1#ifndef CS_XDEF_CW_EVAL_H
2#define CS_XDEF_CW_EVAL_H
44#define _dp3 cs_math_3_dot_product
161 *eval = constant_val[0];
186 eval[0] = constant_val[0];
187 eval[1] = constant_val[1];
188 eval[2] = constant_val[2];
213 for (
int k = 0;
k < 6;
k++)
214 eval[
k] = constant_val[
k];
238 for (
int ki = 0; ki < 3; ki++)
239 for (
int kj = 0; kj < 3; kj++)
240 eval[3*ki+kj] = constant_val[ki][kj];
272 for (
int i = 0; i < n_points; i++) {
273 eval[3*i ] = constant_val[0];
274 eval[3*i + 1] = constant_val[1];
275 eval[3*i + 2] = constant_val[2];
339 " %s: Array storing the evaluation should be allocated before"
340 " the call to this function.", __func__);
341 assert(input != NULL);
374 " %s: Array storing the evaluation should be allocated before"
375 " the call to this function.", __func__);
379 assert(input != NULL);
446 " %s: Array storing the evaluation should be allocated before"
447 " the call to this function.", __func__);
449 assert(input != NULL);
482 " %s: Array storing the evaluation should be allocated before"
483 " the call to this function.", __func__);
487 assert(input != NULL);
521 assert(input != NULL);
524 " %s: Array storing the evaluation should be allocated before"
525 " the call to this function.", __func__);
528 for (
529 for (
530 eval[3*ki+kj] = constant_val[ki][kj];
561 " %s: Array storing the evaluation should be allocated before"
562 " the call to this function.", __func__);
566 assert(input != NULL);
1172 for (
int k = 0;
k < 3;
k++)
1173 eval[3*f+
k] *= fq.
meas;
Definition: bft_error.cpp:187
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
#define CS_UNUSED(x)
Definition: cs_defs.h:518
Definition: cs_defs.h:325
@ k
const cs_flag_t cs_flag_primal_face
Definition: cs_flag.cpp:53
static bool cs_flag_test(cs_flag_t flag_to_check, cs_flag_t reference)
Check if two flags share the same pattern Return true if the flag to check has at least the pattern o...
Definition: cs_flag.h:333
static bool cs_eflag_test(cs_eflag_t flag_to_check, cs_eflag_t reference)
Check if a two compute flag share the same pattern Return true if the computed flag to check has at l...
Definition: cs_flag.h:381
@ CS_FLAG_COMP_PFQ
Definition: cs_flag.h:233
CS_F_HOST_DEVICE void cs_math_33_3_product(const T m[3][3], const U v[3], V *restrict mv)
Compute the product of a matrix of 3x3 real values by a vector of 3 real values.
Definition: cs_math.h:389
cs_quadrature_type_t
Type of quadrature to use when computing an integral quantity. This rationale is used for integrals a...
Definition: cs_quadrature.h:79
void() cs_quadrature_tria_integral_t(double tcur, const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_analytic_func_t *ana, void *input, double results[])
Compute the integral over a triangle based on a specified quadrature rule and add it to results.
Definition: cs_quadrature.h:196
void() cs_quadrature_tetra_integral_t(double tcur, const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_analytic_func_t *ana, void *input, double results[])
Compute the integral over a tetrahedron based on a specified quadrature rule and add it to results.
Definition: cs_quadrature.h:223
void cs_xdef_cw_eval_flux_by_vector_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the (scalar-valued) normal flux of a quantity defined by an analytic ...
Definition: cs_xdef_cw_eval.cpp:2058
static void cs_xdef_cw_eval_scalar_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a scalar function defined through a descript...
Definition: cs_xdef_cw_eval.h:325
void cs_xdef_cw_eval_tensor_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a ce...
Definition: cs_xdef_cw_eval.cpp:589
static void cs_xdef_cw_eval_symtens_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a tensor-valued quantity with a symmetric storage by a cellwise process.
Definition: cs_xdef_cw_eval.h:204
static void cs_xdef_cw_eval_face_drham_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating at the center of the face a scalar function defined through a descrip...
Definition: cs_xdef_cw_eval.h:403
static void cs_xdef_cw_eval_tensor_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a tensor-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:229
static void cs_xdef_cw_eval_vector_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a vector-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:176
void cs_xdef_cw_eval_scalar_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.cpp:366
void cs_xdef_cw_eval_vect_avg_reduction_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the reduction by averages of a analytic function by a cellwise proces...
Definition: cs_xdef_cw_eval.cpp:2480
#define _dp3
Definition: cs_xdef_cw_eval.h:44
void() cs_xdef_cw_eval_int_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:107
void cs_xdef_cw_eval_flux_by_scalar_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by analytic function (scalar-va...
Definition: cs_xdef_cw_eval.cpp:1863
void cs_xdef_cw_eval_flux_v_by_vector_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by a vector-valued quantities and relying on ...
Definition: cs_xdef_cw_eval.cpp:1514
void cs_xdef_cw_eval_tensor_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a tensor function defined through a descript...
Definition: cs_xdef_cw_eval.cpp:454
void cs_xdef_cw_eval_c_int_by_analytic(const cs_cell_mesh_t *cm, double t_eval, cs_analytic_func_t *ana, void *input, cs_quadrature_tetra_integral_t *qfunc, cs_real_t *eval)
Integrate an analytic function over a cell.
Definition: cs_xdef_cw_eval.cpp:152
void cs_xdef_cw_eval_vector_flux_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal vector-valued flux of a quantity defined by analytic funct...
Definition: cs_xdef_cw_eval.cpp:2244
void cs_xdef_cw_eval_at_xyz_by_analytic(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined by analytic function at a precise location (x,...
Definition: cs_xdef_cw_eval.cpp:848
void() cs_xdef_cw_eval_xyz_t(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity at several locations in a cell defined through a descripto...
Definition: cs_xdef_cw_eval.h:85
void cs_xdef_cw_eval_vector_at_xyz_by_field(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined by a field at a precise location inside a cell Use...
Definition: cs_xdef_cw_eval.cpp:973
static void cs_xdef_cw_eval_vector_at_xyz_by_val(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined by analytic function at a precise location inside ...
Definition: cs_xdef_cw_eval.h:259
void cs_xdef_cw_eval_flux_v_by_vector_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by vector-valued quantities....
Definition: cs_xdef_cw_eval.cpp:1104
void cs_xdef_cw_eval_by_analytic(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity at the cell center defined using an analytic function by a cellwise process (usag...
Definition: cs_xdef_cw_eval.cpp:657
void cs_xdef_cw_eval_flux_v_by_scalar_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by a scalar-valued quantities and relying on ...
Definition: cs_xdef_cw_eval.cpp:1172
void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:64
void cs_xdef_cw_eval_f_int_by_analytic(const cs_cell_mesh_t *cm, double t_eval, short int f, cs_analytic_func_t *ana, void *input, cs_quadrature_tria_integral_t *qfunc, cs_real_t *eval)
Integrate an analytic function over a face.
static void cs_xdef_cw_eval_tensor_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:549
void cs_xdef_cw_eval_scal_avg_reduction_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.cpp:2425
void cs_xdef_cw_eval_vector_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.cpp:543
void cs_xdef_cw_eval_vector_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a vector function defined through a descript...
Definition: cs_xdef_cw_eval.cpp:409
static void cs_xdef_cw_eval_scalar_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a scalar-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:152
void cs_xdef_cw_eval_scalar_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.cpp:499
void cs_xdef_cw_eval_by_field(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity inside a cell defined using a field Variation using a cs_cell_mesh_t structure.
Definition: cs_xdef_cw_eval.cpp:796
static void cs_xdef_cw_eval_vector_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:432
void cs_xdef_cw_eval_flux_v_by_scalar_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by scalar-valued quantities....
Definition: cs_xdef_cw_eval.cpp:1038
void cs_xdef_cw_eval_by_array(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity at cells defined by an array. Array is assumed to be interlaced....
Definition: cs_xdef_cw_eval.cpp:689
void cs_xdef_cw_eval_by_time_func(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity by a cellwise process using a definition by time function.
Definition: cs_xdef_cw_eval.cpp:631
static void cs_xdef_cw_eval_scalar_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:362
void cs_xdef_cw_eval_vector_at_xyz_by_array(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Definition: cs_xdef_cw_eval.cpp:887
void cs_xdef_cw_eval_fc_int_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_analytic_func_t *ana, void *input, const short int dim, cs_quadrature_tetra_integral_t *q_tet, cs_quadrature_tria_integral_t *q_tri, cs_real_t *c_int, cs_real_t *f_int)
Routine to integrate an analytic function over a cell and its faces.
Definition: cs_xdef_cw_eval.cpp:249
static void cs_xdef_cw_eval_vector_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:470
static void cs_xdef_cw_eval_tensor_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:509
void cs_xdef_cw_eval_flux_by_tensor_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by values. Use of a cs_cell_mes...
Definition: cs_xdef_cw_eval.h:1160
static void cs_xdef_cw_eval_flux_by_vector_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by a vector-valued flux for the...
Definition: cs_xdef_cw_eval.h:294
void() cs_xdef_cw_eval_face_t(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:129
Definition: cs_cdo_local.h:242
cs_lnum_t * f_ids
Definition: cs_cdo_local.h:279
cs_eflag_t flag
Definition: cs_cdo_local.h:244
cs_quant_t * face
Definition: cs_cdo_local.h:284
Definition: cs_cdo_quantities.h:134
double meas
Definition: cs_cdo_quantities.h:136
double center[3]
Definition: cs_cdo_quantities.h:138
double unitv[3]
Definition: cs_cdo_quantities.h:137
Context structure when a definition by analytic function is used.
Definition: cs_xdef.h:288
cs_analytic_func_t * func
Definition: cs_xdef.h:300
void * input
Definition: cs_xdef.h:307
Context structure when an array is used for the definition.
Definition: cs_xdef.h:209
cs_real_t * values
Definition: cs_xdef.h:269
cs_flag_t value_location
Definition: cs_xdef.h:265
