54#define ICNTL(I) icntl[(I)-1]
55#define CNTL(I) cntl[(I)-1]
56#define INFOG(I) infog[(I)-1]
57#define INFO(I) info[(I)-1]
58#define RINFOG(I) rinfog[(I)-1]
59#define RINFO(I) rinfo[(I)-1]
60#define KEEP(I) keep[(I)-1]
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
cs_log_t
Definition: cs_log.h:44
Definition: cs_matrix.h:108
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
cs_sles_convergence_state_t
Definition: cs_sles.h:57
cs_sles_pc_t * cs_sles_mumps_pc_create(const cs_param_sles_t *slesp)
Create a preconditioner structure relying on MUMPS solver.
Definition: cs_sles_mumps.cpp:2783
void cs_sles_mumps_free(void *context)
Free MUMPS linear equation solver setup context.
Definition: cs_sles_mumps.cpp:2899
void() cs_sles_mumps_setup_hook_t(const cs_param_sles_t *slesp, void *context, void *mumps)
Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup...
Definition: cs_sles_mumps.h:82
void cs_sles_mumps_library_info(cs_log_t log_type)
Print information on MUMPS library.
Definition: cs_sles_mumps.cpp:3845
void cs_sles_mumps_set_zero_sthreshold(double thr)
Modifiy the default value used as a threshold to clean matrix values sent to MUMPS in case of factori...
Definition: cs_sles_mumps.cpp:2716
void cs_sles_mumps_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup MUMPS linear equation solver.
Definition: cs_sles_mumps.cpp:3033
void cs_sles_mumps_destroy(void **context)
Destroy MUMPS linear system solver info and context.
Definition: cs_sles_mumps.cpp:3001
void cs_user_sles_mumps_hook(const cs_param_sles_t *slesp, void *context, void *pmumps)
Function pointer for advanced user settings of a MUMPS solver. This function is called two times duri...
Definition: cs_sles_mumps.cpp:2674
struct _cs_sles_mumps_t cs_sles_mumps_t
Definition: cs_sles_mumps.h:88
void * cs_sles_mumps_copy(const void *context)
Create MUMPS linear system solver info and context based on existing info and context.
Definition: cs_sles_mumps.cpp:2871
cs_sles_convergence_state_t cs_sles_mumps_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Call MUMPS linear equation solver.
Definition: cs_sles_mumps.cpp:3523
void cs_sles_mumps_log(const void *context, cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles_mumps.cpp:3759
void cs_sles_mumps_set_zero_dthreshold(double thr)
Definition: cs_sles_mumps.cpp:2699
cs_sles_mumps_t * cs_sles_mumps_create(const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
Create MUMPS linear system solver info and context.
Definition: cs_sles_mumps.cpp:2822
cs_sles_mumps_t * cs_sles_mumps_define(int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
Define and associate a MUMPS linear system solver for a given field or equation name.
Definition: cs_sles_mumps.cpp:2750
Definition: cs_sles_pc.h:65
Definition: cs_param_sles.h:63
