cs_walldistance.cpp File Reference
#include <cassert>
#include "alge/cs_blas.h"
#include "base/cs_boundary.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_post.h"
#include "bft/bft_printf.h"
#include "cdo/cs_equation.h"
#include "cdo/cs_reco.h"
#include "mesh/cs_mesh.h"
#include "cdo/cs_walldistance.h"
+ Include dependency graph for cs_walldistance.cpp:
Macros
#define _dp3   cs_math_3_dot_product
#define CS_WALLDISTANCE_DBG   0
static void _compute_poisson_cdovcb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, const cs_equation_t *eq, cs_real_t dist[])
 Compute the wall distance for a vertex+cell-based scheme Estimation based on a Poisson equation. More...
static void _compute_poisson_cdovb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, cs_real_t dist[])
 Compute the wall distance for a vertex-based scheme Estimation based on a Poisson equation. More...
static void _compute_poisson_cdofb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_field_t *field, cs_real_t dist[])
 Compute the wall distance for a face-based scheme Estimation based on a Poisson equation. More...
bool cs_walldistance_is_activated (void)
 Test if the computation of the wall distance is activated. More...
void cs_walldistance_activate (void)
 Activate the future computation of the wall distance. More...
void cs_walldistance_setup (void)
 Setup the equation related to the wall distance. More...
void cs_walldistance_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the wall distance. More...
static cs_equation_t * cs_wd_poisson_eq = nullptr
◆ _dp3
◆ CS_WALLDISTANCE_DBG
◆ _compute_poisson_cdofb()
static void _compute_poisson_cdofb ( const cs_cdo_connect_t *  connect,
const cs_cdo_quantities_t *  cdoq,
const cs_equation_t *  eq,
const cs_field_t *  field,
cs_real_t  dist[]
static
[in]eqpointer to the associated cs_equation_t structure
[in]fieldpointer to a cs_field_t structure
[in,out]distarray storing the wall distance to compute
◆ _compute_poisson_cdovb()
static void _compute_poisson_cdovb ( const cs_cdo_connect_t *  connect,
cs_real_t  dist[]
static
◆ _compute_poisson_cdovcb()
static void _compute_poisson_cdovcb ( const cs_cdo_connect_t *  connect,
cs_real_t  dist[]
static
[in]eqpointer to the related cs_equation_t structure
◆ cs_walldistance_activate()
void cs_walldistance_activate ( void  )
◆ cs_walldistance_compute()
void cs_walldistance_compute ( const cs_mesh_t *  mesh,
const cs_time_step_t *  time_step,
◆ cs_walldistance_is_activated()
bool cs_walldistance_is_activated ( void  )
true if the wall distance computation is requested, false otherwise
◆ cs_walldistance_setup()
void cs_walldistance_setup ( void  )
◆ cs_wd_poisson_eq
cs_equation_t* cs_wd_poisson_eq = nullptr
static
