cs_multigrid_smoother.cpp File Reference
#include <stdarg.h>
#include <mpi.h>
#include "base/cs_mem.h"
#include "base/cs_dispatch.h"
#include "alge/cs_sles_it.h"
#include "alge/cs_sles_it_priv.h"
#include "alge/cs_multigrid_smoother.h"
+ Include dependency graph for cs_multigrid_smoother.cpp:
cs_sles_it_t * cs_multigrid_smoother_create (cs_sles_it_type_t smoother_type, int poly_degree, int n_iter)
 Create iterative sparse linear system solver info and context used as a smoother in a multigrid solver. More...
void cs_multigrid_smoother_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup iterative sparse linear equation solver in case of used as a multigrid smoother. More...
cs_sles_convergence_state_t cs_multigrid_smoother_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call iterative sparse linear equation solver. More...
Iterative linear solvers used as multigrid smoothers only.
These smoothers are based on iterative solvers, but are simplified so as to avoid the cost of some residual computation and convergence testing operations.
◆ cs_multigrid_smoother_create()
cs_sles_it_t * cs_multigrid_smoother_create ( cs_sles_it_type_t  smoother_type,
int  poly_degree,
int  n_iter
[in]smoother_typetype of smoother (CG, Jacobi, ...)
[in]poly_degreepreconditioning polynomial degree (0: diagonal; -1: non-preconditioned; see Iterative linear solvers. for details)
[in]n_iternumber of iterations to perform
a pointer to newly created smoother info object, or nullptr if not available for this solver type.
◆ cs_multigrid_smoother_setup()
void cs_multigrid_smoother_setup ( void *  context,
const char *  name,
const cs_matrix_t *  a,
int  verbosity
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_it_t *)
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_multigrid_smoother_solve()
cs_sles_convergence_state_t cs_multigrid_smoother_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
const cs_real_t *  rhs,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]rhsright hand side
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
