux of the advection field across a boundary face f (cellwise version) More...
void cs_advection_field_cw_boundary_f2v_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, short int f, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the normal flux of the advection field across the closure of the dual cell related to each vertex belonging to the boundary face f. More...
void cs_advection_field_cw_face_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the (primal) faces of a cell. More...
void cs_advection_field_cw_dface_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the dual faces of a cell. More...
void cs_advection_field_macb_dface_flux (const cs_macfb_builder_t *macb, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the dual faces of a cell MAC face-based scheme. More...
void cs_advection_field_update (cs_real_t t_eval, bool cur2prev)
 For each cs_adv_field_t structures, update the values of the related field(s) More...
void cs_advection_get_peclet (const cs_adv_field_t *adv, const cs_property_t *diff, cs_real_t t_eval, cs_real_t peclet[])
 Compute the Peclet number in each cell. More...
void cs_advection_get_courant (const cs_adv_field_t *adv, cs_real_t dt_cur, cs_real_t courant[])
 Compute the Courant number in each cell. More...
cs_real_t * cs_advection_field_divergence_at_vertices (const cs_adv_field_t *adv, cs_real_t t_eval)
 Compute the divergence of the advection field at vertices Useful for CDO Vertex-based schemes. More...
static const char _err_empty_adv []
static const cs_cdo_quantities_t * cs_cdo_quant
static const cs_cdo_connect_t * cs_cdo_connect
static int _n_adv_fields = 0
static cs_adv_field_t ** _adv_fields = nullptr
◆ _dp3
◆ CS_ADVECTION_FIELD_DBG
◆ CS_ADVECTION_FIELD_ID_NOT_SET
◆ CS_ADVECTION_FIELD_ID_TO_BE_SET
◆ _compute_adv_vector_at_vertices()
static void _compute_adv_vector_at_vertices ( cs_xdef_t *  def,
cs_real_t *  vtx_values
static
[in]defpointer to a cs_xdef_t struct.
[in,out]vtx_valuesvalues of the reconstruction
◆ _cw_fill_uniform_boundary_flux()
static void _cw_fill_uniform_boundary_flux ( const cs_cell_mesh_t *  cm,
short int  f,
cs_real_t *  fluxes
static
[in]fface id in the cellwise numbering
[in]face_fluxvalue of the normal flux across the face
[in,out]fluxesnormal boundary flux for each vertex of the face
◆ _fill_uniform_boundary_flux()
static void _fill_uniform_boundary_flux ( const cs_cdo_quantities_t *const  cdoq,
cs_lnum_t  bf_id,
cs_real_t *  fluxes
static
[in]f2eface --> edge connectivity
[in]e2vedge --> vertices connectivity
[in]bf_idboundary face id
[in,out]fluxesarray of values to update
◆ _get_dim_def()
static int _get_dim_def ( const cs_adv_field_t *  adv)
inlinestatic
[in]advpointer to an advection field structure
the dimension
◆ cs_advection_field_across_boundary()
void cs_advection_field_across_boundary ( const cs_adv_field_t *  adv,
cs_real_t *  flx_values
[in]advpointer to a cs_adv_field_t structure
[in,out]flx_valuesarray storing the results
◆ cs_advection_field_add()
cs_adv_field_t * cs_advection_field_add ( const char *  name,
[in]namename of the advection field
[in]statusstatus of the advection field to create
a pointer to the new allocated cs_adv_field_t structure
◆ cs_advection_field_add_user()
cs_adv_field_t * cs_advection_field_add_user ( const char *  name)
◆ cs_advection_field_at_vertices()
void cs_advection_field_at_vertices ( const cs_adv_field_t *  adv,
[in,out]vtx_valuesarray storing the results
◆ cs_advection_field_by_id()
cs_adv_field_t * cs_advection_field_by_id ( int  id)
[in]ididentification number
a pointer to a cs_adv_field_t structure or null if not found
◆ cs_advection_field_by_name()
cs_adv_field_t * cs_advection_field_by_name ( const char *  name)
◆ cs_advection_field_check_name()
bool cs_advection_field_check_name ( const cs_adv_field_t *  adv,
const char *  ref_name
[in]advpointer to a cs_adv_field_t structure to test
[in]ref_namename of the advection field to find
true if the name of the advection field is ref_name otherwise false
◆ cs_advection_field_create_fields()
void cs_advection_field_create_fields ( void  )
◆ cs_advection_field_cw_boundary_f2v_flux()
void cs_advection_field_cw_boundary_f2v_flux ( const cs_cell_mesh_t *  cm,
short int  f,
cs_real_t *  fluxes
◆ cs_advection_field_cw_boundary_face_flux()
cs_real_t cs_advection_field_cw_boundary_face_flux ( const cs_real_t  time_eval,
const short int  f,
the normal boundary flux for the face f
◆ cs_advection_field_cw_dface_flux()
void cs_advection_field_cw_dface_flux ( const cs_cell_mesh_t *  cm,
cs_real_t *  fluxes
[in,out]fluxesarray of values attached to dual faces of a cell
◆ cs_advection_field_cw_eval_at_xyz()
void cs_advection_field_cw_eval_at_xyz ( const cs_adv_field_t *  adv,
cs_nvec3_t *  eval
[in]xyzlocation where to perform the evaluation
[in,out]evalpointer to a cs_nvec3_t
◆ cs_advection_field_cw_face_flux()
void cs_advection_field_cw_face_flux ( const cs_cell_mesh_t *  cm,
cs_real_t *  fluxes
[in,out]fluxesarray of values attached to primal faces of a cell
◆ cs_advection_field_def_boundary_flux_by_analytic()
void cs_advection_field_def_boundary_flux_by_analytic ( cs_adv_field_t *  adv,
const char *  zname,
cs_analytic_func_t *  func,
void *  input
[in,out]advpointer to a cs_adv_field_t structure
[in]znamename of the boundary zone to consider
[in]funcpointer to a function
[in]inputnull or pointer to a structure cast on-the-fly
◆ cs_advection_field_def_boundary_flux_by_array()
cs_xdef_t * cs_advection_field_def_boundary_flux_by_array ( cs_adv_field_t *  adv,
const char *  zname,
cs_flag_t  val_loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]val_locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t struct. (true or false)
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
a pointer to the resulting definition
◆ cs_advection_field_def_boundary_flux_by_field()
void cs_advection_field_def_boundary_flux_by_field ( cs_adv_field_t *  adv,
cs_field_t *  field
[in]fieldpointer to a cs_field_t structure
◆ cs_advection_field_def_boundary_flux_by_value()
void cs_advection_field_def_boundary_flux_by_value ( cs_adv_field_t *  adv,
const char *  zname,
[in]normal_fluxvalue to set
◆ cs_advection_field_def_by_analytic()
void cs_advection_field_def_by_analytic ( cs_adv_field_t *  adv,
void *  input
◆ cs_advection_field_def_by_array()
cs_xdef_t * cs_advection_field_def_by_array ( cs_adv_field_t *  adv,
cs_real_t *  array,
bool  is_owner
[in]val_locationinformation to know where are located values
[in]is_ownertransfer the lifecycle to the cs_xdef_t struc. (true or false)
a pointer to the resulting cs_xdef_t structure
◆ cs_advection_field_def_by_dof_func()
void cs_advection_field_def_by_dof_func ( cs_adv_field_t *  adv,
cs_dof_func_t *  func,
void *  input
[in]dof_locationlocation where values are computed
[in]funcpointer to a cs_dof_func_t function
◆ cs_advection_field_def_by_field()
void cs_advection_field_def_by_field ( cs_adv_field_t *  adv,
cs_field_t *  field
◆ cs_advection_field_def_by_value()
void cs_advection_field_def_by_value ( cs_adv_field_t *  adv,
cs_real_t *  values
[in]valuesvalues to set
◆ cs_advection_field_destroy_all()
void cs_advection_field_destroy_all ( void  )
Free all alllocated cs_adv_field_t structures and its related array.
a null pointer
◆ cs_advection_field_divergence_at_vertices()
cs_real_t * cs_advection_field_divergence_at_vertices ( const cs_adv_field_t *  adv,
cs_real_t  t_eval
[in]advpointer to the advection field struct.
[in]t_evaltime at which one evaluates the advection field
a pointer to an array storing the result
◆ cs_advection_field_finalize_setup()
void cs_advection_field_finalize_setup ( void  )
◆ cs_advection_field_get_cell_vector()
void cs_advection_field_get_cell_vector ( cs_lnum_t  c_id,
cs_nvec3_t *  vect
[in]c_idid of the current cell
[in,out]vectpointer to a cs_nvec3_t structure (meas + unitv)
◆ cs_advection_field_get_n_fields()
int cs_advection_field_get_n_fields ( void  )
the number of advection fields
◆ cs_advection_field_in_cells()
void cs_advection_field_in_cells ( const cs_adv_field_t *  adv,
cs_real_t *  cell_values
[in,out]cell_valuesarray of values at cell centers
◆ cs_advection_field_init_sharing()
void cs_advection_field_init_sharing ( const cs_cdo_quantities_t *  quant,
const cs_cdo_connect_t *  connect
◆ cs_advection_field_log_setup()
void cs_advection_field_log_setup ( void  )
◆ cs_advection_field_macb_dface_flux()
void cs_advection_field_macb_dface_flux ( const cs_macfb_builder_t *  macb,
cs_real_t *  fluxes
[in]macbpointer to a cs_macfb_builder_t structure
◆ cs_advection_field_set_postprocess()
void cs_advection_field_set_postprocess ( cs_adv_field_t *  adv,
cs_flag_t  post_flag
[in]post_flagflag to set
◆ cs_advection_field_update()
void cs_advection_field_update ( cs_real_t  t_eval,
bool  cur2prev
[in]t_evalphysical time at which one evaluates the term
[in]cur2prevtrue or false
◆ cs_advection_get_courant()
void cs_advection_get_courant ( const cs_adv_field_t *  adv,
cs_real_t  dt_cur,
cs_real_t  courant[]
[in]dt_curcurrent time step
[in,out]courantpointer to an array storing the Courant number
◆ cs_advection_get_peclet()
void cs_advection_get_peclet ( const cs_adv_field_t *  adv,
const cs_property_t *  diff,
cs_real_t  t_eval,
cs_real_t  peclet[]
[in]diffpointer to the diffusion property struct.
[in,out]pecletpointer to an array storing the Peclet number
◆ _adv_fields
cs_adv_field_t** _adv_fields = nullptr
static
◆ _err_empty_adv
const char _err_empty_adv[]
static
Initial value:
= " Stop setting an empty cs_adv_field_t structure.\n"
" Please check your settings.\n"
◆ _n_adv_fields
static
◆ cs_cdo_connect
const cs_cdo_connect_t* cs_cdo_connect
static
◆ cs_cdo_quant
const cs_cdo_quantities_t* cs_cdo_quant
static
