cs_turbulence_t Struct Reference
#include <cs_cdo_turbulence.h>
+ Collaboration diagram for cs_turbulence_t:
Public Attributes
Turbulence modelling
Set of parameters to handle turbulence modelling.
cs_turbulence_param_t * param
cs_equation_t * mom_eq
Main properties related to the turbulence modelling
cs_property_t * rho
cs_property_t * mu_tot
cs_property_t * mu_l
cs_real_t * mu_tot_array
Main related fields
cs_field_t * mu_t_field
cs_field_t * rij
Main structure and function pointers
The context structure is a structure cast on-the-fly and function pointers are a limited set of functions associated to the main operations for this structure: initialization, destruction, computation and update.
void * context
cs_turb_init_context_t * init_context
cs_turb_free_context_t * free_context
cs_turb_compute_t * compute
cs_turb_compute_t * compute_steady
cs_turb_update_t * update
void add_boundary_stress (const cs_mesh_t *m, cs_field_t *boundary_stress) const
 Compute and add the turbulent part of the boundray stress. More...
void check_convergence (const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, const cs_param_psteady_t &psp, cs_cdo_navsto_psteady_cvg_t &ps_cvg) const
 Check the convergence of the pseudo-steady algorithm when the unsteady Navier-Stokes system with a CDO face-based scheme is used. More...
Member Function Documentation
◆ add_boundary_stress()
void add_boundary_stress ( const cs_mesh_t *  m,
cs_field_t *  boundary_stress
) const
[in]boundary_stresspointer to a cs_field_t structure
◆ check_convergence()
void check_convergence ( const cs_cdo_quantities_t *  quant,
const cs_time_step_t *  ts,
const cs_param_psteady_t &  psp,
cs_cdo_navsto_psteady_cvg_t &  ps_cvg
) const
[in]quantpointer to a cs_cdo_quantities_t struct.
[in]tspointer to a cs_time_step_t structure
[in]psppointer to a cs_param_psteady_t struct.
[in]ps_cvgpointer to a cs_cdo_navsto_psteady_cvg_t struct.
Member Data Documentation
◆ compute
compute
Function pointer to compute all variables related to a turbulence model
◆ compute_steady
compute_steady
Function pointer to compute in steady mode all variables related to a turbulence model
◆ context
context
Context related to the turbulence modelling. This structure is cast on-the-fly according to the modelling choices
◆ free_context
free_context
Function pointer to de-allocate memory owned by the context structure
◆ init_context
init_context
Function pointer to initialize the context structure
◆ mom_eq
mom_eq
Pointer to the momentum equation structure.
◆ mu_l
mu_l
laminar viscosity
◆ mu_t
mu_t
total viscosity (dynamic turbulent + laminar)
dynamic turbulent viscosity
◆ mu_t_field
cs_field_t* mu_t_field
Reynolds stress tensor
◆ mu_tot
cs_property_t* mu_tot
mass density
◆ mu_tot_array
mu_tot_array
Array storing the value of the total viscosity in each cell
◆ param
param
Main set of parameters to handle turbulence modelling. The members of this structure are shared with the legacy part.
◆ rho
rho
mass density
◆ rij
rij
◆ update
update
Function pointer to perform the update step (properties or arrays associated to the variables of a turbulence model are updated)
