cs_turbulence_kw.h
1#ifndef CS_TURBULENCE_KW_H
2#define CS_TURBULENCE_KW_H
5 * k-w turbulence model.
31 * Local headers
34#include "base/cs_defs.h"
36/*=============================================================================
37 * Public function prototypes
47/*----------------------------------------------------------------------------*/
48
49extern "C" void
50cs_turbulence_kw_clip(int phase_id,
51 cs_lnum_t n_cells);
52
53
54/*----------------------------------------------------------------------------*/
63/*----------------------------------------------------------------------------*/
64
65extern "C" void
66cs_turbulence_kw(int phase_id);
67
68/*----------------------------------------------------------------------------*/
87/*----------------------------------------------------------------------------*/
88
89extern "C" void
90cs_turbulence_kw_mu_t(int phase_id);
91
92/*----------------------------------------------------------------------------*/
93
94#endif /* CS_TURBULENCE_KW_H */
Definition: cs_defs.h:325
void cs_turbulence_kw_mu_t(int phase_id)
Calculation of turbulent viscosity for the SST model.
Definition: cs_turbulence_kw.cpp:1808
void cs_turbulence_kw(int phase_id)
Solve the k-omega equations.
Definition: cs_turbulence_kw.cpp:268
void cs_turbulence_kw_clip(int phase_id, cs_lnum_t n_cells)
Clip k and omega.
Definition: cs_turbulence_kw.cpp:126
