Scalar balance on full domain
This is an example of cs_user_extra_operations which performs a scalar balance on the full computational domain. It is possible to customize the output to extract the contribution of some boundary zones of interest.
Define local variables
cs_lnum_t cell_id, cell_id1, cell_id2, face_id;
int nt_cur = domain->time_step->nt_cur;
Definition: cs_defs.h:332
cs_rreal_t cs_rreal_3_t[3]
Definition: cs_defs.h:378
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:342
Definition: cs_defs.h:325
Definition: cs_mesh_quantities.h:88
cs_rreal_3_t * diipb
Definition: cs_mesh_quantities.h:118
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:108
cs_real_t * cell_vol
cs_lnum_t * b_face_cells
Definition: cs_mesh.h:112
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
cs_lnum_t n_cells_with_ghosts
Definition: cs_mesh.h:151
cs_lnum_t n_cells
Definition: cs_mesh.h:97
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
Get the physical fields
Initialization step
double vol_balance = 0.;
double div_balance = 0.;
double a_wall_balance = 0.;
double h_wall_balance = 0.;
double sym_balance = 0.;
double in_balance = 0.;
double out_balance = 0.;
double mass_i_balance = 0.;
double mass_o_balance = 0.;
double tot_balance = 0.;
return;
int iflmas =
h->get_key_int(
"inner_mass_flux_id");
int iflmab =
h->get_key_int(
"boundary_mass_flux_id");
auto cvar_h =
h->get_val_s();
auto cvara_h =
h->get_val_s(1);
if (false) {
true,
1,
for (face_id = 0; face_id < n_b_faces; face_id++) {
cell_id = b_face_cells[face_id];
h_reconstructed[face_id] = cvar_h[cell_id]
+ grad(cell_id, 0)*diipb[face_id][0]
+ grad(cell_id, 1)*diipb[face_id][1]
+ grad(cell_id, 2)*diipb[face_id][2];
} else {
h_reconstructed[face_id] = cvar_h[cell_id];
Define a templated array class (owner of data)
Definition: cs_array.h:1118
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
void cs_field_gradient_scalar(const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *restrict grad)
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_field_operator.cpp:328
@ h
Definition: cs_field_pointer.h:90
Computation step
for (cell_id = 0; cell_id < n_cells; cell_id++) {
vol_balance += cell_vol[cell_id] *
rho[cell_id]
* (cvara_h[cell_id] - cvar_h[cell_id]);
for (face_id = 0; face_id < n_i_faces; face_id++) {
cell_id1 = i_face_cells[face_id][0];
cell_id2 = i_face_cells[face_id][1];
if (cell_id1 < n_cells)
div_balance += i_mass_flux[face_id] *
dt[cell_id1] * cvar_h[cell_id1];
if (cell_id2 < n_cells)
div_balance -= i_mass_flux[face_id] *
dt[cell_id2] * cvar_h[cell_id2];
div_balance += b_mass_flux[face_id] *
dt[cell_id] * cvar_h[cell_id];
face_id = face_list[i];
a_wall_balance += - b_face_surf[face_id] *
dt[cell_id]
* (af_H[face_id] + bf_H[face_id] * h_reconstructed[face_id])
- b_mass_flux[face_id] *
dt[cell_id]
* (a_H[face_id] + b_H[face_id] * h_reconstructed[face_id]);
h_wall_balance += - b_face_surf[face_id] *
dt[cell_id]
dt[cell_id]
sym_balance += - b_face_surf[face_id] *
dt[cell_id]
dt[cell_id]
in_balance += - b_face_surf[face_id] *
dt[cell_id]
dt[cell_id]
out_balance += - b_face_surf[face_id] *
dt[cell_id]
dt[cell_id]
double b_tot[9] = {
vol_balance, div_balance, a_wall_balance, h_wall_balance,
sym_balance, in_balance, out_balance, mass_i_balance, mass_o_balance
vol_balance = b_tot[0], div_balance = b_tot[1];
a_wall_balance = b_tot[2], h_wall_balance = b_tot[3];
sym_balance = b_tot[4], in_balance = b_tot[5], out_balance = b_tot[6];
mass_i_balance = b_tot[7], mass_o_balance = b_tot[8];
tot_balance = vol_balance + div_balance + a_wall_balance + h_wall_balance
+ sym_balance + in_balance + out_balance + mass_i_balance
+ mass_o_balance;
@ CS_DOUBLE
Definition: cs_defs.h:295
@ rho
Definition: cs_field_pointer.h:96
@ dt
Definition: cs_field_pointer.h:61
static void cs_parall_sum(int n, cs_datatype_t datatype, void *val)
Sum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:139
void cs_selector_get_b_face_list(const char *criteria, cs_lnum_t *n_b_faces, cs_lnum_t b_face_list[])
Fill a list of boundary faces verifying a given selection criteria.
Definition: cs_selector.cpp:89
Write the balance at time step n
rho[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
dt[cell_id]
double b_tot[9] = {
+ mass_o_balance;
