cs_turbulence_kw.h File Reference
+ Include dependency graph for cs_turbulence_kw.h:
void cs_turbulence_kw_clip (int phase_id, cs_lnum_t n_cells)
 Clip k and omega. More...
void cs_turbulence_kw (int phase_id)
 Solve the k-omega equations. More...
void cs_turbulence_kw_mu_t (int phase_id)
 Calculation of turbulent viscosity for the $ k - \omega $ SST model. More...
◆ cs_turbulence_kw()
void cs_turbulence_kw ( int  phase_id)
Solve the $ k - \omega $ SST for incompressible flows or slightly compressible flows for one time step.
[in]phase_idturbulent phase id (-1 for single phase flow)
◆ cs_turbulence_kw_clip()
void cs_turbulence_kw_clip ( int  phase_id,
cs_lnum_t  n_cells
Clip k and omega.
[in]n_cellsnumber of cells
◆ cs_turbulence_kw_mu_t()
void cs_turbulence_kw_mu_t ( int  phase_id)
\[ \mu_T = \rho A1 \dfrac{k}{\max(A1 \omega; \; S f_2)} \]
with
\[ S = \sqrt{  2 S_{ij} S_{ij}} \]
\[ S_{ij} = \dfrac{\der{u_i}{x_j} + \der{u_j}{x_i}}{2}\]
and $ f_2 = \tanh(arg2^2) $
\[ arg2^2 = \max(2 \dfrac{\sqrt{k}}{C_\mu \omega y}; \;
                  500 \dfrac{\nu}{\omega y^2}) \]
where $ y $ is the distance to the wall.
$ \divs{\vect{u}} $ is calculated at the same time than $ S $ for use in cs_turbulence_kw.
with
