cs_cdocb_scaleq_t Struct Reference
#include <cs_cdocb_priv.h>
+ Collaboration diagram for cs_cdocb_scaleq_t:
Public Attributes
Main parameters
Main members of the CDO cell-based structure
int var_field_id
int bflux_field_id
cs_lnum_t n_faces
cs_lnum_t n_cells
cs_lnum_t n_dofs
cs_real_t * flux
cs_real_t * flux_pre
cs_real_t * face_values
cs_real_t * face_values_pre
cs_real_t ** div_op_cw
cs_hodge_t ** diff_hodge
cs_hodge_compute_t * compute_diff_hodge
cs_cdo_enforce_bc_t * enforce_dirichlet
cs_cdo_enforce_bc_t * enforce_neumann
cs_cdo_enforce_bc_t * enforce_robin_bc
cs_real_t * block21_op
cs_cdo_system_helper_t * system_helper
Assembly stage
Additional members which may be used to assemble the system
cs_cdocb_scaleq_assemble_t * assemble
Solve stage
Additional members which may be used to solve the system
cs_cdocb_scaleq_solve_t * solve
cs_saddle_solver_t * saddle_solver
Member Data Documentation
◆ assemble
◆ bflux_field_id
int bflux_field_id
◆ block21_op
cs_real_t* block21_op
◆ compute_diff_hodge
cs_hodge_compute_t* compute_diff_hodge
◆ diff_hodge
cs_hodge_t** diff_hodge
◆ div_op_cw
cs_real_t** div_op_cw
◆ enforce_dirichlet
cs_cdo_enforce_bc_t* enforce_dirichlet
◆ enforce_neumann
cs_cdo_enforce_bc_t* enforce_neumann
◆ enforce_robin_bc
cs_cdo_enforce_bc_t* enforce_robin_bc
◆ face_values
cs_real_t* face_values
◆ face_values_pre
cs_real_t* face_values_pre
◆ flux
cs_real_t* flux
◆ flux_pre
cs_real_t* flux_pre
◆ n_cells
cs_lnum_t n_cells
◆ n_dofs
cs_lnum_t n_dofs
◆ n_faces
cs_lnum_t n_faces
◆ saddle_solver
cs_saddle_solver_t* saddle_solver
Function dedicated to the resolution of the saddle-point system
◆ solve
solve
◆ system_helper
cs_cdo_system_helper_t* system_helper
◆ var_field_id
int var_field_id
