cs_math.h File Reference
+ Include dependency graph for cs_math.h:
Namespaces
namespace  cs
Enumerations
enum  cs_math_sym_tensor_component_t {
  XX , YY , ZZ , XY ,
  YZ , XZ
template<typename T , typename U >
CS_F_HOST_DEVICE cs_real_t cs_math_3_distance_dot_product (const T xa[3], const T xb[3], const U xc[3])
 Compute $ (\vect{x}_b - \vect{x}_a) \cdot \vect{x}_c $. More...
CS_F_HOST_DEVICE cs_real_t cs_math_3_dot_product (const T u[3], const U v[3])
 Compute the dot product of two vectors of 3 real values. More...
template<typename T >
CS_F_HOST_DEVICE cs_real_t cs_math_3_norm (const T v[3])
 Compute the euclidean norm of a vector of dimension 3. More...
template<typename T , typename U , typename V >
CS_F_HOST_DEVICE cs_real_t cs_math_3_sym_33_3_dot_product (const T n1[3], const U t[6], const V n2[3])
 Compute the dot product of a symmetric tensor t with two vectors, n1 and n2. More...
CS_F_HOST_DEVICE cs_real_t cs_math_3_square_norm (const T v[3])
 Compute the square norm of a vector of 3 real values. More...
static CS_F_HOST_DEVICE void cs_math_3_normalize (const T vin[3], U vout[3])
 Normalise a vector of 3 real values. More...
CS_F_HOST_DEVICE void cs_math_sym_33_3_product (const T m[6], const U v[3], V *restrict mv)
 Compute the product of a symmetric matrix of 3x3 real values by a vector of 3 real values. NB: Symmetric matrix are stored as follows (s11, s22, s33, s12, s23, s13) More...
CS_F_HOST_DEVICE void cs_math_3_normal_scaling (const T n[3], U factor, V v[3])
 Add the dot product with a normal vector to the normal direction to a vector. More...
CS_F_HOST_DEVICE cs_real_t cs_math_3_33_3_dot_product (const T n1[3], const U t[3][3], const V n2[3])
 Compute the dot product of a tensor t with two vectors, n1 and n2. More...
CS_F_HOST_DEVICE void cs_math_3_orthogonal_projection (const T n[3], const U v[3], V *restrict vout)
 Orthogonal projection of a vector with respect to a normalised vector. More...
static CS_F_HOST_DEVICE void cs_math_3_cross_product (const T u[3], const U v[3], V *restrict uv)
 Compute the cross product of two vectors of 3 real values. More...
template<cs_lnum_t n, typename T >
CS_F_HOST_DEVICE void cs_math_matrix_gauss_inverse (const T a[n][n], T b[n][n])
 Inverse square, dense matrix using Gauss-Jordan elimination. More...
CS_F_HOST_DEVICE void cs_math_6_gauss_inverse_in_place (T a[6])
 Inverse 3x3 symmetric matrix in place, using Gauss-Jordan elimination. More...
CS_F_HOST_DEVICE double abs (const double a)
CS_F_HOST_DEVICE float abs (const float a)
CS_F_HOST_DEVICE double min (const double a, const double b)
CS_F_HOST_DEVICE float min (const float a, const float b)
CS_F_HOST_DEVICE double max (const double a, const double b)
CS_F_HOST_DEVICE float max (const float a, const float b)
CS_F_HOST_DEVICE double clamp (const double x, const double xmin, const double xmax)
CS_F_HOST_DEVICE float clamp (const float x, const float xmin, const float xmax)
CS_F_HOST_DEVICE float pow2 (float x)
 Compute the square of a real value. More...
CS_F_HOST_DEVICE double pow2 (double x)
static int cs_math_binom (int n, int k)
 Computes the binomial coefficient of n and k. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_fabs (cs_real_t x)
 Compute the absolute value of a real value. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_fmin (cs_real_t x, cs_real_t y)
 Compute the min value of two real values. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_fmax (cs_real_t x, cs_real_t y)
 Compute the max value of two real values. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_clamp (cs_real_t x, cs_real_t xmin, cs_real_t xmax)
 Clamp function for a given scalar value. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_sq (cs_real_t x)
static CS_F_HOST_DEVICE cs_real_t cs_math_pow2 (cs_real_t x)
static CS_F_HOST_DEVICE cs_real_t cs_math_pow3 (cs_real_t x)
 Compute the cube of a real value. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_pow4 (cs_real_t x)
 Compute the 4-th power of a real value. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_pow5 (cs_real_t x)
 Compute the 5-th power of a real value. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_3_distance (const cs_real_t xa[3], const cs_real_t xb[3])
 Compute the (euclidean) distance between two points xa and xb in a Cartesian coordinate system of dimension 3. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_3_distance_dot_product (const cs_real_t xa[3], const cs_real_t xb[3], const cs_real_t xc[3])
static CS_F_HOST_DEVICE cs_real_t cs_math_3_square_distance (const cs_real_t xa[3], const cs_real_t xb[3])
 Compute the squared distance between two points xa and xb in a Cartesian coordinate system of dimension 3. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_3_dot_product (const cs_real_t u[3], const cs_real_t v[3])
static CS_F_HOST_DEVICE cs_real_t cs_math_3_33_3_dot_product (const cs_real_t n1[3], const cs_real_t t[3][3], const cs_real_t n2[3])
static CS_F_HOST_DEVICE cs_real_t cs_math_3_sym_33_3_dot_product (const cs_real_t n1[3], const cs_real_t t[6], const cs_real_t n2[3])
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm (const cs_real_t v[3])
static CS_F_HOST_DEVICE cs_real_t cs_math_3_square_norm (const cs_real_t v[3])
static CS_F_HOST_DEVICE void cs_math_3_normalize (const cs_real_t vin[3], cs_real_t vout[3])
static CS_F_HOST_DEVICE void cs_math_3_normalize_threshold (const cs_real_t vin[3], const cs_real_t thres, cs_real_t vout[3])
 Normalise a vector of 3 real values and clip the norm using a threshold value. More...
static CS_F_HOST_DEVICE void cs_math_3_orthogonal_projection (const cs_real_t n[3], const cs_real_t v[3], cs_real_t *restrict vout)
static CS_F_HOST_DEVICE void cs_math_3_normal_scaling (const cs_real_t n[3], cs_real_t factor, cs_real_t v[3])
static CS_F_HOST_DEVICE void cs_math_33_normal_scaling_add (const cs_real_t n[3], cs_real_t factor, cs_real_t t[3][3])
 Add the dot product with a normal vector to the normal,normal component of a tensor: t += factor * n.t.n n(x)n. More...
static CS_F_HOST_DEVICE void cs_math_33_3_product (const cs_real_t m[3][3], const cs_real_t v[3], cs_real_t *restrict mv)
 Compute the product of a matrix of 3x3 real values by a vector of 3 real values. More...
static CS_F_HOST_DEVICE void cs_math_33_3_product_add (const cs_real_t m[3][3], const cs_real_t v[3], cs_real_t *restrict mv)
 Compute the product of a matrix of 3x3 real values by a vector of 3 real values add. More...
static CS_F_HOST_DEVICE void cs_math_33t_3_product (const cs_real_t m[3][3], const cs_real_t v[3], cs_real_t *restrict mv)
 Compute the product of the transpose of a matrix of 3x3 real values by a vector of 3 real values. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_3_product (const cs_real_t m[6], const cs_real_t v[3], cs_real_t *restrict mv)
static CS_F_HOST_DEVICE void cs_math_sym_33_3_product_add (const cs_real_t m[6], const cs_real_t v[3], cs_real_t *restrict mv)
 Compute the product of a symmetric matrix of 3x3 real values by a vector of 3 real values and add it to the vector. NB: Symmetric matrix are stored as follows (s11, s22, s33, s12, s23, s13) More...
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_33_sym_33_product_trace (const cs_real_t m1[6], const cs_real_t m2[6])
 Compute the product of two symmetric matrices of 3x3 real values and take the trace. NB: Symmetric matrix are stored as follows (s11, s22, s33, s12, s23, s13) More...
static CS_F_HOST_DEVICE cs_real_t cs_math_33_trace (const cs_real_t t[3][3])
 Compute the trace of a 3x3 tensor. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_6_trace (const cs_real_t t[6])
 Compute the trace of a symmetric tensor. More...
static CS_F_HOST_DEVICE void cs_math_66_6_product (const cs_real_t m[6][6], const cs_real_t v[6], cs_real_t *restrict mv)
 Compute the product of a matrix of 6x6 real values by a vector of 6 real values. More...
static CS_F_HOST_DEVICE void cs_math_66_6_product_add (const cs_real_t m[6][6], const cs_real_t v[6], cs_real_t *restrict mv)
 Compute the product of a matrix of 6x6 real values by a vector of 6 real values and add it to the vector. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_33_determinant (const cs_real_t m[3][3])
 Compute the determinant of a 3x3 matrix. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_33_determinant (const cs_real_t m[6])
 Compute the determinant of a 3x3 symmetric matrix. More...
static CS_F_HOST_DEVICE void cs_math_3_average (const cs_real_t u[3], const cs_real_t v[3], cs_real_t *restrict uv)
 Compute the average of two vector of dimension 3. More...
static CS_F_HOST_DEVICE void cs_math_3_cross_product (const cs_real_t u[3], const cs_real_t v[3], cs_real_t *restrict uv)
static CS_F_HOST_DEVICE cs_real_t cs_math_3_triple_product (const cs_real_t u[3], const cs_real_t v[3], const cs_real_t w[3])
 Compute the triple product. More...
static CS_F_HOST_DEVICE void cs_math_3_orthonormal_basis (const cs_real_t vect[3], cs_real_t axes[3][3])
 Build an orthonormal basis based on a first vector "vect". axes[0] is vect normalized, while (axes[0], axes[1], axes[23]) is an orthonormal base. More...
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer (const cs_real_t in[3][3], cs_real_t out[3][3])
 Inverse a 3x3 matrix. More...
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer_in_place (cs_real_t a[3][3])
 Inverse a 3x3 matrix in place, using Cramer's rule. More...
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer_sym_in_place (cs_real_t a[3][3])
 Inverse a 3x3 symmetric matrix (with non-symmetric storage) in place, using Cramer's rule. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_inv_cramer (const cs_real_t s[6], cs_real_t *restrict sout)
 Compute the inverse of a symmetric matrix using Cramer's rule. More...
static CS_F_HOST_DEVICE void cs_math_33_product (const cs_real_t m1[3][3], const cs_real_t m2[3][3], cs_real_t mout[3][3])
 Compute the product of two 3x3 real valued matrices. More...
static CS_F_HOST_DEVICE void cs_math_33_transform_r_to_a (const cs_real_t m[3][3], const cs_real_t q[3][3], cs_real_t mout[3][3])
 Compute transformation from relative to absolute reference frame Q^t M Q. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_transform_r_to_a (const cs_real_t m[6], const cs_real_t q[3][3], cs_real_t mout[6])
static CS_F_HOST_DEVICE void cs_math_33_transform_a_to_r (const cs_real_t m[3][3], const cs_real_t q[3][3], cs_real_t mout[3][3])
 Compute transformation from absolute to relative reference frame Q M Q^t. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_transform_a_to_r (const cs_real_t m[6], const cs_real_t q[3][3], cs_real_t mout[6])
static CS_F_HOST_DEVICE void cs_math_33_extract_sym_ant (const cs_real_t m[3][3], cs_real_t m_sym[3][3], cs_real_t m_ant[3][3])
 Extract from the given matrix its symmetric and anti-symmetric part. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_33_main_invariant_2 (const cs_real_t m[3][3])
 Compute the second main invariant of the symmetric part of a 3x3 tensor. More...
static CS_F_HOST_DEVICE void cs_math_33_product_add (const cs_real_t m1[3][3], const cs_real_t m2[3][3], cs_real_t(*restrict mout)[3])
 Add the product of two 3x3 real matrices to a matrix. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_product (const cs_real_t s1[6], const cs_real_t s2[6], cs_real_t *restrict sout)
 Compute the product of two symmetric matrices. More...
static CS_F_HOST_DEVICE void cs_math_reduce_sym_prod_33_to_66 (const cs_real_t s[3][3], cs_real_t(*restrict sout)[6])
 Compute a 6x6 matrix A, equivalent to a 3x3 matrix s, such as: A*R_6 = R*s^t + s*R. More...
static CS_F_HOST_DEVICE void cs_math_sym_33_double_product (const cs_real_t s1[6], const cs_real_t s2[6], const cs_real_t s3[6], cs_real_t(*restrict sout)[3])
 Compute the product of three symmetric matrices. More...
static CS_F_HOST_DEVICE void cs_nvec3 (const cs_real_t v[3], cs_nvec3_t *qv)
 Define a cs_nvec3_t structure from a cs_real_3_t. More...
static CS_F_HOST_DEVICE void cs_math_sym_44_factor_ldlt (cs_real_t ldlt[10])
 LDL^T: Modified Cholesky decomposition of a 4x4 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_44_partial_solve_ldlt (const cs_real_t ldlt[10], const cs_real_t rhs[4])
CS_F_HOST_DEVICE void cs_math_3_length_unitv (const cs_real_t xa[3], const cs_real_t xb[3], cs_real_t *len, cs_real_3_t unitv)
 Compute the length (Euclidean norm) between two points xa and xb in a Cartesian coordinate system of dimension 3. More...
void cs_math_sym_33_eigen (const cs_real_t m[6], cs_real_t eig_vals[3])
 Compute all eigenvalues of a 3x3 symmetric matrix with symmetric storage. More...
void cs_math_33_eigen (const cs_real_t m[3][3], cs_real_t *eig_ratio, cs_real_t *eig_max)
 Compute max/min eigenvalues ratio and max. eigenvalue of a 3x3 symmetric matrix with non-symmetric storage. More...
double cs_math_surftri (const cs_real_t xv[3], const cs_real_t xe[3], const cs_real_t xf[3])
 Compute the area of the convex_hull generated by 3 points. This corresponds to the computation of the surface of a triangle. More...
double cs_math_voltet (const cs_real_t xv[3], const cs_real_t xe[3], const cs_real_t xf[3], const cs_real_t xc[3])
 Compute the volume of the convex_hull generated by 4 points. This is equivalent to the computation of the volume of a tetrahedron. More...
void cs_math_33_eig_val_vec (const cs_real_t m_in[3][3], const cs_real_t tol_err, cs_real_t eig_val[3], cs_real_t eig_vec[3][3])
 Evaluate eigenvalues and eigenvectors of a real symmetric matrix m1[3,3]: m1*m2 = lambda*m2. More...
void cs_math_fact_lu (const int n, const cs_real_t *a, cs_real_t *a_lu)
 Compute LU factorization of an array of dense matrices of identical size. More...
void cs_math_fw_and_bw_lu (const cs_real_t a_lu[], const int n, cs_real_t x[], const cs_real_t b[])
 Compute forward and backward to solve an LU P*P system. More...
const cs_real_t cs_math_zero_threshold
const cs_real_t cs_math_epzero
const cs_real_t cs_math_infinite_r
const cs_real_t cs_math_big_r
const cs_real_t cs_math_pi
const cs_real_t cs_math_1ov3
const cs_real_t cs_math_2ov3
const cs_real_t cs_math_4ov3
const cs_real_t cs_math_5ov3
const cs_real_t cs_math_1ov6
const cs_real_t cs_math_1ov12
const cs_real_t cs_math_1ov24
static const cs_real_33_t cs_math_33_identity
static const cs_real_6_t cs_math_sym_33_identity = {1., 1., 1., 0. ,0., 0.}
◆ cs_math_sym_tensor_component_t
Enumerator
XX
YY
ZZ
XY
YZ
XZ
◆ cs_math_33_3_product()
static CS_F_HOST_DEVICE void cs_math_33_3_product ( const cs_real_t  m[3][3],
inlinestatic
[in]mmatrix of 3x3 real values
[in]vvector of 3 real values
[out]mvvector of 3 real values
◆ cs_math_33_3_product_add()
static CS_F_HOST_DEVICE void cs_math_33_3_product_add ( const cs_real_t  m[3][3],
inlinestatic
[in,out]mvvector of 3 real values
◆ cs_math_33_determinant()
static CS_F_HOST_DEVICE cs_real_t cs_math_33_determinant ( const cs_real_t  m[3][3])
inlinestatic
[in]m3x3 matrix
the determinant
◆ cs_math_33_eig_val_vec()
void cs_math_33_eig_val_vec ( const cs_real_t  m_in[3][3],
Use of Jacobi method for symmetric matrices (adapted from the book Numerical Recipes in C, Chapter 11.1)
[in]m_inmatrix of 3x3 real values (initial)
[in]tol_errabsolute tolerance (sum of off-diagonal elements)
[out]eig_valvector of 3 real values (eigenvalues)
[out]eig_vecmatrix of 3x3 real values (eigenvectors)
◆ cs_math_33_eigen()
void cs_math_33_eigen ( const cs_real_t  m[3][3],
cs_real_t *  eig_ratio,
cs_real_t *  eig_max
Based on: Oliver K. Smith "eigenvalues of a symmetric 3x3 matrix", Communication of the ACM (April 1961) (Wikipedia article entitled "Eigenvalue algorithm")
[in]m3x3 matrix
[out]eig_ratiomax/min
[out]eig_maxmax. eigenvalue
◆ cs_math_33_extract_sym_ant()
static CS_F_HOST_DEVICE void cs_math_33_extract_sym_ant ( const cs_real_t  m[3][3],
inlinestatic
[out]m_symmatrix of 3x3 real values (symmetric part)
[out]m_antmatrix of 3x3 real values (anti-symmetric part)
◆ cs_math_33_inv_cramer()
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer ( const cs_real_t  in[3][3],
cs_real_t  out[3][3]
inlinestatic
[in]inmatrix to inverse
[out]outinversed matrix
◆ cs_math_33_inv_cramer_in_place()
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer_in_place ( cs_real_t  a[3][3])
inlinestatic
[in,out]amatrix to inverse
◆ cs_math_33_inv_cramer_sym_in_place()
static CS_F_HOST_DEVICE void cs_math_33_inv_cramer_sym_in_place ( cs_real_t  a[3][3])
inlinestatic
◆ cs_math_33_main_invariant_2()
static CS_F_HOST_DEVICE cs_real_t cs_math_33_main_invariant_2 ( const cs_real_t  m[3][3])
inlinestatic
trace(S.S) = Sij Sij, where S is the symmetric part of m
◆ cs_math_33_normal_scaling_add()
static CS_F_HOST_DEVICE void cs_math_33_normal_scaling_add ( const cs_real_t  n[3],
cs_real_t  factor,
cs_real_t  t[3][3]
inlinestatic
[in]nnormalised face normal vector
[in]factorfactor
[in,out]tmatrix to be scaled
◆ cs_math_33_product()
static CS_F_HOST_DEVICE void cs_math_33_product ( const cs_real_t  m1[3][3],
inlinestatic
[in]m1matrix of 3x3 real values
[in]m2matrix of 3x3 real values
[out]moutm1.m2 product
◆ cs_math_33_product_add()
static CS_F_HOST_DEVICE void cs_math_33_product_add ( const cs_real_t  m1[3][3],
cs_real_t(*)  mout[3]
inlinestatic
[out]moutmatrix of 3x3 real values
◆ cs_math_33_trace()
static CS_F_HOST_DEVICE cs_real_t cs_math_33_trace ( const cs_real_t  t[3][3])
inlinestatic
[in]ttensor of 3x3 real values
trace (t[0][0] + t[1][1] + t[2][2])
◆ cs_math_33_transform_a_to_r()
static CS_F_HOST_DEVICE void cs_math_33_transform_a_to_r ( const cs_real_t  m[3][3],
inlinestatic
[in]qtransformation matrix of 3x3 real values
[out]moutQ M Q^t
◆ cs_math_33_transform_r_to_a()
static CS_F_HOST_DEVICE void cs_math_33_transform_r_to_a ( const cs_real_t  m[3][3],
inlinestatic
[out]moutQ^t M Q
◆ cs_math_33t_3_product()
static CS_F_HOST_DEVICE void cs_math_33t_3_product ( const cs_real_t  m[3][3],
inlinestatic
◆ cs_math_3_33_3_dot_product() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_33_3_dot_product ( const cs_real_t  n1[3],
inlinestatic
[in]n1vector of 3 real values
[in]n2vector of 3 real values
the resulting dot product n1.t.n2.
◆ cs_math_3_33_3_dot_product() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_33_3_dot_product ( const T  n1[3],
const U  t[3][3],
const V  n2[3]
inline
Template Parameters
Tinput value type
Uinput value type
Vinput value type
◆ cs_math_3_average()
static CS_F_HOST_DEVICE void cs_math_3_average ( const cs_real_t  u[3],
inlinestatic
[in]uvector of 3 real values
[out]uvaverage of u an v := (u+v)/2
◆ cs_math_3_cross_product() [1/2]
static CS_F_HOST_DEVICE void cs_math_3_cross_product ( const cs_real_t  u[3],
inlinestatic
[out]uvcross-product of u an v
◆ cs_math_3_cross_product() [2/2]
static CS_F_HOST_DEVICE void cs_math_3_cross_product ( const T  u[3],
const U  v[3],
V *restrict  uv
inlinestatic
Template Parameters
Tinput value type
Uinput value type
Vinput value type
◆ cs_math_3_distance()
static CS_F_HOST_DEVICE cs_real_t cs_math_3_distance ( const cs_real_t  xa[3],
inlinestatic
[in]xafirst coordinate
[in]xbsecond coordinate
the length between two points xa and xb
◆ cs_math_3_distance_dot_product() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_distance_dot_product ( const cs_real_t  xa[3],
inlinestatic
[in]xcthird coordinate
the dot product
◆ cs_math_3_distance_dot_product() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_distance_dot_product ( const T  xa[3],
const T  xb[3],
const U  xc[3]
inline
Template Parameters
Tinput value type
Uinput value type
the dot product
◆ cs_math_3_dot_product() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_dot_product ( const cs_real_t  u[3],
inlinestatic
the resulting dot product u.v.
◆ cs_math_3_dot_product() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_dot_product ( const T  u[3],
const U  v[3]
inline
Template Parameters
Tinput value type
Uinput value type
◆ cs_math_3_length_unitv()
CS_F_HOST_DEVICE void cs_math_3_length_unitv ( const cs_real_t  xa[3],
cs_real_t *  len,
cs_real_3_t  unitv
[in]xacoordinate of the first extremity
[in]xbcoordinate of the second extremity
[out]lenpointer to the length of the vector va -> vb
[out]unitvunitary vector along va -> vb
◆ cs_math_3_norm() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm ( const cs_real_t  v[3])
inlinestatic
[in]v
the value of the norm
◆ cs_math_3_norm() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_norm ( const T  v[3])
inline
Template Parameters
Tinput value type
[in]v
◆ cs_math_3_normal_scaling() [1/2]
static CS_F_HOST_DEVICE void cs_math_3_normal_scaling ( const cs_real_t  n[3],
cs_real_t  factor,
cs_real_t  v[3]
inlinestatic
[in]factorfactor
[in,out]vvector to be scaled
◆ cs_math_3_normal_scaling() [2/2]
CS_F_HOST_DEVICE void cs_math_3_normal_scaling ( const T  n[3],
U  factor,
V  v[3]
inline
Template Parameters
Tinput value type
Uinput value type
Vinput value type
[in]factorfactor
◆ cs_math_3_normalize() [1/2]
static CS_F_HOST_DEVICE void cs_math_3_normalize ( const cs_real_t  vin[3],
cs_real_t  vout[3]
inlinestatic
To normalize in-place, vin and vout may point to the same array.
[in]vinvector
[out]voutnormalized vector
◆ cs_math_3_normalize() [2/2]
static CS_F_HOST_DEVICE void cs_math_3_normalize ( const T  vin[3],
U  vout[3]
inlinestatic
Template Parameters
Tinput value type
Uinput value type
[in]vinvector
◆ cs_math_3_normalize_threshold()
static CS_F_HOST_DEVICE void cs_math_3_normalize_threshold ( const cs_real_t  vin[3],
cs_real_t  vout[3]
inlinestatic
[in]vinvector
[in]thresthreshold for normalization
◆ cs_math_3_orthogonal_projection() [1/2]
static CS_F_HOST_DEVICE void cs_math_3_orthogonal_projection ( const cs_real_t  n[3],
inlinestatic
[in]nnormal vector direction
[in]vvector to be projected
[out]voutprojection
◆ cs_math_3_orthogonal_projection() [2/2]
CS_F_HOST_DEVICE void cs_math_3_orthogonal_projection ( const T  n[3],
const U  v[3],
V *restrict  vout
inline
Template Parameters
Tinput value type
Uinput value type
Vinput value type
[out]voutprojection
◆ cs_math_3_orthonormal_basis()
static CS_F_HOST_DEVICE void cs_math_3_orthonormal_basis ( const cs_real_t  vect[3],
inlinestatic
[in]vectVector used to build the orthonormal basis
[out]axesaxes basis (cs_real_t[3][3])
◆ cs_math_3_square_distance()
static CS_F_HOST_DEVICE cs_real_t cs_math_3_square_distance ( const cs_real_t  xa[3],
inlinestatic
the square length between two points xa and xb
◆ cs_math_3_square_norm() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_square_norm ( const cs_real_t  v[3])
inlinestatic
square norm of v.
◆ cs_math_3_square_norm() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_square_norm ( const T  v[3])
inline
Template Parameters
Tinput value type
square norm of v.
◆ cs_math_3_sym_33_3_dot_product() [1/2]
static CS_F_HOST_DEVICE cs_real_t cs_math_3_sym_33_3_dot_product ( const cs_real_t  n1[3],
inlinestatic
[in]ttensor of 6 real values [ 0 3 5 ] [ 3 1 4 ] [ 5 4 2 ]
◆ cs_math_3_sym_33_3_dot_product() [2/2]
CS_F_HOST_DEVICE cs_real_t cs_math_3_sym_33_3_dot_product ( const T  n1[3],
const U  t[6],
const V  n2[3]
inline
Template Parameters
Tinput value type
Uinput value type
Vinput value type
◆ cs_math_3_triple_product()
static CS_F_HOST_DEVICE cs_real_t cs_math_3_triple_product ( const cs_real_t  u[3],
inlinestatic
[in]wvector of 3 real values
the scalar triple product: (uxv).w
◆ cs_math_66_6_product()
static CS_F_HOST_DEVICE void cs_math_66_6_product ( const cs_real_t  m[6][6],
inlinestatic
[in]mmatrix of 6x6 real values
[in]vvector of 6 real values
[out]mvvector of 6 real values
◆ cs_math_66_6_product_add()
static CS_F_HOST_DEVICE void cs_math_66_6_product_add ( const cs_real_t  m[6][6],
inlinestatic
◆ cs_math_6_gauss_inverse_in_place()
CS_F_HOST_DEVICE void cs_math_6_gauss_inverse_in_place ( T  a[6])
[in]ainput matrix
[out]boutput matrix (may be identical to a)
◆ cs_math_6_trace()
static CS_F_HOST_DEVICE cs_real_t cs_math_6_trace ( const cs_real_t  t[6])
inlinestatic
[in]tvector of 6 real values (symmetric tensor)
trace (t[0] + t[1] + t[2])
◆ cs_math_binom()
static int cs_math_binom ( int  n,
int  k
inlinestatic
[in]nfirst argument
[in]ksecond argument
the value of binom(n)(k)
◆ cs_math_clamp()
static CS_F_HOST_DEVICE cs_real_t cs_math_clamp ( cs_real_t  x,
cs_real_t  xmin,
cs_real_t  xmax
inlinestatic
[in]xinitial value
[in]xminmin value for clamping
[in]xmaxmax value for clamping
clamped value which is 'x' if xmin < x < xmax or lower/upper bound otherwise
◆ cs_math_fabs()
static CS_F_HOST_DEVICE cs_real_t cs_math_fabs ( cs_real_t  x)
inlinestatic
[in]xvalue
absolute value of the given value
◆ cs_math_fact_lu()
void cs_math_fact_lu ( const int  n,
const cs_real_t *  a,
cs_real_t *  a_lu
[in]nmatrix size
[in]amatrix (size n.n)
[out]a_luLU factorization of matrix (size n.n)
◆ cs_math_fmax()
static CS_F_HOST_DEVICE cs_real_t cs_math_fmax ( cs_real_t  x,
cs_real_t  y
inlinestatic
[in]x,yvalues
the max value
◆ cs_math_fmin()
static CS_F_HOST_DEVICE cs_real_t cs_math_fmin ( cs_real_t  x,
cs_real_t  y
inlinestatic
[in]x,yvalues
the min value
◆ cs_math_fw_and_bw_lu()
void cs_math_fw_and_bw_lu ( const cs_real_t  a_lu[],
int  n,
cs_real_t  x[],
const cs_real_t  b[]
[in]a_lumatrix LU factorization
[in]nmatrix size
[out]xsolution
[out]bright hand side
◆ cs_math_matrix_gauss_inverse()
CS_F_HOST_DEVICE void cs_math_matrix_gauss_inverse ( const T  a[n][n],
T  b[n][n]
inline
[in]ainput matrix
◆ cs_math_pow2()
static CS_F_HOST_DEVICE cs_real_t cs_math_pow2 ( cs_real_t  x)
inlinestatic
[in]xvalue
the square of the given value
◆ cs_math_pow3()
static CS_F_HOST_DEVICE cs_real_t cs_math_pow3 ( cs_real_t  x)
inlinestatic
[in]xvalue
the cube of the given value
◆ cs_math_pow4()
static CS_F_HOST_DEVICE cs_real_t cs_math_pow4 ( cs_real_t  x)
inlinestatic
[in]xvalue
the 4th power of the given value
◆ cs_math_pow5()
static CS_F_HOST_DEVICE cs_real_t cs_math_pow5 ( cs_real_t  x)
inlinestatic
[in]xvalue
the 5th power of the given value
◆ cs_math_reduce_sym_prod_33_to_66()
static CS_F_HOST_DEVICE void cs_math_reduce_sym_prod_33_to_66 ( const cs_real_t  s[3][3],
cs_real_t(*)  sout[6]
inlinestatic
[in]s3x3 matrix
[out]sout6x6 matrix
◆ cs_math_sq()
static CS_F_HOST_DEVICE cs_real_t cs_math_sq ( cs_real_t  x)
inlinestatic
[in]xvalue
◆ cs_math_surftri()
double cs_math_surftri ( const cs_real_t  xv[3],
[in]xvcoordinates of the first vertex
[in]xecoordinates of the second vertex
[in]xfcoordinates of the third vertex
◆ cs_math_sym_33_3_product() [1/2]
static CS_F_HOST_DEVICE void cs_math_sym_33_3_product ( const cs_real_t  m[6],
inlinestatic
◆ cs_math_sym_33_3_product() [2/2]
CS_F_HOST_DEVICE void cs_math_sym_33_3_product ( const T  m[6],
const U  v[3],
V *restrict  mv
inline
Template Parameters
Tinput value type
Uinput value type
Vinput value type
◆ cs_math_sym_33_3_product_add()
static CS_F_HOST_DEVICE void cs_math_sym_33_3_product_add ( const cs_real_t  m[6],
inlinestatic
◆ cs_math_sym_33_determinant()
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_33_determinant ( const cs_real_t  m[6])
inlinestatic
[in]m3x3 symmetric matrix
the determinant
◆ cs_math_sym_33_double_product()
static CS_F_HOST_DEVICE void cs_math_sym_33_double_product ( const cs_real_t  s1[6],
cs_real_t(*)  sout[3]
inlinestatic
Remarks
Symmetric matrix coefficients are stored as follows: (s11, s22, s33, s12, s23, s13)
[in]s1symmetric matrix
[in]s2symmetric matrix
[in]s3symmetric matrix
[out]soutsout = s1 * s2 * s3
◆ cs_math_sym_33_eigen()
void cs_math_sym_33_eigen ( const cs_real_t  m[6],
[in]m3x3 symmetric matrix (m11, m22, m33, m12, m23, m13)
[out]eig_valssize 3 vector
◆ cs_math_sym_33_inv_cramer()
static CS_F_HOST_DEVICE void cs_math_sym_33_inv_cramer ( const cs_real_t  s[6],
inlinestatic
Remarks
[in]ssymmetric matrix
[out]soutsout = 1/s1
◆ cs_math_sym_33_product()
static CS_F_HOST_DEVICE void cs_math_sym_33_product ( const cs_real_t  s1[6],
inlinestatic
Warning: this is valid if and only if s1 and s2 commute (otherwise sout is not symmetric).
Remarks
◆ cs_math_sym_33_sym_33_product_trace()
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_33_sym_33_product_trace ( const cs_real_t  m1[6],
inlinestatic
trace
◆ cs_math_sym_33_transform_a_to_r()
static CS_F_HOST_DEVICE void cs_math_sym_33_transform_a_to_r ( const cs_real_t  m[6],
cs_real_t  mout[6]
inlinestatic
[in]msymetric matrix of 3x3 real values
[out]moutQ M Q^t
◆ cs_math_sym_33_transform_r_to_a()
static CS_F_HOST_DEVICE void cs_math_sym_33_transform_r_to_a ( const cs_real_t  m[6],
cs_real_t  mout[6]
inlinestatic
[out]moutQ^t M Q
◆ cs_math_sym_44_factor_ldlt()
static CS_F_HOST_DEVICE void cs_math_sym_44_factor_ldlt ( cs_real_t  ldlt[10])
inlinestatic
[in,out]ldltpointer to matrix coefficients: (m00, m10, m11, m20, m21, m22, m30, m31, m32, m33) in (f00, l10, f11, l20, l21, f22, l30, l31, l32, f33) out
◆ cs_math_sym_44_partial_solve_ldlt()
static CS_F_HOST_DEVICE cs_real_t cs_math_sym_44_partial_solve_ldlt ( const cs_real_t  ldlt[10],
inlinestatic
Here we only need to use the last element of the solution vector, so we return that value only and simplify the computation.
[in,out]ldltpointer to matrix coefficients: (f00, l10, f11, l20, l21, f22, l30, l31, l32, f33)
[in]rhsright-hand side
◆ cs_math_voltet()
double cs_math_voltet ( const cs_real_t  xv[3],
[in]xccoordinates of the fourth vertex
the volume of the tetrahedron.
◆ cs_nvec3()
static CS_F_HOST_DEVICE void cs_nvec3 ( const cs_real_t  v[3],
cs_nvec3_t *  qv
inlinestatic
[in]vvector of size 3
[out]qvpointer to a cs_nvec3_t structure
◆ cs_math_1ov12
extern
◆ cs_math_1ov24
extern
◆ cs_math_1ov3
extern
◆ cs_math_1ov6
extern
◆ cs_math_2ov3
extern
◆ cs_math_33_identity
static
Initial value:
= {{1., 0., 0.,},
{0., 1., 0.},
{0., 0., 1.}}
◆ cs_math_4ov3
extern
◆ cs_math_5ov3
extern
◆ cs_math_big_r
extern
◆ cs_math_epzero
extern
◆ cs_math_infinite_r
extern
◆ cs_math_pi
extern
◆ cs_math_sym_33_identity
static
◆ cs_math_zero_threshold
extern
