cs_plant_option_t Struct Reference
#include <cs_atmo_ground_model.h>
+ Collaboration diagram for cs_plant_option_t:
Public Attributes
cs_real_t h_canopy
cs_real_t h_canopy_exch
cs_real_t d_leaf
cs_real_t leaf_area_index
cs_real_t k_ext_coef
cs_real_t albedo_plant
cs_real_t emi_plant
cs_real_t c_co2_air
cs_real_t f_co2_0_ground
cs_real_t temp_ref_co2
cs_real_t ea_ground
cs_real_t a_pho
cs_real_t g0_pho
cs_real_t sf_psiv
cs_real_t psif_psiv
cs_real_t oi
cs_real_t koref
cs_real_t kcref
cs_real_t eao
cs_real_t eac
cs_real_t gamma_0
cs_real_t gamma_1
cs_real_t gamma_2
cs_real_t tem_ref_pho
cs_real_t vlmaxref
cs_real_t knitro
cs_real_t jlmaxref
cs_real_t ea_vlmax
cs_real_t ed_vlmax
cs_real_t s_vlmax
cs_real_t ea_jlmax
cs_real_t ed_jlmax
cs_real_t s_jlmax
cs_real_t alpha_pho
cs_real_t theta_pho
cs_real_t v_gco2_incr
cs_real_t v_gco2_decr
cs_real_t xiv
cs_real_t r_root
cs_real_t z_root
cs_real_t ld_root
int water_potential_model
cs_real_t psi_e
cs_real_t psi_pow
cs_real_t kref
cs_real_t canopy_mix_l
cs_real_t turb_prandtl
cs_real_t cdrag_leaf
cs_real_t zos
cs_real_t zref_plant
cs_real_t k_eddy_hc
cs_real_t tort_factor
cs_real_t ground_exch_l
cs_real_t dry_ground_porosity
cs_real_t dv
Member Data Documentation
◆ a_pho
cs_real_t a_pho
Stomatal conductance constant
◆ albedo_plant
Albedo of the plant
◆ alpha_pho
cs_real_t alpha_pho
Photon flux constant 1
◆ c_co2_air
cs_real_t c_co2_air
CO2 concentration in the air
◆ canopy_mix_l
Canopy mixing length
◆ cdrag_leaf
Leaf draf coefficient
◆ d_leaf
cs_real_t d_leaf
Leaf length
◆ dry_ground_porosity
Dry ground porosity
◆ dv
Ground constant for the porosity
◆ ea_ground
cs_real_t ea_ground
Activation energy for the CO2
◆ ea_jlmax
cs_real_t ea_jlmax
Activation energy for photosynthesis process 2
◆ ea_vlmax
cs_real_t ea_vlmax
Activation energy for photosynthesis process 1
◆ eac
cs_real_t eac
Activation energy linked to constant 3
◆ eao
cs_real_t eao
Activation energy linked to constant 2
◆ ed_jlmax
cs_real_t ed_jlmax
Desactivation energy for photsynthesis process 2
◆ ed_vlmax
cs_real_t ed_vlmax
Desactivation energy for photsynthesis process 1
◆ emi_plant
cs_real_t emi_plant
Emissivity of the plant
◆ f_co2_0_ground
Constant for the CO2 flux in the ground
◆ g0_pho
cs_real_t g0_pho
Stomatal conductance minimum value
◆ gamma_0
cs_real_t gamma_0
Gamma const 0
◆ gamma_1
cs_real_t gamma_1
Gamma const 1
◆ gamma_2
cs_real_t gamma_2
Gamma const 2
◆ ground_exch_l
Ground exchange length
◆ h_canopy
cs_real_t h_canopy
Height of the canopy
◆ h_canopy_exch
Plant air exchange height
◆ jlmaxref
cs_real_t jlmaxref
Max photon flux
◆ k_eddy_hc
cs_real_t k_eddy_hc
Eddy diffusivity at the top of the canopy
◆ k_ext_coef
Canopy extinction coefficient for the radiation
◆ kcref
cs_real_t kcref
Plant process constant 3
◆ knitro
cs_real_t knitro
Leaf allocation coef for the nitrogen
◆ koref
cs_real_t koref
Plant process constant 2
◆ kref
cs_real_t kref
Reference ground hydraulic conductivity
◆ ld_root
cs_real_t ld_root
Length of roots in a volume of ground
◆ leaf_area_index
Leaf Area Index
◆ oi
Plant process constant 1
◆ psi_e
cs_real_t psi_e
Ref water potential
◆ psi_pow
cs_real_t psi_pow
Air hydraulic power
◆ psif_psiv
cs_real_t psif_psiv
Water stress reference value
◆ r_root
cs_real_t r_root
Root radius
◆ s_jlmax
cs_real_t s_jlmax
Entropy constant for photsynthesis process 2
◆ s_vlmax
cs_real_t s_vlmax
Entropy constant for photsynthesis process 1
◆ sf_psiv
cs_real_t sf_psiv
Constant factor for the water stress model
◆ tem_ref_pho
Reference temperature for the photsynthesis
◆ temp_ref_co2
Reference temperature for the CO2 exchanges
◆ theta_pho
cs_real_t theta_pho
Photon flux constant 2
◆ tort_factor
Ground tortuosity factor
◆ turb_prandtl
Turbulent Prandtl in the canopy
◆ v_gco2_decr
Speed of decrease of gco2
◆ v_gco2_incr
Speed of increase of gco2
◆ vlmaxref
cs_real_t vlmaxref
Photosynhtesis process 1 constant
◆ water_potential_model
Choice of water potential model
◆ xiv
cs_real_t xiv
Hydraulic resistance
◆ z_root
cs_real_t z_root
Root depth
◆ zos
cs_real_t zos
Bare ground rugosity
◆ zref_plant
Reference height of the plant
