cs_wall_distance_options_t Struct Reference
#include <cs_wall_distance.h>
+ Collaboration diagram for cs_wall_distance_options_t:
Public Attributes
int need_compute
int is_up_to_date
int method
Member Data Documentation
◆ is_up_to_date
int is_up_to_date
Is the wall distance up to date ?
◆ method
int method
Method used to calculate the distance to the wall y and the non-dimensional distance $ y+ $ for all the cells of the calculation domain (when needed):
  • 1: standard algorithm (based on a Poisson equation for y and convection equation for $ y+ $).
  • 2: brute force algorithm (based on geometrical considerations), for serial mode without periodicity only; useful only as a reference for testing.
Note that in the case of restarts, reading the distance from the restart file will avoid minor differences due to the fact that the iterative method will add at least an additional iteration, even if already converged.
◆ need_compute
int need_compute
Does the wall distance need to be computed ?
